POV-Ray : Newsgroups : povray.binaries.images : Sunflower Server Time
31 May 2026 03:18:46 EDT (-0400)
  Sunflower (Message 1 to 6 of 6)
Subject: Sunflower
Date: 18 Mar 2008 02:54:19
Message: <47df752b@news.povray.org>
Try to ignore the ground..  ;-S
Progress is slow. I need to find a better way to show the veins on the
leaves.
Comments and help welcome.
-Nekar Xenos-
Download 'Sunflower.jpg' (286 KB)
Preview of image 'Sunflower.jpg'
Subject: Re: Sunflower
Date: 18 Mar 2008 03:40:23
Message: <47df7ff7$1@news.povray.org>
"Nekar Xenos" <nek### [at] gmailcom> wrote in message
news:47df752b@news.povray.org...
> leaves.
    It's not tall enough! ;) That's looking very good. How have you modelled
the leaves?
        ~Steve~
> -Nekar Xenos-
Date: 18 Mar 2008 03:54:10
Message: <47df8332@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:47df7ff7$1@news.povray.org...
>> leaves.
>How have you modelled the leaves?
I first drew the edge of the leaf in CorelDraw in bezier curves. I then
looked at the mouse coordinates when I hovered over each node and used those
coordinates for the bezier patch.
I used quilted textures within scaled quilted textures for the veins and
applied shear-trans to each smaller one to try and get a branch effect, but
that doesn't seem to work.
Posted the source to p.b.s-f
-Nekar Xenos-
Date: 18 Mar 2008 04:24:41
Message: <47df8a59@news.povray.org>
news:47df8332@news.povray.org...
> those coordinates for the bezier patch.
     Hmm, it renders with holes in the petals with 3.5, 3.6 is fine though.
I'm not at all familiar with the way that you did this, but my first thought
was can you not go back to CorelDraw and remodel the leaves with the leaf
veins added too? Would that not work?
    ~Steve~
> -Nekar Xenos-
Date: 18 Mar 2008 04:40:35
Message: <47df8e13@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:47df8a59@news.povray.org...
I used 3.6. Its the filter transparency I used to try and simulate
translucency
> thought was can you not go back to CorelDraw and remodel the leaves with
> the leaf veins added too? Would that not work?
Working on a 500mhz ThinkPad it does slow things down a bit. so I'm worried
that such a large amount of patches will slow down Pov too much.
Maybe someone in this group knows of a function that I can use as a pigment
function instead?   {=')
-Nekar Xenos-
Date: 18 Mar 2008 13:24:05
Message: <47e008c5$1@news.povray.org>
That flower looks great!
Maybe try the crackle pattern? But it might be too asymmetric.
