POV-Ray : Newsgroups : povray.binaries.images : 'Accidental' isosurface Server Time
21 Dec 2025 14:56:46 EST (-0500)
  'Accidental' isosurface (Message 31 to 40 of 68)
Subject: Re: 'Accidental' isosurface
Date: 23 Nov 2009 03:25:22
Message: <4b0a46f2$1@news.povray.org>
>> I think it would be easiest (ie not take 400 years) if you made a
>> program in a faster language (eg C++) to write a df3 file, and then used
>> POV to render the df3 file as an isosurface.
>  Why does it have to be an isosurface? If you created a mesh out of it,
> it would probably render about a thousand times faster,
But take a thousand times longer to code :-)
Date: 23 Nov 2009 11:07:53
Message: <4b0ab359$1@news.povray.org>
abram wrote:
> The patch:
> http://softwareprocess.es/x/x/mandelbulb/fnintern.cpp.patch
Looking at it again, I can see a simple improvement that shouldn't cost
too much computing power and would make it much more usable for pigments
and media - returning smooth values based on rate of divergence.
No change needed on your if(cnt<=0){return -1.0;}, but what you can do
for the other condition is:
return (cnt+log(log(r)/log(2.0))/log(n))/(iterations);
In words: find the count you got down to, and add a fraction to it that
approximates how close it was to taking one less iteration, then
normalizing that so it will return a range from 0 to 1+, where 0 is when
you've reached nearly the max iterations, and 1+ when it takes only 1
iteration to diverge, and higher than that when it diverges really far
in the first step.
The actual formula for that fraction is log[base n](log[base
threshold](cnt)), where your threshold for the radius is 2.0.
This would let you get smoothly colored pigment patterns if you want to
do any rate of divergence coloring, which could be interesting. Of
course feel free to change the range of returned values, this is just an
idea for normalizing. To save very minor computational cost you can
pre-calculate the log(2.0), or even change your divergence radius to E.
Chris
Date: 24 Nov 2009 07:40:00
Message: <web.4b0bd319ce81d185f4c648ed0@news.povray.org>
> PM 2Ring wrote:
> > How do you turn a df3 density file into a mesh?
>   You don't turn a df3 density file into a mesh. You calculate a mesh
> from the original fractal.
>   (Granted, it's not a trivial task, requiring using something like the
> marching triangles algorithm, but still beneficial in terms of rendering
> speed.)
Thanks, Warp.
I found the Marching Cubes C code (cunningly disguised as C++ code...) in p.b.u.
It
converts 8 bit df3 files ok, but of course the resulting mesh isn't quite as
accurate as a POV isosurface. The mesh renders much faster, but it does take
more memory & is much slower to render. So for some applications (eg a lot of
small renders for an animation) I prefer to use the isosurface.
Maybe I need to use the df3 file more efficiently. Currently, I'm only storing 1
bit per voxel: 0 if it's not in the Mandelbulb, 255 if it is. I'm wondering if
there's a better way.
Someone mentioned earlier about doing a glass Mandelbulb. I don't know if this
would work very well, since the surface is fractally bumpy. I've done a glassy
doesn't look very shiny; as you can see below, it's more like a scrunched up
ball of foil.
Download 'mandelbulbi5s90.jpg' (160 KB)
Preview of image 'mandelbulbi5s90.jpg'
Date: 24 Nov 2009 11:46:13
Message: <4b0c0dd5$1@news.povray.org>
waggy wrote:
> That inspired me to try mandelbulbs with fractional powers.  Attached is a power
> 2.3 mandelbulb, 20 iterations, rotated off-axis, and rendered as media.
  There's a skull in that image.
Date: 24 Nov 2009 12:19:07
Message: <4b0c158b@news.povray.org>
>> speed.)
> Thanks, Warp.
> It
> ball of foil.
If you want to make it glass or metallic, you need to change a few
things for the DF3 way:
Outside value: 16
Inside value: 200
This is to get rid of the overshot artefacts you can get with the
interpolation. Interpolate 2 realy don't work well when you have sharp
jumps to zero and 255.
Use interpolate 2
Gives you a nice smooth, curvy, interpolation.
Date: 24 Nov 2009 15:23:52
Message: <4b0c40d8$1@news.povray.org>
> ball of foil.
Goodness!  Who let a mathematician into the Brillo factory?
Tim Cook
http://empyrean.freesitespace.net
Date: 24 Nov 2009 16:35:01
Message: <web.4b0c505ece81d185f99d05c80@news.povray.org>
These things can look weirdly organic, especially when rendered in media.
Attached is "side" view of a power 2, iteration 20 image.
Oh, for those who don't watch the binaries.animations newsgroup, I posted an
animation of mandelbulb powers 1 through 100 rendered in media.
http://news.povray.org/povray.binaries.animations/message/%3Cweb.4b09e469315ec22ef99d05c80%40news.povray.org%3E/#%3Cweb
(Just remove the .dat extension and it should play on MS, Mac, and Linux
systems.)
Download 'mb2i20_media_1024.png' (428 KB)
Preview of image 'mb2i20_media_1024.png'
Date: 24 Nov 2009 17:10:01
Message: <web.4b0c5989ce81d185f99d05c80@news.povray.org>
> ball of foil.
I found the same thing.  However, lower iteration mandelbulbs show some promise,
especially if you just cut out part of it.  Attached are power 8, iteration 3
mandelbulbs in stock glass and chrome.  (I apologize I suck at glass.)
~David
Download 'mb8i3_glass_chrome.png' (769 KB)
Preview of image 'mb8i3_glass_chrome.png'
Date: 25 Nov 2009 16:48:12
Message: <4b0da61c@news.povray.org>
  AFAIK the Marching Triangles algorithm produces meshes of much higher
quality than Marching Cubes.
  Marching Cubes tends to produce randomly-sized triangles and very thin
triangles whose size is in no way related to the shape, and it doesn't
take into account the curvature of the surface being tesselated.
  Marching Triangles, on the other hand, produces nice about
evenly-sized triangles for surfaces with the same curvature, and does so
adaptively, ie. producing smaller triangles at high curvature places and
larger triangles at low curvature places. The end result (when eg.
rendered as a wireframe) tends to look a lot more pleasing.
Date: 27 Nov 2009 20:45:01
Message: <web.4b108022ce81d185f4c648ed0@news.povray.org>
> Outside value: 16
> Inside value: 200
> Use interpolate 2
Thanks for the suggestion, Alain. It does look better, but it needs a much
higher max_gradient. And I noticed some strange artifacts when rendering a
simple cubical frame with interpolate 2, even though all the outer voxels in my
cube df3 are supposed to be outside the surface.
FWIW, the metallic Mandelbulb I posted was done using a mesh produced by
Marching Cubes.
