POV-Ray : Newsgroups : povray.binaries.images : 'Accidental' isosurface Server Time
19 Jun 2026 17:33:12 EDT (-0400)
  'Accidental' isosurface (Message 39 to 48 of 68)
Subject: Re: 'Accidental' isosurface
Date: 25 Nov 2009 16:48:12
Message: <4b0da61c@news.povray.org>
PM 2Ring wrote:
> I found the Marching Cubes C code
  AFAIK the Marching Triangles algorithm produces meshes of much higher
quality than Marching Cubes.
  Marching Cubes tends to produce randomly-sized triangles and very thin
triangles whose size is in no way related to the shape, and it doesn't
take into account the curvature of the surface being tesselated.
  Marching Triangles, on the other hand, produces nice about
evenly-sized triangles for surfaces with the same curvature, and does so
adaptively, ie. producing smaller triangles at high curvature places and
larger triangles at low curvature places. The end result (when eg.
rendered as a wireframe) tends to look a lot more pleasing.
Date: 27 Nov 2009 20:45:01
Message: <web.4b108022ce81d185f4c648ed0@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> If you want to make it glass or metallic, you need to change a few
> things for the DF3 way:
> Outside value: 16
> Inside value: 200
> This is to get rid of the overshot artefacts you can get with the
> interpolation. Interpolate 2 realy don't work well when you have sharp
> jumps to zero and 255.
> Use interpolate 2
> Gives you a nice smooth, curvy, interpolation.
Thanks for the suggestion, Alain. It does look better, but it needs a much
higher max_gradient. And I noticed some strange artifacts when rendering a
simple cubical frame with interpolate 2, even though all the outer voxels in my
cube df3 are supposed to be outside the surface.
FWIW, the metallic Mandelbulb I posted was done using a mesh produced by
Marching Cubes.
Date: 27 Nov 2009 20:50:00
Message: <web.4b1081b2ce81d185f4c648ed0@news.povray.org>
That sounds great, Warp. But after over an hour of searching for Marching
Triangles code, I haven't located anything yet, not even pseudocode. :( Do you
have any suggestions for where I should look? I have found some articles in PDF
format, but I haven't downloaded any of them to check if they contain source
code.
Date: 27 Nov 2009 20:59:11
Message: <op.u320412a7bxctx@bigfrog.bredbandsbolaget.se>
> Do you have any suggestions for where I should look? I have found some
> articles in PDF format, but I haven't downloaded any of them to check if
> they contain source code.
http://en.wikipedia.org/wiki/Marching_tetrahedrons
The Wikipedia article links to:
http://local.wasp.uwa.edu.au/~pbourke/geometry/polygonise/#tetra
FE
Date: 27 Nov 2009 21:15:31
Message: <4b1087c3$1@news.povray.org>
>> Outside value: 16
>> Inside value: 200
>> Use interpolate 2
> Marching Cubes.
If the values reach zero or the highest possible value (255 for 8 bits),
  you get overshots, and those results in warping around the resulting
values from your density_map. If you go to zero, you get areas that will
eroneously use the entry for 1 on the density map. If you go to 255, you
get areas that will use the values for zero, or close to zero.
That's why I told tou to restrict the range of values used.
Date: 27 Nov 2009 21:25:00
Message: <web.4b1089c8ce81d185f4c648ed0@news.povray.org>
Thanks, Fredrik, but I've already seen those links. Marching Tetrahedrons is a
slight improvenent on Marching Cubes, but Marching Triangles appears to be quite
a different algorithm, with adaptive triangle sizes.
Date: 27 Nov 2009 21:35:01
Message: <web.4b108b70ce81d185f4c648ed0@news.povray.org>
> >> Outside value: 16
> >> Inside value: 200
> That's why I told you to restrict the range of values used.
I understand, Alain, and I have restricted the values: my df3 test files only
use 16 & 200 (I used tr to translate my existing files). But I still get these
artifacts. I didn't bother saving an image, but I'll generate a new one, if
you'd like to see for yourself.
Date: 27 Nov 2009 21:59:25
Message: <op.u323xgyj7bxctx@bigfrog.bredbandsbolaget.se>
On Sat, 28 Nov 2009 03:24:08 +0100, PM 2Ring <nomail@nomail> wrote:
> Marching Tetrahedrons is a slight improvenent on Marching Cubes,
> but Marching Triangles appears to be quite a different algorithm,
Source code for that does seem to be scarce, but the original article (by
Hilton & Illingworth) has a pretty detailed stepwise description of the
algorithm. It should not be to difficult to work from that.
FE
Date: 28 Nov 2009 07:04:40
Message: <4b1111d8@news.povray.org>
You can find some code in this thread:
http://news.povray.org/povray.binaries.scene-files/thread/%3C47be20ab%40news.povray.org%3E/
Subject: "Isosurface Approximation macros rewrite"
Date: 22 Feb 2008 01:08:59
Tor Olav
http://subcube.com
Date: 28 Nov 2009 13:10:00
Message: <web.4b116755ce81d185f4c648ed0@news.povray.org>
Thanks, Tor Olav. I'll have a look at it when I wake up. :)
