POV-Ray : Newsgroups : povray.binaries.images : PoseRay 3.11.0 released: comments for future improvements Server Time
15 Aug 2025 15:13:50 EDT (-0400)
  PoseRay 3.11.0 released: comments for future improvements (Message 1 to 10 of 15)
Subject: PoseRay 3.11.0 released: comments for future improvements
Date: 16 Jun 2007 09:20:14
Message: <4673e38e@news.povray.org>
Being a heavy user of Poser 7 and Poseray, it is almost unavoidable that I
have to come up with a number of (new) comments, partly deriving from the
use of Poser 7. I post them here, together with an example image, so that
everybody interested may learn from them and may add things that I have
forgotten.
1) Bump mapping:  When applying an image map as bump map to, e.g. a cloth,
one may often want to scale down (or up) the bump map in order to obtain the
desired effect. In Poser, this is done by changing the U_Scale and V_Scale
of the bump image map in the Material Room. However, this scaling is not
taken on by Poseray and, to obtain the desired effect, one needs to add
manually a scale parameter to the map in the exported xxx_POV_mat.inc file.
2) Bump_size: By default, Poser defines a white background parameter in the
Material Room for all the used image maps. This has unexpected consequences
when using a bump map, even if the used image has traditionally black as
background and white as foreground. Poseray translates the bump sizes into
negative values which may disconcert at first, but renders correctly in
POV-Ray. However, the values are very high (e.g. -20, or -50) for some
reason (even if the bump strength in Poser is set to 1.0) and they may have
to be changed to more conventional values manually.
3) Procedural textures: Procedural textures in Poser are only shown in
Poseray (and exported to POV-Ray) as pigments and finishes. This is
understandable as the procedural parameters used by Poser may not be easily
translated into POV-Ray code. When using procedural textures in Poser, best
is to find an equivalent POV-Ray texture and use that instead.
4) G2 hair: Poser 7 introduced G2 figures and also G2 conforming hair. For
many reasons G2 hair is more realistic than the conforming hair in Poser 6.
However, when exported to POV-Ray through Poseray, the result is rather
disappointing. I discovered now why this is so. G2 hair uses a bump map for
displacement mapping. Why for displacement is debatable as the hair mesh is
fine but not particularly so. Better is to use the map as a bump map. The
results are much better. However, there is a problem with G2 conforming hair
and Poseray. First, the hair geometry (in the example I used at least) has
its morphs centered on the neck body part of the hair figure. In Poseray the
neck of the human figure AND the neck of the hair figure are translated into
one single mesh geometry group. Second, and as a consequence probably, the
displacement map for the hair group is not loaded. While the material maps
for the hair are properly loaded, the bump map is not. When adding the
proper bump map in Poseray and exporting to POV-Ray, the results are
excellent.
The attached image resumes the comments above and shows how the figure and
the hair should be.
Download 'Pov_render_04.jpg' (47 KB)
Preview of image 'Pov_render_04.jpg'
Subject: Re: PoseRay 3.11.0 released: comments for future improvements
Date: 16 Jun 2007 12:38:59
Message: <46741223@news.povray.org>
I may implement scaling into the basic materials in the next version but
now you can go into the POV-Ray tab and copy the material into the text
window and edit the bump map UV scaling there as a transformation. The
copy command is in the POV-Ray tab as insert->materials->copy from basic
tab.
I will look into this. Since I do not have Poser 7 I assumed bump_size
behaved the same as in Poser 6.  You can scale the imported bump size in
the Poser scene import options. The default value is what Poser 6 uses.
I noticed some inconsistencies between the bump_size implementation
using different models and whether the bump map was an image or a
proprietary BUM file.
I agree. Would be nice if Poser could bake and export its procedural
textures. This and strand hair are features that makes Poser less
portable to other applications.
> excellent.
I will look into this since I have one of those G2 models with hair.
Maybe I could route the displacement call into the bump map
automatically. I will add this to the manual in the export to Poser
tutorial section.
Thank you very much for your feedback.
FlyerX
Date: 16 Jun 2007 16:24:09
Message: <467446e9@news.povray.org>
Since Thomas has started a thread about Poseray, I take the opportunity
to say all the good I think of it. I used it a lot while testing
PovEdge, and really it is *so much* more than a simple format converter !
I am sure than there are many functionnalities I am not aware of, but I
know that:
- It can correct models that have problems, by re-calculating the
normals (very useful in many situations, as bugged model are quite common).
- It can subdivide models. This is unvaluable with low-poly models,
which can then become much more usable.
- It can import PovRay mesh2! This may sound uninteresting for a Povray
user, but it is not. It means that all the great mesh2 models available
in the community can be corrected (if necessary), subdivided, or even
(as output in .obj is also possible) imported in Wings3d, or any other
modeler, to be modified at will ! By the way, as a small feature
request, the parsing of the mesh2 format concerning the textures could
be improved (now it changes the names to Pov_Texture_1, etc. and
changing this back by hand can become tedious when there are many
different textures).
Thibaut
Date: 16 Jun 2007 18:45:59
Message: <46746827@news.povray.org>
> know that:
> Thibaut
Thibaut,
I am glad that you find PoseRay useful. I will look into the texture
naming. It is just a little complicated because a texture may be layered
and that may mangle the names. Besides the meshes may have their own
materials instead (such as PoseRay output) and that complicates matters
further.
FlyerX
Date: 17 Jun 2007 00:40:01
Message: <web.4674ba66d112495dc4e58e10@news.povray.org>
> excellent.
It's often advantagious to import items one at a time. An obj for hair, an
obj for the figure, the poncho, etc. For example, if you are working on the
poncho material in POV-Ray, you can comment out the other objects and it
parses much faster.
I use a method like this:
//Assembled objects ...
#include "BodyVase3_POV_geom.inc" object{BodyVase3_}
#include "V4Head_POV_geom.inc" object{V4Head_}
#include "Hat_POV_geom.inc" object{Hat_}
#include "Flowers_POV_geom.inc" object{Flowers_}
Janet
Date: 17 Jun 2007 03:48:46
Message: <4674e75e$1@news.povray.org>
"FlyerX" <fly### [at] yahoocom> schreef in bericht
news:46741223@news.povray.org...
>> cloth, one may often want to scale down (or up) the bump map in order to
>> obtain the desired effect. In Poser, this is done by changing the U_Scale
>> and V_Scale of the bump image map in the Material Room. However, this
>> scaling is not taken on by Poseray and, to obtain the desired effect, one
>> needs to add manually a scale parameter to the map in the exported
> tab.
Oh! That is nice indeed! I realize that there are many Poseray features that
I have never used yet! Excellent solution.
In a general case, I think that one should always consider the necessities
to edit the model to one's needs.
>> the Material Room for all the used image maps. This has unexpected
>> consequences when using a bump map, even if the used image has
>> traditionally black as background and white as foreground. Poseray
>> translates the bump sizes into negative values which may disconcert at
>> first, but renders correctly in POV-Ray. However, the values are very
>> high (e.g. -20, or -50) for some reason (even if the bump strength in
>> Poser is set to 1.0) and they may have to be changed to more conventional
>> values manually.
> I noticed some inconsistencies between the bump_size implementation using
> different models and whether the bump map was an image or a proprietary
> BUM file.
Yes, this seems to start with Poser 7. It took me a while to realize what
happened. Even so, I am not entirely sure what the role of the background
color is really, only that it matters in the way Poser renders it itself.
Also I became convinced only yesterday of the need for negative bump_size
values to obtain the correct result in POV-Ray.
>> easily translated into POV-Ray code. When using procedural textures in
>> Poser, best is to find an equivalent POV-Ray texture and use that
>> instead.
> textures. This and strand hair are features that makes Poser less portable
Yes, that would be nice. Strand hair in particular would be important, in
the same way as dynamic clothes is.
>> For many reasons G2 hair is more realistic than the conforming hair in
>> Poser 6. However, when exported to POV-Ray through Poseray, the result is
>> rather disappointing. I discovered now why this is so. G2 hair uses a
>> bump map for displacement mapping. Why for displacement is debatable as
>> the hair mesh is fine but not particularly so. Better is to use the map
>> as a bump map. The results are much better. However, there is a problem
>> with G2 conforming hair and Poseray. First, the hair geometry (in the
>> example I used at least) has its morphs centered on the neck body part of
>> the hair figure. In Poseray the neck of the human figure AND the neck of
>> the hair figure are translated into one single mesh geometry group.
>> Second, and as a consequence probably, the displacement map for the hair
>> group is not loaded. While the material maps for the hair are properly
>> loaded, the bump map is not. When adding the proper bump map in Poseray
>> and exporting to POV-Ray, the results are excellent.
> I will look into this since I have one of those G2 models with hair. Maybe
> I could route the displacement call into the bump map automatically. I
> will add this to the manual in the export to Poser tutorial section.
After I sent this post, I found out that the hair object I used for the
comment above is a bit atypical compared to other G2 hair figures (or props
as the case may be). I have not tested all the G2 hair however, and it may
be that for the G2 Jessie for instance, or all the *long* hair, the morph
building is identical. So, the solution might be a bit more complicated...
Well, I thank you very much indeed for a great product that is really
invaluable for crisscrossing amongst applications! That is also one of the
reasons I take the time to stay alert to possible improvements and to note
down what I believe might be worthwhile to the community.
Date: 17 Jun 2007 03:56:07
Message: <4674e917$1@news.povray.org>
"Janet" <par### [at] attnet> schreef in bericht
news:web.4674ba66d112495dc4e58e10@news.povray.org...
>> For
>> 6.
>> for
>> is
>> hair
>> has
>> the
>> into
>> the
>> maps
>> excellent.
> the
> parses much faster.
You are absolutely right, Janet. I have been thinking along this line, but
not used it really just because everything went smooth and fast enough not
to bother yet. However, I am often at the limits where Poser begins to slow
down noticiably because of too many things to manage at the same time. This
is particularly the case with several dynamic simulations applied to the
same figure. So, breaking up the workflow where possible is an excellent
option and easy to reassemble in POV-Ray later on.
Date: 17 Jun 2007 08:02:06
Message: <467522be@news.povray.org>
High!
> the hair should be.
Wow... the first real PoV longhair in about seven years since I read
this group! Awesome... now grow him a Vercingetorix-style Gaul moustache
and send him in full armour to Gergovia (not Alesia, that would be too
cruel...)!
A more practical question: his hair looks as it was partially tied up in
the back - is it so?
But at picture tells me that with PoseRay, a true self portrait would be
  at least theoretically possible...
See you on www.khyberspace.de !
Yadgar
Now playing: The World Spins, I'm Part Of It (China Crisis)
Date: 17 Jun 2007 08:40:36
Message: <46752bc4@news.povray.org>
news:467522be@news.povray.org...
> High!
>> and the hair should be.
> Wow... the first real PoV longhair in about seven years since I read this
> group! Awesome... now grow him a Vercingetorix-style Gaul moustache and
> cruel...)!
There are a couple of long hair figures/props (for males!) available in
Poser. This is one of the latest coming with James G2.
Yes a moustache is indicated indeed  :-)
However, a truly Celtic hairdress would involve limed hair, combed backwards
and up into rigid spikes.
That is true. That is why the morphs are attached to the neck for this
particular hair figure.
Not only theoretically!! Not in Poseray, but in the Poser Face Room, you can
scan in a portrait of yourself and apply that to the figure. You will obtain
a (fairly) correct avatar of yourself. However, from comments I have read in
the Poser forums, this is not as straightforward as it seems...
Date: 17 Jun 2007 15:45:02
Message: <web.46758e53d112495662040f20@news.povray.org>
> know that:
It can? Thanks for pointing it out, I've been trying to import some
Makehuman .obj items in Pov-ray, but they have some serious normal
problems. Guess I'll have to read Poseray's.
