POV-Ray : Newsgroups : povray.binaries.images : Zeger's greebles.inc Server Time
14 Nov 2024 20:26:50 EST (-0500)
  Zeger's greebles.inc (Message 1 to 10 of 10)
Subject: Zeger's greebles.inc
Date: 8 Jun 2006 05:30:05
Message: <4487ee1d@news.povray.org>
Whilst attempting to debug Zeger's greebles.inc I managed to produce the
attached - definitely "under construction". Also attached both pov and
megapov output for unmodified Zeger code
Now for the bit that is likely to provoke a few flames
#declare FLAMEPROOF_UNDERWEAR=true;
First thing to be spotted
#macro RoundPrism(Points,R,H)
    #local Aantal=dimension_size(Points,1);
    #local Tel=0;
    #local Aantal2=Aantal;
    #local Points2=array[Aantal];
-- CUT --
 BLAH
-- CUT --
         #if (Aantal2>2)
            polygon {
                Aantal2,
                #local Tel=0;
                #while (Tel<Aantal)
                    #ifdef(Points2[Tel])
                        <Points2[Tel].x,Points2[Tel].y>
                    #local Tel=Tel+1;
                translate -z*H
    rotate x*90
Surely there's a fencepost error here. If I wish to produce an n-sided
polygon, I need n+1 (Antaal+1) points.
Possibly -
polygon {
       Aantal2,
              #local Tel=0;
                #while (Tel<Aantal+1) //Umm....why are we using Antaal
instead of Antaal2??
                        <Points2[Tel].x,Points2[Tel].y>,
                    #local Tel=Tel+1;
                <Points2[0].x,Points2[0].y>
                translate -z*H
                -would work and prevent the "polygon not closed" warnings
Secondly (and to my eyes this a BIG problem) why is the macro
VerdeelSuperellipsoid calling itself?
#macro
VerdeelSuperellipsoid(Rx,Ry,Rz,n1,n2,F1,F2,B1,B2,Bevel,BevelHeight,StepF,StepB,Diepte)
 #if (Diepte<0)
  #local Scale=BevelHeight*(.5+rand(Seed)*.5);
  SuperEllipsoidSegment(Rx,Ry,Rz,n1,n2,F1,F2,B1,B2,Bevel,Scale,StepF,StepB)
  #ifndef (Detail) #local Detail=5; #end
  SuperEllipsoidGreeble(Rx,Ry,Rz,n1,n2,F1,F2,B1,B2,Bevel,Scale,Detail,StepF,StepB)
 #else
  #local PercentageU=.5+(rand(Seed)-rand(Seed))*.5*.6;
  #local PercentageV=.5+(rand(Seed)-rand(Seed))*.5*.6;
  #local FM=F1+(F2-F1)*PercentageU;
  #local BM=B1+(B2-B1)*PercentageV;
XXXX
VerdeelSuperellipsoid(Rx,Ry,Rz,n1,n2,F1,FM,B1,BM,Bevel,BevelHeight,StepF,StepB,Verlaag(Diepte))
XXXX
VerdeelSuperellipsoid(Rx,Ry,Rz,n1,n2,FM,F2,B1,BM,Bevel,BevelHeight,StepF,StepB,Verlaag(Diepte))
XXXX
VerdeelSuperellipsoid(Rx,Ry,Rz,n1,n2,F1,FM,BM,B2,Bevel,BevelHeight,StepF,StepB,Verlaag(Diepte))
XXXX
VerdeelSuperellipsoid(Rx,Ry,Rz,n1,n2,FM,F2,BM,B2,Bevel,BevelHeight,StepF,StepB,Verlaag(Diepte))
Enlightenment needed.
#declare FLAMEPROOF_UNDERWEAR=false;
John
"Please refrain from fondling the nymphs and sprites - it makes them giggly
and skittish.
Thank you for your co-operation.
The Management"
Download 'greebletest.jpg' (130 KB) Download 'greebletest.txt' (5 KB) Download 'greebletestpov.txt' (4 KB)
Preview of image 'greebletest.jpg'
Subject: Re: Zeger's greebles.inc
Date: 8 Jun 2006 05:35:15
Message: <4487ef53$1@news.povray.org>
Oops, forgot to mention that I produced the image by commenting out that
polygon block in macro RoundPrism
John
and skittish.
The Management"
Date: 8 Jun 2006 08:17:36
Message: <44881560$1@news.povray.org>
"Doctor John" <doc### [at] linuxmailorg> wrote in message
news:4487ee1d@news.povray.org...
the
>     #local Tel=0;
> -- CUT --
>  BLAH
> -- CUT --
>          #if (Aantal2>2)
>             polygon {
>                 Aantal2,
>                 #local Tel=0;
>                 #while (Tel<Aantal)
>                     #end
>                     #local Tel=Tel+1;
>                 #end
>                 translate -z*H
>         #end
>     rotate x*90
> #end
> Possibly -
> polygon {
>        Aantal2,
>               #local Tel=0;
>                     #end
>                     #local Tel=Tel+1;
>                 #end
>                 translate -z*H
warnings
I tend to ignore warnings, but yes, indeed, that would be better :)
but that's not the problem though, POV-Ray just closes the prism for you
if you forget to
> #macro
StepB,Diepte)
>  #if (Diepte<0)
,StepB)
>  #else
> XXXX
> XXXX
> XXXX
> XXXX
>  #end
> #end
because it's a recursive macro, that's the whole idea :)
but, as far as I know, there are no problems with the
superellipsoidal-greebles.
cu!
Date: 8 Jun 2006 09:12:29
Message: <4488223d@news.povray.org>
"Zeger Knaepen" <zeg### [at] povplacecom> wrote in message
news:44881560$1@news.povray.org...
>but that's not the problem though, POV-Ray just closes the prism for you if
>you forget to
True, but you've then got less output to wade through when things don't work
Unfortunately, that's exactly where we seem to be getting problems. As soon
as I comment out the superellipsoid bits in greebletest.pov everything runs
perfectly
I shall carry on trying to figure out exactly where your code produces the
Singular Matrix error (b4 anyone mentions it I already know that MInvers is
a function in matrices.cpp and that it's the only place in the source code
that generates a Singular Matrix error)
BTW Zeger, none of the above is a criticism of you or your coding. I
actually think that the concept is brilliant; I'm just having problems with
the implementation.
John
and skittish.
The Management"
Date: 8 Jun 2006 10:50:13
Message: <44883925@news.povray.org>
Zeger's Greebles, Inc. sounds like a good company name :)
Date: 8 Jun 2006 11:25:00
Message: <web.448840cb6d0cce98c6b359800@news.povray.org>
Zeger's Greebles sounds like a condition or people you might want to avoid,
to me :-)
Date: 8 Jun 2006 11:45:00
Message: <web.448845ce6d0cce988010b7e50@news.povray.org>
> to me :-)
> Stephen
Nah, man - they're fuzzy with cute little noses and they have a children's
TV show on PBS.
-s
5TF!
Date: 8 Jun 2006 13:31:57
Message: <44885f0d@news.povray.org>
soon
runs
> perfectly
hmm, sounds impossible to me...
let's see
hmm, you must be commenting out something else, the only problem I get,
is a "Singular matrix in MInvers" error, always with the polygon in
RoundPrism(..), which has nothing to do with the superellipsoidal
greebles (those are all triangles)
Trust me, the only kind of greebles that will get you that error, are
polygon-greebles (or prism-greebles, which are just combinations of
polygon-greebles :))
the
MInvers is
code
I really think it's just a matter of scale.
Let me try something!
there you go...
in RoundPrism(..), changing
  polygon {
   Aantal2,
   #local Tel=0;
   #while (Tel<Aantal)
    #ifdef(Points2[Tel])<Points2[Tel].x,Points2[Tel].y> #end
    #local Tel=Tel+1;
   translate -z*H
into
  polygon {
   Aantal2,
   #local Tel=0;
   #while (Tel<Aantal)
    #ifdef(Points2[Tel])<Points2[Tel].x,Points2[Tel].y>*100000 #end
    #local Tel=Tel+1;
   scale 1/100000
   translate -z*H
fixes the problem, in this particular case.  Enough proof for me that
the problem is that the points in the polygon are too close together :-/
with
> the implementation.
well, if it works, and it kind of does :), then the implementation
shouldn't matter too much :)
but, it's "opensource" for a reason, of course.  If you know how to do
it faster, or better, then by all means, do so ! :)
what I do, is more or less this:
I recursively subdivide the surface along the U and V directions (or X
and Z for polygons), like this:
Let's say, you have a rectangle going from U=0 to U=1 and V=0 to
V=1.  Now take a random point between <0,0> and <1,1>, for example, a
purely random choice :), <.5,.5>
given this point, you can now make 4 rectangles: <0,0> -> <.5,.5>,
<0,.5> -> <.5,1>, <.5,0> -> <1,.5>, and <.5,.5> -> <1,1>
do the same thing with these 4 rectangles, and you get, if I'm not
mistaken, 16 rectangles, and so on and so on untill you're tired of
subdividing :)
now, draw every one of those sub-rectangles as a beveled prism with a
bevel-width that is, of course, smaller than half the size of the
rectangle, and a random bevel-height.  Those are the greeble-cells.
Every greeble-cell needs to have some greebles, of course, so add up to
5 (or whatever number, I'm going to keep on saying 5 just for the ease
of typing) beveled rectangles that fit insinde the greeble-cell, up to 5
little rounded cylinders (superellipsoids), up to 5 cylinders going
along the U-direction and up to 5 cylinders going along the V-direction.
that's it.  That's the idea with rectangles, but it's the analog with
cylinders or superellipsoid.
cu!
Date: 8 Jun 2006 15:21:29
Message: <448878b9@news.povray.org>
Well, what about "Industrial Light and Greebles inc."? Sounds similar to a
big known company somehow involved with the Star Wars saga...
Best greetings,
Sven
"Ross" <rli### [at] everestkcnet> schrieb im Newsbeitrag
news:44883925@news.povray.org...
Date: 9 Jun 2006 06:00:34
Message: <448946c2$1@news.povray.org>
(((8(|) Doh!!
... also Mea Culpa! Mea Culpa! Mea Maxima Culpa!!
Don't know how I made the mistake (prob. tiredness - see off-topic for
details), it's GreebledRoundPrism or children thats causing the problem. I
still can't see why its causing the Singular Matrix error but a few days
should allow me to find a workaround or even a solution.
Thanx for the extra code - I'll look at it in between World Cup games, work
and moving house.
John
and skittish.
The Management"
