POV-Ray : Newsgroups : povray.binaries.images : Re: Moss Vine test [~30k] Server Time
18 Aug 2025 03:39:38 EDT (-0400)
  Re: Moss Vine test [~30k] (Message 1 to 10 of 28)
Subject: Re: Moss Vine test [~30k]
Date: 8 Mar 2009 14:51:45
Message: <49b413c1@news.povray.org>
More testing....here is the infamous torus...
ian
Download 'NastyMossDonut.jpg' (112 KB)
Preview of image 'NastyMossDonut.jpg'
Date: 8 Mar 2009 15:15:00
Message: <web.49b4182cd4fd5b28219167190@news.povray.org>
That's looking really good! In reply to your previous question in the ruins
thread, it might be criminal not to try this out... :-)
What sort of parse/render time / memory usage are we looking at?
Bill
Date: 9 Mar 2009 01:20:27
Message: <49b4a71b$1@news.povray.org>
"Bill Pragnell" <bil### [at] hotmailcom> wrote in message
news:web.49b4182cd4fd5b28219167190@news.povray.org...
> ruins
> Bill
Why thank you. :-D
Due to the fact I'm using cone differences to make the individual leaves of
the moss....a lot of time. Each moss object as seen in that image is
composed of 260 objects. I would like to use those mesh approximation macros
you have to create a mesh of the base level of the moss object that could
then be translated as needed.
There are a few more optimizations that I *need* to do to reduce failed
tests, because that image took 1.5mil, which is why the parse time was
59min.
I think that the mesh moss might reduce the ram needed.
Below are the stats:
ian
Scene Statistics
  Finite objects:       355690
  Infinite objects:          0
  Light sources:             1
  Total:                355691
Possible Rendering Error: Maximum trace level reached! If your scene
contains black spots read more about the max_trace_level setting in the
documentation!
Render Statistics
Image Resolution 1280 x 1024
Pixels:          1312000   Samples:         2105120   Smpls/Pxl: 1.60
Rays:            4853594   Saved:                 0   Max Level: 5/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Cone/Cylinder                717808152       102235121     14.24
CSG Intersection             316414269        25587670      8.09
CSG Union                     13231600            8405      0.06
Sphere                        28214853          994453      3.52
Torus                         15609517        11444766     73.32
Torus Bound                   15609517        12789091     81.93
Bounding Box                3008474496       832260586     27.66
Light Buffer                6363773504      3437107572     54.01
Vista Buffer                 414971335       317948308     76.62
Roots tested:              12789091   eliminated:              1903432
Calls to Noise:                   0   Calls to DNoise:         5809594
Shadow Ray Tests:          13850948   Succeeded:               7182259
Transmitted Rays:           2748474
I-Stack overflows:              275
Smallest Alloc:                  18 bytes
Largest  Alloc:             6000016 bytes
Peak memory used:         571245785 bytes
Total Scene Processing Times
  Parse Time:    0 hours 59 minutes 52 seconds (3592 seconds)
  Photon Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Cloth Time:    0 hours  0 minutes  0 seconds (0 seconds)
  Mechsim Time:  0 hours  0 minutes  0 seconds (0 seconds)
  Render Time:   0 hours  8 minutes  8 seconds (488 seconds)
  Postpr. Time:  0 hours  0 minutes  0 seconds (0 seconds)
  Total Time:    1 hours  8 minutes  0 seconds (4080 seconds)
CPU time used: kernel 5.30 seconds, user 4065.16 seconds, total 4070.45
seconds
Render averaged 322.01 PPS over 1310720 pixels
POV-Ray finished
Date: 9 Mar 2009 06:25:00
Message: <web.49b4ee36d4fd5b286dd25f0b0@news.povray.org>
I'm not sure my macros are the best solution for that; even if you're genuinely
after a cone, you're better off just writing a simple cone mesh macro for
yourself. I'd be inclined to use very simple flat triangle-based leaves, and
don't worry about smoothing - it's surprising how far a low-detail leaf goes if
it's not going to be seen in closeup.
Make sure your leaf/cone macros just output triangles, not a complete mesh -
have another macro build a clump of leaves as a single mesh that you can then
clone.
[snip stats]
Definitely. I'd expect it to need less than 10% of your current usage, if the
meshes are deployed properly. You might not see a drastic speed up for
high-quality renders, because this sort of thing gets slowed down quite a lot
by the antialiasing, but you should find that non-aa tests run blindingly fast.
Bill
Date: 9 Mar 2009 07:14:09
Message: <49b4fa01@news.povray.org>
news:web.49b4ee36d4fd5b286dd25f0b0@news.povray.org...
> genuinely
> and
> goes if
Well its actually the difference of two very closely spaced cones, to
produce a concave leaf. I am sure that even a single triangle would work,
but I've never used them, ever, so am profoundly lost...more stuff that I
need to learn. :-p
> mesh -
> then
> clone.
Do you know of any simple files which would be a starting point?
> the
> lot
> fast.
Ok. I ran the macro on a a cyl column, just to see what you might be looking
at.
It ended up taking 7min to parse with 90 vines and 15k moss object tests
(thats why you don't see many of them). I'm going to retry with 500k moss
object tests. It is clear that I need to also optimize the way in which
trace is being used in this macro to drop the parse time, though changing
the direction of the test vector has a LOT to do with everything. I have a
decent amount of work ahead, as this is still just using the first code I
threw together.
Here are the stats for the column test followed by the image (note my kernel
time...6.66...yuck!):
Render Statistics
Pixels:          1312000   Samples:         1448368   Smpls/Pxl: 1.10
Rays:            1683045   Saved:                 0   Max Level: 5/5
Cone/Cylinder                 11779353         2352125     19.97
CSG Intersection               1301463          138887     10.67
CSG Union                      5081629          562648     11.07
Sphere                         5581614         1036479     18.57
Bounding Box                  26652056        11990304     44.99
Light Buffer                  49398689        21346439     43.21
Vista Buffer                  12582545         8880334     70.58
Calls to Noise:                   0   Calls to DNoise:         1333006
Shadow Ray Tests:           1213449   Succeeded:                384576
Transmitted Rays:            234677
I-Stack overflows:              685
Largest  Alloc:              992880 bytes
Peak memory used:         138525975 bytes
  Parse Time:    0 hours  7 minutes  1 seconds (421 seconds)
  Render Time:   0 hours  0 minutes 10 seconds (10 seconds)
  Total Time:    0 hours  7 minutes 11 seconds (431 seconds)
CPU time used: kernel 6.66 seconds, user 416.14 seconds, total 422.80
seconds
Render averaged 3100.12 PPS over 1310720 pixels
POV-Ray finished
ian
Download 'VineTest1_2.jpg' (13 KB)
Preview of image 'VineTest1_2.jpg'
Date: 9 Mar 2009 07:55:01
Message: <web.49b502d4d4fd5b286dd25f0b0@news.povray.org>
> need to learn. :-p
Triangles are not difficult... if you can write a climbing ivy macro I'm sure
you'll have no trouble. The main pig is that you can't use the regular
transforms on the individual triangles in a mesh, so you'll have to calculate
your triangle vertices the old-fashioned way; make use of vrotate() and
friends. After that, just treat a mesh as any other object. Don't worry about
mesh2 yet!
You could take a look at Chambers' grass macro in the object collection,
although that's just a single loop to create many blades in one mesh (I think -
I just glanced over it).
Start small and simple, maybe with only hand-built clump meshes at first, till
you're comfortable with using triangles.
> at.
Looks very good.
That's quite long, but I guess finding the vine routes will always be quite
intensive. I once had a scene parse for over half an hour, so I wouldn't worry
too much... you could always save the positions to a data file if there's lots
of heavy calculation. :-)
Bill
Date: 9 Mar 2009 20:20:18
Message: <49b5b242$1@news.povray.org>
> I am sure that even a single triangle would work, but I've never used
> them, ever, so am profoundly lost...more stuff that I need to learn. :-p
You could make a simple leaf in any modelling software and convert it to a
POV-Ray mesh. As long as you pay attention to the dimensions it should not
be hard to incorporate into your macro. If you offered up some dimensions I
bet someone here would do it for you.
Date: 11 Mar 2009 00:51:37
Message: <49b74359$1@news.povray.org>
news:web.49b502d4d4fd5b286dd25f0b0@news.povray.org...
> sure
> calculate
> about
> mesh2 yet!
O_o'
They seem tedious more than difficult....I hate tedium.
> think -
> till
I'll take a look at that there, and given that those are blades of grass,
its probably not too far off from what I want to do with moss leaves anyway,
I'd just need to grab one blade.
> quite
> worry
> lots
Suprisingly, its not the vine routes that takes the time, its tracing the
moss onto the individual vine components.
I need to do something differently with that, but I'll figure it out. I have
a few ideas.
ian
Date: 11 Mar 2009 00:53:32
Message: <49b743cc$1@news.povray.org>
"Mike Hough" <nos### [at] nospamcom> wrote in message
news:49b5b242$1@news.povray.org...
> I bet someone here would do it for you.
I've tried playing in wings3D...but I can't find CSGs..
hI'll probably just model it in Bryce or Truespace, then export DXF. That
can be converted to POV, right?
ian
Date: 11 Mar 2009 02:26:05
Message: <49b7597d$1@news.povray.org>
Poseray can import DXF. You might need to smooth the mesh after you import.
I think that poseray will also include comments with the dimensions of the
object in the exported file.
