POV-Ray : Newsgroups : povray.binaries.images : question image mapping on shiny ball Server Time
26 Dec 2025 06:33:06 EST (-0500)
  question image mapping on shiny ball (Message 1 to 2 of 2)
Subject: question image mapping on shiny ball
Date: 13 Jan 2007 14:00:24
Message: <45a92c48@news.povray.org>
Hi ,
I'm experimenting with picture map on a ball with mlpov.
using the following texture
texture{
   pigment { color rgb <1,1,1>  }
  finish { ambient 0.007 diffuse 0.05 reflection {
<2.5,1.2,0.1>*minreffac,<0.5,0.5,0.5>*maxreffact*(3)  } }
texture{
         image_map
               gif   "balpic.gif"
               map_type 1
               #declare j=255;
               #while (j<256)
                        filter   j, 1
               #declare j=j+1;
               #end//
         translate <0,1.1,0>
            rotate 100*y
            rotate x*-22
                 scale  0.1
        finish { ambient 0.007 diffuse 2 reflection {
<2.5,1.2,0.1>*minreffac*0.6,<0.5,0.5,0.5>*maxreffact*(2)  } }
When I change scale 0.1 to some other value that only seems to change
the position of the image and not the size of it.
The mapped picture is a transparent canvas with the face pic in the
middle.
 Is it possible to change the size of the mapped face picture without
changing the position?
or should i make the transparent bord of the mapped image bigger in
order to make the face relatively smaller?
Download 'iso-8859-1' (5 KB)
Subject: Re: question image mapping on shiny ball
Date: 13 Jan 2007 17:54:28
Message: <45a96324$1@news.povray.org>
Johan Feyaerts nous apporta ses lumieres en ce 13-01-2007 13:59:
> Hi ,
> texture{
> texture{
>    pigment {
>          image_map
>                gif   "balpic.gif"
>                map_type 1
>                #declare j=255;
>                #while (j<256)
>                         filter   j, 1
>                #declare j=j+1;
>                #end//
>          translate <0,1.1,0>
>             rotate 100*y
>             rotate x*-22
>                  scale  0.1
> The mapped picture is a transparent canvas with the face pic in the middle.
You can use a spherical warp instead of map_type 1. Don't forget to add the
keyword once, otherwise, it will get tilled.
That way, your image is first maped on a plane, starting at <0,0> as the botom
left corner and <1,1> as the top right corner, then, it's wraped around your
sphere. You first translate by -0.5 to center it around the origin, then you
scale as you need and to the correct aspect ratio. This allow you to easily
scale it as you need.
Fighting for peace is like screwing for virginity.
  - public toilet wall, The Bayou, Baton Rouge , LO
