POV-Ray : Newsgroups : povray.binaries.images : Flares Plugin Server Time
10 Apr 2026 14:26:10 EDT (-0400)
  Flares Plugin (Message 1 to 8 of 8)
Subject: Flares Plugin
Date: 1 Nov 2007 18:58:16
Message: <472a6818@news.povray.org>
The past 2 weeks I've been working on my lensflare-macros, and I think it's
more or less complete now.  There are 22 pre-defined flare-types (20 ports
of Colefax's lens effects and 2 of my own), there's a randomized type
(directly copied from Colefax's system), and 4 types of "visual effects"
(noise, negative, contrast and brightness).
This image uses one of my own effects.  It also uses the noise, contrast and
brightness visual effects.
It's slightly slower than Colefax's system, but gives more accurate results,
and doesn't need a high max_trace_level (this image has a max_trace_level of
5)
Source posted to p.b.s-f
I still need to write some documentation though...
but anyway! does it look believable?
cu!
Download 'flares_test.jpg' (116 KB)
Preview of image 'flares_test.jpg'
Subject: Re: Flares Plugin
Date: 2 Nov 2007 02:04:43
Message: <472acc0b@news.povray.org>
"Zeger Knaepen" <zeg### [at] povplacecom> wrote in message
news:472a6818@news.povray.org...
> it's more or less complete now.  There are 22 pre-defined flare-types (20
> ports of Colefax's lens effects and 2 of my own), there's a randomized
> type (directly copied from Colefax's system), and 4 types of "visual
> effects" (noise, negative, contrast and brightness).
> and brightness visual effects.
> results, and doesn't need a high max_trace_level (this image has a
> max_trace_level of 5)
The first impression is a "bad" photograph :o)
I think you're moving in the right direction, the yellow is too dark though.
-Nekar Xenos-
Date: 2 Nov 2007 10:35:00
Message: <web.472b432f8550f2da817d81a80@news.povray.org>
WOW ! :o)
Date: 2 Nov 2007 11:25:01
Message: <web.472b4ec48550f2da2c10637b0@news.povray.org>
very nice, but can't say it looks exatcly realistic:  the light source from the
boat's lamp is too bright for such a sunny day!  But the flares are good
looking no doubt...
Date: 2 Nov 2007 12:33:10
Message: <472b5f56$2@news.povray.org>
Believable?
What do you want me to believe? That you were using a camera with multiple
imperfect lens elements and a six section aperture ring? You succeeded. I
assume that the trails intersect the 'look at' axis.
I would expect in a simulation of a photograph that the contrast would drop
dramatically as the imperfections and internal reflections that cause lens
flare would also produce diffuse glare on the film.
Can you simulate the optics of modern, cheap fixed focus cameras (circular
apperture, fewer, dirtier lens elements) and so forth?
Nice work. Keep it up.
DLM
Date: 3 Nov 2007 01:48:35
Message: <472c19c3@news.povray.org>
"nemesis" <nam### [at] gmailcom> wrote in message
news:web.472b4ec48550f2da2c10637b0@news.povray.org...
> from the
I agree, but that can be changed of course :)
> looking no doubt...
tnx!
cu!
Date: 3 Nov 2007 01:49:16
Message: <472c19ec$1@news.povray.org>
"Nekar Xenos" <nek### [at] gmailcom> wrote in message
news:472acc0b@news.povray.org...
I suppose that's the impression I was going for :p
> though.
yes, I agree.  Can be changed of course.
cu!
Date: 3 Nov 2007 02:11:56
Message: <472c1f3c@news.povray.org>
"dlm" <me### [at] addressinvalid> wrote in message
news:472b5f56$2@news.povray.org...
> Believable?
> drop dramatically as the imperfections and internal reflections that cause
> lens flare would also produce diffuse glare on the film.
I suppose that can be simulated by using a lower contrast filter (which is
done by adding Flares_VisualEffect("contrast",.5) to the beginning of the
scene, right after including "flares_types.inc")
Can see no reason why not.  There are 22 prebuilt lensflares included, and
if none of those fit your needs, you can always make your own kind out of 10
kinds of glows, 9 kinds of "rays", 9 kinds of "streaks" and 11 kinds of
spots.  And if none of those flare-parts look the way you like it, you can
always make your own.  So in theory, anything's possible.
thanks! :)
cu!
