"Tim Cook" <z99### [at] gmailcom> schreef in bericht
news:4afc0f9c$1@news.povray.org...
> Hijacking thread somewhat, and not sure if it's the latest version of
> Poseray or not, but it exports Poser objects incorrectly (it might be a
> setting I have ticked) and requires editing of the .inc file to
> work...namely:
> section
> //This encapsulates the material into the mesh so that Moray can use the
> original materials
> #declare Victoria_4_hip_hip_2_hip__2_SkinHip_=...
> (and so forth)
> followed by:
> //Model assembly from the meshes
> #declare Victoria_4_hip_=
> union {
> object{Victoria_4_hip_hip_2_hip__2_SkinHip_uv_mapping}
> object{Victoria_4_hip_rThigh_2_rThigh__2_SkinHip_uv_mapping}
> object{Victoria_4_hip_rThigh_2_rThigh__3_SkinLeg_uv_mapping}
> object{Victoria_4_hip_lThigh_2_lThigh__2_SkinHip_uv_mapping}
> object{Victoria_4_hip_lThigh_2_lThigh__3_SkinLeg_uv_mapping}
> split_union off
> the problem is the fact that it does not declare any objects that end with
> "_uv_mapping", making POV stall. you have to manually remove the
> "_uv_mapping" from each item in this part. it doesn't take very long, but
> it is a nuisance that shouldn't be necessary.
This is indeed to go to the povray.tools.poser newsgroup.
What version of Poseray are you using? I do not get this output with pure
Poser figures, but Victoria is Daz|Studio, so maybe Poseray incorrectly
writes from there?
