POV-Ray : Newsgroups : povray.binaries.images : WIP Twentieth Century Fox films logo (21st actually) Server Time
11 Oct 2024 04:25:01 EDT (-0400)
  WIP Twentieth Century Fox films logo (21st actually) (Message 1 to 10 of 17)
Subject: WIP Twentieth Century Fox films logo (21st actually)
Date: 25 Feb 2006 13:48:28
Message: <4400a67c@news.povray.org>
I haven't been using POV-Ray much lately, so to get back into the fun I put
this together over the past few days. This image is still a rough draft
while WIP is ongoing. Obvious subject for recreation in POV-Ray with those
searchlights in it.
Started with 20th atop there and made a change to 21st today, mainly because
I'm using artistic license anyway to update the look of the 1935 original--
which itself was updated a little in more recent years but still keeps the
same basic design.
Here's a link to the images I'm using to copy this from.
http://en.wikipedia.org/wiki/20th_Century_Fox
BTW, I searched around for any others made before and only found an sPatch
model (broken link to it), no renderings. Also a 3D Max model. I was fairly
certain someone had posted one here at some point in time, so if any of you
have, I'd love to see it.
Bob H
Download '20th Century Fox logo 1st.jpg' (47 KB)
Preview of image '20th Century Fox logo 1st.jpg'
Subject: Re: WIP Twentieth Century (21st this time)
Date: 25 Feb 2006 13:54:51
Message: <4400a7fb@news.povray.org>
Oh heck! Um, that was the first saved as a jpeg. Confused by the file name.
Okay, here's the 21st century one. You'll notice the changes, no doubt. I
was using cylinder spotlights until I switched over to projected_through and
used regular spotlights that could be placed below the beam exit points.
Bob H
Download '21st Century Fox logo 1st.jpg' (57 KB)
Preview of image '21st Century Fox logo 1st.jpg'
Subject: Re: WIP Twentieth Century Fox films logo (21st actually)
Date: 27 Feb 2006 08:20:01
Message: <web.4402fb318c068e9e143d8c0@news.povray.org>
"Bob Hughes" <omniverse@charter%net> wrote:
> BTW, I searched around for any others made before and ... if any of you
Nathan o'Brien posted the source code of a slightly modified logo back in
1997.
Look at
http://news.povray.org/povray.binaries.scene-files/thread/%3C347540cb.0%40news.povray.org%3E/?ttop=224092&toff=1000
Norbert Kern
Date: 27 Feb 2006 17:42:05
Message: <4403803d$1@news.povray.org>
"Norbert Kern" <nor### [at] t-onlinede> wrote in message
news:web.4402fb318c068e9e143d8c0@news.povray.org...
I didn't search enough then!
> 1997.
> Look at
Thank you Norbert! Wow, almost 9 years ago and I still remembered (or
thought I did) that somebody else had done one of these before. Maybe my
memory isn't as bad as I suspect it to be.
Oh-oh. The zip file is said to be corrupt and his web site isn't there. The
one I found through a google search is just broken links. E-mail address is
there so maybe I could still make contact.
Bob H
Date: 1 Mar 2006 07:06:54
Message: <44058e5e$1@news.povray.org>
I love the clouds a lot, is a problem share the texture?
Thanks,
Paolo
name.
and
> Bob H
Date: 1 Mar 2006 12:54:33
Message: <4405dfd9$1@news.povray.org>
"Paolo Gibellini" <p.g### [at] teinoscom> wrote in message
news:44058e5e$1@news.povray.org...
And I will love to share that, Paolo. Not much to it at all. In fact, it's
probably way too simple for a good rendering. Is a WIP, of course.
I tried to get better cloud colors by using a gradient pattern on a plane
between them and the sunlight so it would look like it gets brighter toward
the horizon. I rendered this part alone before giving it to you and I added
the "air" because it wasn't dark enough without that. The camera needed to
be in this, too, or else it might be trouble to get looking right again.
/* BEGIN */
 location <18,-3.85,-24>
 look_at <4.5,3.5,0>
 angle 40
/* AIR */
box {
 <-25,-5,-10>,<25,20,10>
 hollow
  color rgbt 1
 interior {
  media {
   samples 15
   intervals 8
   scattering {
    1,0.02
    extinction 0.9
light_group {
// sun
light_source {
 150*z, <1.5,1.25,1>/2
 media_interaction on
// cloud color projection trick
plane {
 -z,-140
  function {abs(y)}
  color_map {
   [0 color rgbf <1,0.9,0.8,0.9>]
   [0.2 color rgbf <1.1,1.1,0.1,1.1>]
   [0.4 color rgbf <1.25,0.25,0.1,1.1>]
   [0.6 color rgbf <1.5,0.1,0.25,1.1>]
   [1 color rgbf <0.1,0.1,0.1,0.1>]
 no_image no_reflection
/* CLOUDS */
box {
 <-150,25,0>,<50,30,300>
 hollow
  color rgbt 1
 interior {
  media {
   //method 1
   samples 50
   //intervals 4
   absorption <0.25,0.33,0.67>
   emission <0.3,0.1,0.125>
   scattering {
    1,0.25
    extinction 0.8
   density {
    granite
    density_map {
     [0.67 rgb 0]
     [0.7 rgb 2]
     [1 rgb 3]
    scale <75,50,50>
} // end clouds
} // end light_group
sky_sphere {
  granite
  color_map {
   [0.1 color rgb <0.5,0.7,0.9>*3]
   [0.125 color rgb <0.3,0.5,0.6>*1.5]
   [0.15 color rgbt 1]
  scale 0.025
  function {abs(y)}
  color_map {
   [0 color rgbt <1.4,1.2,0.3,0>]
   [0.1 color rgbt <2,0.75,0.1,0.05>]
   [0.3 color rgbt <0.1,0.3,0.6,0.1>]
   [0.6 color rgbt <0.1,0.2,0.3,1>]
  gradient z
  color_map {
   [0 color rgbt 0.3]
   [0.25 color rgbt 0.9]
   [1 color rgbt 1]
  scale 2 translate -z
/* END */
Date: 2 Mar 2006 14:06:36
Message: <4407423c$1@news.povray.org>
"Bob Hughes" <omniverse@charter%net> wrote in message
news:4403803d$1@news.povray.org...
in
> > 1997.
> > Look at
The
is
I opened the zip using winzip with no problems and the files are readable.
Try the download again. If it fails we can make a plan.
DLM
Date: 2 Mar 2006 16:46:51
Message: <440767cb$1@news.povray.org>
"DLM" <mae### [at] combumbiumdedu> wrote in message
news:4407423c$1@news.povray.org...
I tried it a few times at first and again just now. Same thing. WinXP
complains it's invalid or corrupt, so I used a free zip program that could
do a repair if possible and that also said empty or bad file without any way
to fix it. I was guessing it had something to do with a special kind but
everyone usually uses common enough things for posting to the newsgroups.
If you could send the uncompressed file(s) to omn### [at] charternet I'd
really appreciate that. I could even send my scene file of this 20th Century
Fox WIP back to you if you'd like me to; meager as it is, and unchanged
since I last posted.  ;)
I sent an email to Nathan O'Brien using pov### [at] 13netnet but that got
returned as unknown address. He's probably still around someplace because
his last posting was a couple years ago from what I could find.
Bob H
Date: 2 Mar 2006 18:57:39
Message: <44078673@news.povray.org>
news:440767cb$1@news.povray.org...
>> readable.
Bob,
The files needed a bit of updating as they were written in POV 0.0?
In any event I bullied them into submission and managed a quick render of
Nathan O'Brien's original 1997 work.
Search sources in attached 20Cfox.zip for DLM to spot commented changes.
I have posted sources to p.b.s-f in plain text.
DLM
Download '20Cfox.zip' (7 KB) Download '13a&e.png' (324 KB)
Preview of image '13a&e.png'
Date: 2 Mar 2006 19:37:06
Message: <44078fb2$1@news.povray.org>
>> 1997.
>> Look at
> The one I found through a google search is just broken links. E-mail
> address is there so maybe I could still make contact.
> Bob H
I think you may find a live Nathan O'Brien presence at
http://www.no13.net/
and some fabulous architectural renderings at
http://www.fbe.unsw.edu.au/exhibits/rayshade/church/
DLM
