POV-Ray : Newsgroups : povray.binaries.images : Photon speckles Server Time
30 Sep 2024 13:20:46 EDT (-0400)
  Photon speckles (Message 1 to 10 of 15)
Subject: Photon speckles
Date: 16 Sep 2007 20:13:52
Message: <46edc6c0@news.povray.org>
I'm sure this is a frequent problem, but I just can't find the information
in the documentation. I'm rendering this scene with photons and as you can
see in the attached image the returning rays through the cone are coming
back as speckles. I've tried some of the photon settings with no success.
Thanks for any suggestions.
-- Dave
Download 'Speckles.jpg' (40 KB)
Preview of image 'Speckles.jpg'
Subject: Re: Photon speckles
Date: 16 Sep 2007 21:36:40
Message: <46edda28@news.povray.org>
I ran it again without photons, so it's just a basic glass cone on a wood
textured plane. What am I missing here?
"NetDave" <new### [at] netdavecom> wrote in message
news:46edc6c0@news.povray.org...
> -- Dave
Download 'Specles2.jpg' (27 KB)
Preview of image 'Specles2.jpg'
Date: 16 Sep 2007 23:17:53
Message: <46edf1e1$1@news.povray.org>
Increase max_trace_level maybe ?
>> -- Dave
http://sibylone.free.fr
Date: 17 Sep 2007 04:30:00
Message: <web.46ee3abc6a7782f5943b35b60@news.povray.org>
> > -- Dave
Do they go away if you use high-quality antialiasing?
It might be coincident surfaces causing those artefacts; have you tried
translating the cone upwards (or the plane downwards) by a very small
amount?
Otherwise, as JC suggested, try increasing your max_trace_level.
- sooperFoX
Date: 17 Sep 2007 09:17:21
Message: <46ee7e61$1@news.povray.org>
NetDave nous apporta ses lumieres en ce 2007/09/16 20:13:
> -- Dave
It can be a coincident surface problem: move the cone very slightly up.
It can be not enough photons: reduce the spacing or increace count.
It can be that you exeeded max_trace_level: increase max_trace_level in
global_settings.
You know you've been raytracing too long when you can describe in perfect,
legal, pov syntax, how to re-create everything in your computer room using
primitives and csg operations.
fish-head
Date: 18 Sep 2007 00:12:47
Message: <46ef503f@news.povray.org>
Thanks for all the suggestions everyone. So far nothing has worked. I tried
a bunch of other objects and they all seem to work ok. I guess I'll come
back to this sometime, but for now the cone doesn't seem to want to
cooperate. Lots of other shapes will make this scene work and I'll post it
when I'm satisfied with the composition.
-- Dave
> -- Dave
Date: 1 Oct 2007 04:15:01
Message: <web.4700aae86a7782f5943b35b60@news.povray.org>
Hi Dave,
If you're using the area_light keyword *inside* the photons block of your
light_source, that will cause artifacts in a lot of cases. Try disabling it
(you can leave it turned on in your native light_source for the soft
shadows) and you should lose the speckles.
Below is an excerpt from the pov-ray documentation (3.6.3.3 Photons FAQ,
second-last question):
"Photons do work with area lights. However, normally photon mapping ignores
all area light options and treats all light sources as point lights. If you
would like photon mapping to use your area light options, you must specify
the "area_light" keyword within the photons { } block in your light
source's code. Doing this will not increase the number of photons shot by
the light source, but it might cause regular patterns to show up in the
rendered caustics (possibly splotchiness)."
The last sentence is of interest, I think.
-- sooperFoX
> -- Dave
> > -- Dave
Date: 21 Oct 2007 15:13:11
Message: <471ba4c7@news.povray.org>
Thanks for the suggestion sooperFoX, but I'm not using area_light at all.
Here's my light_source:
light_source
  <500,350,-100>
  color Light_Color
  spotlight
  radius 1
  falloff 2.5
  tightness 10
  point_at <0, 0, 15>
  photons
    reflection on
    refraction on
The wierd thing is this ONLY happens when I use a cone object. Nothing else
causes it. FWIW, I've attached the final result of my tinkering. Some of the
old-timers may recognize this from some previous experiments with photons. I
just resurrected it in order to generate a 1920x1200 version for my new
monitor desktop.
-- Dave
"sooperFoX" <bon### [at] gmailcom> wrote in message
news:web.4700aae86a7782f5943b35b60@news.povray.org...
> Hi Dave,
> it
> ignores
> you
> -- sooperFoX
>> tried
>> it
>> -- Dave
>> > information
>> > can
>> > coming
>> > success.
>> > -- Dave
Download 'DesktopChessRing2.jpg' (42 KB)
Preview of image 'DesktopChessRing2.jpg'
Date: 25 Oct 2007 06:30:00
Message: <web.47206f316a7782f5943b35b60@news.povray.org>
What happens if you translate the cone upwards by about half the width of
that ring there? Do you still get the speckles then?
If you'd like to share the source of your speckles cone scene I'd be happy
to play with it to try and see what is doing it (or better, to stop it!)
I would also like to see what happens when increasing the resolution of your
render to include only the cone at about/above 1200x1600 or so... what do
the speckles look like then? Maybe it can give some clue as to what is
happening. I have a reasonably fast dual-core PC, so again, I'd be happy to
try this for you on either POV 3.6/3.7 or MegaPOV 1.21 -- which, by the way,
are you using?
-- sooperFoX
> light_source
>   <500,350,-100>
>   color Light_Color
>   spotlight
>   radius 1
>   falloff 2.5
>   tightness 10
>   point_at <0, 0, 15>
>   photons
>     reflection on
>     refraction on
> monitor desktop.
Date: 26 Oct 2007 00:53:34
Message: <472172ce$1@news.povray.org>
I posted  the a sample of the code that demonstrates the problem in
p.b.scenefiles. I'm using the current POV release. I noticed that if I
translate the cone a towards the foreground, the speckles seem to diminish,
but that doesn't solve my question.
news:web.47206f316a7782f5943b35b60@news.povray.org...
> your
> to
> way,
> are you using?
> Cheers
> -- sooperFoX
>> light_source
>>   <500,350,-100>
>>   color Light_Color
>>   spotlight
>>   radius 1
>>   falloff 2.5
>>   tightness 10
>>   point_at <0, 0, 15>
>>   photons
>>     reflection on
>>     refraction on
>> else
>> the
>> photons. I
>> monitor desktop.
