POV-Ray : Newsgroups : povray.binaries.images : Fire and... wait, what the hell...? [100 KB] Server Time
15 Feb 2026 22:03:20 EST (-0500)
  Fire and... wait, what the hell...? [100 KB] (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Fire and... wait, what the hell...? [100 KB]
Date: 9 Feb 2006 10:44:35
Message: <43eb6363$1@news.povray.org>
Trevor G Quayle wrote:
> If you're interested, I have a macro I made a couple years ago for a candle
> flame as in the attached image.
Nice one - open source? :)
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 9 Feb 2006 13:35:00
Message: <web.43eb8a3cf5fb88c4c8947640@news.povray.org>
> Eero "Aero" Ahonen
>    http://www.zbxt.net
Sure.  It evens contains a macro that attempts to reverse engineer the
turbulence to keep the flame properly postioned when turbulated (doesn't
work too well with turbulence of 1 or more, tends to get stuck and not be
able to find the turbulated point).
Feel free to adjust anything in it.  Don't ask me o explain the mathematics
though, I wrote it a few years ago and have no idea how it works anymore.
#macro Flam (Turb)
  #local R1=seed(2);
  #local OS=rand(R1)*50;
  #local Flam1 = function(x,y,z)
{pow(pow(pow(3*x,2)+pow(0.8*y-0.2,2)+pow(3*z,2),3)+pow(max(1-sqrt(pow(5*x,2)+pow(y+.5,2)+pow(5*z,2)),0),2))}
  #local Flam2 = function(x,y,z)
{floor(pow(sqrt(pow((3.5*x),2)+pow((0.4*y+0.6),2)+pow((3.5*z),2)),2))}
  #local FlamF = function(x,y,z) {min(max(Flam1(x,y,z),Flam2(x,y,z)),1)}
  #macro turb_translate (tTurb,tOcta,tLamb,tOmeg,P0,Acc)
    #local PC=P0;
    #local Dir=<0,0,0>;
    #local V0=vlength(vturbulence(tLamb, tOmeg, tOcta, P0)*tTurb);
    #local Step=V0/2;
    #macro AB(PC,Step,d,Dir,V0)
      #local P1=PC+Step*d;
      #local V1=vlength(P1+vturbulence(tLamb, tOmeg, tOcta, P1)*tTurb-P0);
      #if (V1<V0 | d.x=1)
        #local Dir=d;
        #local V0=V1;
    #while (V0>Acc)
      #local DrP=Dir;
      AB(PC,Step, x,Dir,V0)
      AB(PC,Step,-x,Dir,V0)
      AB(PC,Step, y,Dir,V0)
      AB(PC,Step,-y,Dir,V0)
      AB(PC,Step, z,Dir,V0)
      AB(PC,Step,-z,Dir,V0)
      #if (vlength(DrP+Dir)=0)
        #local Step=Step/2;
      #else
        #local Step=V0/2;
      #local PC=PC+Step*Dir;
    PC
  #local tOcta=7;
  #local tLamb=1.32;
  #local tOmeg=0.135;
  sphere{0 1.1 scale <1/2,1,1/2> translate y*(0.15+OS)
    hollow
    pigment{rgbt <1,1,1,1>}
    interior{
      media{
        emission rgb 0.3
        method 3
        intervals 2
        density{
          function{FlamF(x,y-OS,z)}
          color_map{
            [0.00 rgb <1,1,.5>]
            [0.20 rgb <1,.5,0>]
            [0.60 rgb <1,.1,0>]
            [0.78 rgb <0,0,0>]
            [0.84 rgb <0,0,0>]
            [0.89 rgb <1,0,1>]
            [0.93 rgb <0,0,1>]
            [0.98 rgb <0,1,1>]
            [1.00 rgb <0,0,0>]
          warp{
            turbulence Turb
            octaves tOcta
            lambda tLamb
            omega tOmeg
    no_shadow
    translate turb_translate(Turb,tOcta,tLamb,tOmeg,y*(0.65-OS),0.001)
object{Flam(0.2) scale 10}
-tgq
Date: 9 Feb 2006 16:30:28
Message: <43ebb474@news.povray.org>
> Intriguing image...
> One is not sure what it is at first glance but... yes there is something
> there. I think you should explore this more in detail.
> Where are your wood and marble textures?
That's Not Good(tm)... :-/
> ... oh! the background, or box?
Yeah. The box is supposed to be wood. And the thing the candle stands on
is supposed to be a slab of cold marble.
Date: 9 Feb 2006 16:33:35
Message: <43ebb52f$1@news.povray.org>
> I suggest a change in lighting: a subtle pale blue light from above,
> preferably an area light or even totally shadowless so it doesn't look too
> obvious. This will shift the image away from the monochromatic and, assuming
> your ice is white and everything else is orange, should really help make it
> look like ice and make it stand out from the background.
I tried making the candle flame cyan instead of yellow.
It made the wood look green! :-S
The ice did look slightly more icy though. But only slightly. I think
maybe the ice is just too damn transparent? Or maybe I should put some
scattering media in it or something? (I mean heck, it's only 4 hours a
render at the moment; why not make it 4,000 hours??)
The candle is *supposed* to be composed of snow. But nobody would ever
realise that. It just looks... well, like granite, actually. Or maybe
brass, with all that orange light on it. (Candle flame is orange, wood
is orange, radiosity.....)
I haven't even started on the flame yet. As I see it, I need to fix the
abysmal wood and marble textures, make the ice look more like ice, and
somehow make my snow look like snow.
So, basically, change the entire image, actually... >_<
Date: 9 Feb 2006 23:35:44
Message: <43ec1820@news.povray.org>
"Orchid XP v2" <voi### [at] devnull> wrote in message
news:43ebb52f$1@news.povray.org...
Leave the candle flame orange/yellow and put a fade_distance on it, then a
blue light from above will look very nice. Warm in the center (within range
of the candle) and cool further away
Try these...
#declare M_Ice= // might be suitable, was designed for a frozen lake
 material {
   pigment{rgb <.9,.9,1>}
   normal {bumps 0.02 scale 0.25 turbulence .5}
   finish {specular 0.5 roughness 0.02 diffuse 0.7 ambient 0.3
    reflection { 0 , 0.15 }
    conserve_energy
  interior {
   ior 1.25
   fade_distance 0.002
   fade_power 2
   fade_color rgb <1,1,1>
#declare T_Snow=
   pigment {rgb <0.95,0.95,1>}
   finish {
    ambient 0.25
    diffuse 0.55
    reflection {0,0.2}
    specular 0.6 roughness 0.008
   normal {granite 0.1 scale 0.01}
The textures in woods.inc and stones.in are quite nice, at least as
starting point
As my archery coach is fond of saying Why should you be different from
everyone else? Most of my scenes go through 2-3 complete redesigns before
I'm happy.
Date: 10 Feb 2006 00:05:06
Message: <43ec1f02$1@news.povray.org>
"Gail Shaw" <gshaw AT sentechsa com> wrote in message
news:43ec1820@news.povray.org...
> range
Yeah exactly, you need the orange but it will look more orange if there's a
second light that's at the other end of the spectrum and in a different part
of the scene, lots of nice contrast and varying tone.
Tek
http://evilsuperbrain.com
Date: 10 Feb 2006 14:17:24
Message: <43ece6c4$1@news.povray.org>
The yellow light source inside the flame already has face_distance set.
(And face_power=2.)
Now, here's a question. Should I add a blue *light source*, or just make
the roof of the box bright blue and let radiosity do the rest?
> Try these...
>  material {
>   texture {
>     conserve_energy
>   interior {
>    ior 1.25
>    fade_distance 0.002
>    fade_power 2
> #declare T_Snow=
>   texture {
>    finish {
>     ambient 0.25
>     diffuse 0.55
>     reflection {0,0.2}
Thanks. I'll give 'em a whirl.
> starting point
Um... isn't that defined as cheating?
> I'm happy.
Ah well... we'll see what I can get done over the weekend...
Date: 10 Feb 2006 14:50:51
Message: <43ecee9b@news.povray.org>
news:43ece6c4$1@news.povray.org...
> (And face_power=2.)
What's the fade_distance, what's the colour and how big is the scene?
personally, I'd say scrap the radiosity, but that's because I've never had
much luck with it.
Give it a try both with and without if you have the time.
Pleasure
> > starting point
No, why would it? It's called not reinventing the wheel when it's not
necessary.
Irtc doesn't say that you must create everything yourself, just that you
must give credit for other's work
Do you not use any of the standard pov includes?
Date: 10 Feb 2006 16:55:08
Message: <43ed0bbc$1@news.povray.org>
>>(And face_power=2.)
*checks*
face_distance is 50 cm. (For reference, the candle is 20 cm tall.)
Colour is <0.9, 0.8, 0.5>.
> much luck with it.
Without the radiosity, almost the entire floor is in shaddow and comes
out pure black. (It's shaded by the candle. BTW, *real* candles do this
also. I have *lots* of candles. What can I say? I enjoy burning things.
Erm...)
Of course, if I add another light source...
>>>starting point
> necessary.
I used functions.inc so I could access f_bozo [which is what generates
that bizzare candle] and f_crackle [for the ice crystals]. But no, I
never use anything else.
Date: 11 Feb 2006 04:04:48
Message: <43eda8b0$1@news.povray.org>
Personally I always use radiosity if it doesn't make my renders too slow
(which it usually does!), particularly if I have an enclosed scene like this
where you'd need a lot of lights to fake all the light that should be
bouncing off the walls. I normally use the Radiosity_Fast setting in
rad_def.inc, because it's way too complex to figure out what all the
radiosity settings do.
Tek
news:43ed0bbc$1@news.povray.org...
>>>(And face_power=2.)
> *checks*
>> had
>> much luck with it.
> Without the radiosity, almost the entire floor is in shaddow and comes out
> pure black. (It's shaded by the candle. BTW, *real* candles do this also.
> I have *lots* of candles. What can I say? I enjoy burning things. Erm...)
>>>>starting point
>> necessary.
> that bizzare candle] and f_crackle [for the ice crystals]. But no, I never
> use anything else.
