Subject: The Spheres on the Tcheckhardt Plain (WIP) - 2 images
Date: 18 Sep 2006 09:28:20
Message: <450e9ef4@news.povray.org>
Just thought I'd post this for comments and a question.
Question: I intend to place more objects in the scene. One of the spheres
needs to reflect a no_image object and its shadow but I don't want the
shadow showing on the plain surface. Any suggestions would be helpful. I've
also included a close-up of one sphere's surface just to show the
highlight - note the specularity.
John
PS Thomas (De Groot) - I noted your question re: Zeger's Greebles and will
post the modified code just as soon as I can find where and on which machine
I saved it.
"Please refrain from fondling the nymphs and sprites
- it makes them giggly and skittish.
Thank you for your co-operation.
The Management"
Subject: Re: The Spheres on the Tcheckhardt Plain (WIP) - 2 images
Date: 18 Sep 2006 20:35:26
Message: <450f3b4e$1@news.povray.org>
Doctor John nous apporta ses lumieres en ce 18/09/2006 09:33:
> Just thought I'd post this for comments and a question.> > Question: I intend to place more objects in the scene. One of the spheres > needs to reflect a no_image object and its shadow but I don't want the > shadow showing on the plain surface. Any suggestions would be helpful. I've > also included a close-up of one sphere's surface just to show the > highlight - note the specularity.> > John> >
Not tested.
Maybe by making the plain no_reflection no_shadow so that it don't show in the
reflections but shows directly. Then using another plain just below, only
visible in the reflections with double_illuminate. Place a second light_source
under your scene and project_trough a negative light with an inverted copy of
the "ghost" object to make the shadow appears.
The no_shadow for the top surface permit the bottom one to receive the main
light and cast shadows. The gap between the two surfaces must be very small
comparatively to the scene scale.
At the feast of ego everyone leaves hungry.
Bentley's House of Coffee and Tea, Tucson, AZ
Date: 19 Sep 2006 04:23:49
Message: <450fa915$1@news.povray.org>
"Doctor John" <doc### [at] linuxmailorg> schreef in bericht
news:450e9ef4@news.povray.org...
> Just thought I'd post this for comments and a question.>> Question: I intend to place more objects in the scene. One of the spheres > needs to reflect a no_image object and its shadow but I don't want the > shadow showing on the plain surface. Any suggestions would be helpful. > I've also included a close-up of one sphere's surface just to show the > highlight - note the specularity.>
Add no_shadow to the sphere?
>> PS Thomas (De Groot) - I noted your question re: Zeger's Greebles and will > post the modified code just as soon as I can find where and on which > machine I saved it.
Thanks a lot!! That would be great.
Date: 19 Sep 2006 10:51:45
Message: <45100401@news.povray.org>
"Alain" <ele### [at] netscapenet> wrote in message
news:450f3b4e$1@news.povray.org...
> Not tested.> Maybe by making the plain no_reflection no_shadow so that it don't show in > the reflections but shows directly. Then using another plain just below, > only visible in the reflections with double_illuminate. Place a second > light_source under your scene and project_trough a negative light with an > inverted copy of the "ghost" object to make the shadow appears.> The no_shadow for the top surface permit the bottom one to receive the > main light and cast shadows. The gap between the two surfaces must be very > small comparatively to the scene scale.>
Thanks for the use of your brain cells. I will test it tonight
John
The Management"
Date: 19 Sep 2006 10:53:50
Message: <4510047e$1@news.povray.org>
"mine" <nomail@nomail> wrote in message
news:web.450f56d66075a9642cb88adf0@news.povray.org...
> wow, very nice indeed.How do you do the dirt?
The plain surface is of course an isosurface. I'll post the texture and iso
when I have results from Alain's suggestion
John
The Management"
Date: 19 Sep 2006 10:55:10
Message: <451004ce$1@news.povray.org>
"Thomas de Groot" <t.d### [at] internlnet> wrote in message
news:450fa915$1@news.povray.org...
You're welcome :-)
John
The Management"
Date: 20 Sep 2006 10:54:30
Message: <45115626$1@news.povray.org>
Nope, doesn't work - at least not yet. I think you're thinking along the
right lines tho'. I'll keep trying
John
The Management"
Date: 20 Sep 2006 10:55:57
Message: <4511567d$1@news.povray.org>
"Doctor John" <doc### [at] linuxmailorg> wrote in message
news:4510047e$1@news.povray.org...
> "mine" <nomail@nomail> wrote in message> news:web.450f56d66075a9642cb88adf0@news.povray.org...>> wow, very nice indeed.How do you do the dirt?> The plain surface is of course an isosurface. I'll post the texture and > iso> when I have results from Alain's suggestion
...and here it is
John
The Management"
Date: 21 Sep 2006 03:54:47
Message: <45124547@news.povray.org>
news:4511567d$1@news.povray.org...
>> when I have results from Alain's suggestion> ...and here it is>
Where?
