I've fixed it up a bit. I'll post the source as well. I've removed the
LightSys stuff because it gets too cluttered. I've also used my now fixed up
galaxy macro.
I would have liked to work more on my jazz scene but my home PC's
motherbaord has died... : (
-Nekar Xenos-
Download 'Pov-well-2.jpg' (96 KB)
Preview of image 'Pov-well-2.jpg'
I'm not sure if this depiction of Earth's gravity is correct. Earth's
gravity increases as you get closer to it, using the usual formula.
However, once you get inside Earth's surface and start going towards its
center, the gravity decreases until at Earth's center there's zero gravity.
OTOH, I must admit I don't know what is the common convention for
depicting a gravity well as a plane. Is the plane displaced according to
the strength of the gravity or according to the change in gravity with
respect to the surroundings?
> gravity.
The slope of the plane represents the force of gravity.
The increased area of the surface near the gravity well
represents the increased volume of space-time...
the height is the inverse of the increased density of
space-time (it seems more correct for gravity to point down).
Space-time is one of those things that is difficult to
visualize, it's easier to think of gravity as a force, instead
of thinking of it as an expansion of space-time.
Hash: SHA1
> galaxy macro.
Much nicer than your first image.
Very cool. :-)
William Tracy
afi### [at] gmailcom -- wtr### [at] calpolyedu
You know you've been raytracing too long when you switch to Linux
because Microsoft won't release the source code to Windows so you can
change all the buttons in your OS to use cool little raytraced images.
-- Taps a.k.a. Tapio Vocadlo
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHYyJCKrVIcTMekC8RApBZAJ0WeE+Rf3lPTnr1eew3U3G4aXyKVwCggUYM
Qf5WWTuUgFx2gu8dmHkAyr4=
=SkUK
-----END PGP SIGNATURE-----
"Warp" <war### [at] tagpovrayorg> wrote in message
news:4762fc3d$1@news.povray.org...
> gravity.
The first one was on the same height. This one just looked better when I
lowered the gravity well, so call it artistic license... ;o)
I am not sure the actual aim here is achievable: I want it to resemble the
POV-Ray logo (or at least a "P") be mathematically correct (of which I know
0) and still look good.
Any help will be appreciated.
-Nekar Xenos-
Nekar Xenos napsal(a):
>> gravity.
try moving the light source close to the earth so its rings' left half
is in shadow. You might need to add another light source.
> know
Try using a shear transform to slant the gravity well,
that way it'll resemble the P from the logo more closely.
Shear_Trans(x, vnormalize(vrotate(y,<0,0,-30>)), z)
Download 'Pov well 2.jpg' (68 KB)
Preview of image 'Pov well 2.jpg'
"Tim Attwood" <tim### [at] comcastnet> wrote in message
news:4764fd6e@news.povray.org...
>> the
>> know
Thanks,
I tried this but in the end decided to rather rotate the plane, - I think it
looks better. I've added polar ice and worked on the land and cloud
textures.
I don't know if it's just my area, but it seems like South Africa's internet
has become bottlenecked over the festive season, so I don't know if this
will upload. Hi-speed adsl has been reduced to slower than a 56k modem...
-Nekar Xenos-
Download 'Pov-well-4.jpg' (141 KB)
Preview of image 'Pov-well-4.jpg'
