POV-Ray : Newsgroups : povray.binaries.images : Fire & Ice #2 [~130 KB] Server Time
11 Sep 2025 19:56:46 EDT (-0400)
  Fire & Ice #2 [~130 KB] (Message 1 to 10 of 23)
Subject: Fire & Ice #2 [~130 KB]
Date: 15 Feb 2006 16:59:03
Message: <43f3a427@news.povray.org>
As suggested by a few, I have added a second blue lightsource. Nothing
else has changed - so far. As you can see, it does look quite a bit
better. (Unfortunately, it's still unspeakably suckful... but never mind.)
Download 'candle10+rad.jpg' (121 KB)
Preview of image 'candle10+rad.jpg'
Subject: Re: Fire & Ice #2 [~130 KB]
Date: 15 Feb 2006 17:00:21
Message: <43f3a475$1@news.povray.org>
Having just said that... I did turn off area lights, and the daft "snow"
texture on the candle. Just to speed up the render.
Date: 15 Feb 2006 17:30:07
Message: <opa7v1p0citbgm8lcemsfitos5ol9csiba@4ax.com>
On Wed, 15 Feb 2006 20:59:12 +0000, Orchid XP v2 <voi### [at] devnull>
This is not OT :-)
It is coming along a great improvement
Date: 15 Feb 2006 17:43:33
Message: <43f3ae95$1@news.povray.org>
What I feel now is that the candle is much too powerful for the effect I
guess you want to achieve...
If you want to restrict the light from the flame to the center of the
scene, you could use light fading. Maybe with more red for the light on
the flame as well, so as to gain contrast between your ice and the fire.
Keep working on that one, I think it has a great potential...
Vincent
Date: 15 Feb 2006 17:57:34
Message: <43f3b1de@news.povray.org>
news:43f3a427@news.povray.org...
It's an improvement!
You could give the candle a patterned texture with a spherical pattern
centered on the flame with ambient to fake  subsurface scattering
texture
         spherical
         texture_map
            [0.0     pigment  { you_pigment    }
               finish{ ambient 0 }
            [1.0      pigment  { you_pigment    }
               finish{ambient 1  }
Date: 16 Feb 2006 05:43:23
Message: <43f4574b$1@news.povray.org>
Somehow I like it.
It looks like something is dissolving or growing
right under the "candle". If the transition from
"ground" to "snow" would be more smooth it
would make an interesting surreal image. Though
I'm not sure whether I can see fire an ice.
On the other hand fire dissolves/melts ice so
one could argue.
Sebastian
Date: 16 Feb 2006 08:52:14
Message: <43f4838e$1@news.povray.org>
I was going to say - 'nice lump of poo' ;-)
But the snow texture will most likely make it look better :-)
Tom
Date: 16 Feb 2006 09:36:31
Message: <43f48def@news.povray.org>
"Orchid XP v2" <voi### [at] devnull> wrote in message
Is the background the wood texture? If so, scale it down a lot (0.05 or so)
Or just say it's a marble texture which is what it currently looks like.
A proper flame and a proper snow texture (slightly transparent?) and this
should look very nice.
Date: 16 Feb 2006 09:39:10
Message: <43f48e8e@news.povray.org>
Tone down the brighness of the candle and drop the fade_distance down so
that the blue light shows. Also consider changing the ground texture from
stone to snow. The candle can then look like it's growing out of the
snow-covered ground.
Date: 16 Feb 2006 12:36:44
Message: <43f4b82c$1@news.povray.org>
Orc,
The extra light helps hugely!
The candle will look more like a candle if you remove your placeholder "lamp
post" and put in a flame together with a melted down pool of wax. This will
also allow you to move the light source lower to light up the candle from
inside some more.
Wicks are white - until they have been charred in the flame zone.
DLM
