![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
... I don't care whether there's enough trees to call it a forest, I'm
still calling it a forest macro ...
I think the macro is almost finished--I'll post the source sometime next
week.
Actually, I now have an include file with two macros: One that plants a
single clump of trees centered at a specified location, and one that
populates an entire landscape by planting many clumps at random
locations. I can mix and match the two depending on how much control I
need over the scene.
Also, the landscape planting macro takes two shape arrays now: An array
of tree shapes, and an array of bush shapes. The bush clumps are
centered around the tree clumps, but spread out more.
While I'm posting, is anyone besides Sven interested in my landscape
mesh generator program? I didn't originally intend to distribute the
program, since Terragen and Geomorph are both already free and much more
full-featured. However, if people are interested (one person does not
count as "people") I'll try to clean up the program and put it online.
William Tracy
afi### [at] gmail com -- wtr### [at] calpoly edu
Who could pollute the entire world?
-- Nausicaa
Download 'a4b.jpg' (171 KB)
Preview of image 'a4b.jpg'
![a4b.jpg](/povray.binaries.images/attachment/%3C47ad2f6b%40news.povray.org%3E/a4b.jpg?ttop=444265&toff=3400&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hmm... How about using a heightfield image to tell it where to put more
trees? :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> week.
Count me in.
Ger
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Lovely.
I've been thinking about how trees are distributed and I've noticed that in
RL the dense growth tend to be in the valleys and "dents" and of course
along streams and rivers. I think this has to do with how water flows when
it rains and tends to accumulate in puddles obviousley carrying any loose
seeds with it. Maybe an easy way to simulate this is by giving lower
altitudes a higher denstiy and higher probabilty of clumps.
Keep up the good work!
"William Tracy" <wtr### [at] calpoly edu> wrote in message
news:47ad2f6b@news.povray.org...
I'm interested. Especialy because it's done in Pov-Ray :)
-Nekar Xenos-
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> trees? :)
That's overkill for my specific application. :-)
I need to place a few clumps to cover some artifacts in a render I'm
working on, then plant the rest of the scene randomly.
William Tracy
The flavor of Redcode used in this guide is (mostly) the current de
facto standard, the ICWS '94 Standard Draft with pMARS 0.8 extensions.
(Sort of like the Netscape extensions to HTML... Hmm... Luckily we still
don't have a Microsoft Corewar Simulator. Maybe they think the market's
too small.)
-- Ilmari Karonen, http://vyznev.net/corewar/guide.html
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
If you wanted to really do it right, you could find the height of your
target location, then sample the area immediately around it. If the
location is lower than its immediate surrounds (i.e., it's in a valley,
as opposed to being in the middle of a lowland plain), you would
increase the likelihood of planting a tree. :-)
That said, I'm really only intending to use this macro for this month's
TC-RTC stills round, and next month's animations round. The macro has
reached a point where I think it's just about good enough for my entries.
If anyone else wants to try adding extra features to the macro, by all
means go ahead. :-)
... I'm probably going to need to optimize this a bit more if I'm going
to use it for animation. Right now, I have a scene that takes forty
seconds just to parse. :-/
William Tracy
If we were told to parse starting *after* the supplied String, then do
what we need to do to indicate pilot error.
-- Laird Nelson, blogging on Java programming
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> If you wanted to really do it right ...
Come to think of it, you could implement what I described as some
external utility that manipulates a height map, and outputs another
height map that is read as a density function by the tree macro, in the
same vein as Nicolas' suggestion.
Actually, the height map transformation would probably be just a simple
convolve operation that could be hacked together in some image editor.
Hmm ... So many ideas, so little time. :-)
William Tracy
"You cannot predict the future."
"I knew you were going to say that."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Excellent work, William! Looking forward to your macro.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:47ad6383$1@news.povray.org...
Cool, and thanks. :)
For what it's worth, I'm about 4 days into my stills image now, so I
should be submitting soon. ;)
~Steve~
> William Tracy
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wow!
I love this one, too! Even more!
It looks very, very good!
Sven (with a wicked greedy light in the eyes)
"William Tracy" <wtr### [at] calpoly edu> schrieb im Newsbeitrag
> week.
> William Tracy
> -- Nausicaa
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
