Well folks, I think I've finally done it. I've managed to successfully
alter my luminous bloom code to accommodate POV-Ray's new .hdr file
format. This will probably work only with the beta versions.
The attached image shows the effect. Notice the phong highlight, how it
produces a bright, diagonal glare. The color of the highlight really
shows up nicely. Look at the other portions of the image. Areas which
would normally show a lot of glare now produce only a minimal effect.
The scene's objects have really low diffuse values. The yellow light
source has an intensity of about 20, and the phong highlight has a value
of one.
Unfortunately, .hdr images tend to render more slowly than other
formats, and it really affects the final render time when many of them
are averaged together in this kind of implementation.
I hope to release both new luminous bloom versions soon.
Sam
Download 'lbtest_hdr1_27.jpg' (55 KB)
Preview of image 'lbtest_hdr1_27.jpg'
Here's another example of the HDR glare effect. At the top of the lamp
shade you can see visible stair-stepping on the pixels. This happened
during the first render pass. It would seem POV-Ray still has trouble
antialiasing super-bright pixels. The light source inside the lampshade
has an intensity of five.
Sam
Download 'lbtest_hdr1_38.jpg' (47 KB)
Preview of image 'lbtest_hdr1_38.jpg'
This looks like something that POV-Ray could do very fast as a
post-processing step once some kind of post-processing support is added
(and this is, in fact, what I have suggested as an alternative to the
two current antialiasing methods, ie. pre-clamping and post-clamping,
both of which have their problems.)
I'd probably focus my efforts on such post-processing effects, once the
official version of POV-Ray supports them. It would be nice if the PP
step was multithreaded :)
So, how is development of an extensible version of POV-Ray going,
anyway? There was talk of the ability to add new features with a
plugin-like system, but I haven't heard anything about it in a while.
BTW, I was able to reduce the aliasing by adjusting a single value in my
code. It will be the default from now on.
Sam
