POV-Ray : Newsgroups : povray.binaries.images : Green photons render Server Time
11 Oct 2024 12:21:04 EDT (-0400)
  Green photons render (Message 1 to 10 of 10)
Subject: Green photons render
Date: 9 Dec 2005 07:00:49
Message: <439971f1@news.povray.org>
Image showing light refraction of inverted lenticular, but
Even though I have color set up white, my transparent material turns green.
I've tried all tehse settings:
   //   rgbft <1,1,1,0.9,0.1>
   //color transmit 1.0
   color red 1.0  green 1.0  blue 1.0  filter 1.0
If I use
 // color rgbt <1.000000, 1.000000, 0.000000, 0.000000>
I get no photons being generated.
Any ideas,
Sorry for newbie question
Download 'lent_test3.JPG' (35 KB)
Preview of image 'lent_test3.JPG'
Subject: Re: Green photons render
Date: 9 Dec 2005 07:50:00
Message: <web.43997cef7988abeee47fda940@news.povray.org>
I think we'll need to see more or your scene file. What photon settings are
you using? What is in the interior{} block of your lenticular object?
What's its dispersion setting?
[In POV 3.5 there was a bug that produced greenish spots if fresnel &
conserve-energy were both used for a transparent object, but it was a
different shade of green]
> If I use
That's just opaque yellow.
What do you mean? That you don't see photon effects, or that POV doesn't
even shoot any photons?
> Any ideas, Sorry for newbie question
Since you're new, my advice is to try playing with the standard glass
textures (in glass.inc) first & modify them to see what happens before
trying to create your own transparent materials.
PS. Your scene is very dark. What's your gamma setting?
Date: 9 Dec 2005 18:28:51
Message: <439a1333@news.povray.org>
The file was exported from 3DWin5 that comes with Rheinhart, from a 3dsMax
file. Quite pleased that I can raytrace models from 3dsmax, but of course
the textures dont come over properly. They are not transparent so I added to
make up the following settings....I'll attach the whole set of files -
that's probably tidier:
I noticed last night that I had no refractive setting on my material, but
that made no difference.
Simon
"PM 2Ring" <nomail@nomail> wrote in message
news:web.43997cef7988abeee47fda940@news.povray.org...
green.
are
> > If I use
Download 'lent_test3_p.inc.txt' (1 KB) Download 'lent_test3_a.inc.txt' (1 KB) Download 'lent_test3_c.inc.txt' (1 KB) Download 'lent_test3_g.inc.txt' (1 KB) Download 'lent_test3_l.inc.txt' (2 KB) Download 'lent_test3_m.inc.txt' (3 KB) Download 'lent_test3_o.inc.txt' (306 KB) Download 'lent_test3.pov.txt' (2 KB)
Date: 10 Dec 2005 08:07:52
Message: <439ad328@news.povray.org>
Getting closer to this problem with a smaller object - it seems the normals
are all messed up - got one image that looks like the ghost in the machine.
Suspecting the converter so , am now trying with the normals exported also
and parts of the sphere are now non coloured, but still some weird green tis
there. See pic 1&2.
"Simon Dyer" <sim### [at] paradisenetnz> wrote in message
news:439a1333@news.povray.org...
to
> Simon
> green.
> are
> > > If I use
Download 'testSphereConcat.JPG' (7 KB) Download 'testSphere-WhyGreen.JPG' (5 KB)
Preview of image 'testSphereConcat.JPG'
Preview of image 'testSphere-WhyGreen.JPG'
Date: 11 Dec 2005 03:56:15
Message: <439be9af@news.povray.org>
I found the problem, or at least the solution, still dont understadn where
the green came from, but I had dispersion on and for some reason my shapes
always dispersed to green.  With dispersion 1.0, the green goes away.  Stil
some eird textures inside my spehere though.
        interior {ior 1.10 dispersion 1.0 dispersion_samples 7}
news:439ad328@news.povray.org...
normals
machine.
tis
> there. See pic 1&2.
3dsMax
course
added
> to
but
> > Simon
> > green.
settings
> > are
> > > > If I use
doesn't
Download 'testSphere.JPG' (11 KB)
Preview of image 'testSphere.JPG'
Date: 11 Dec 2005 10:03:37
Message: <439c3fc9$1@news.povray.org>
Simon Dyer nous apporta ses lumieres en ce 2005-12-11 03:55:
dispersion 1 = NO dispersion
Christian Science #2: Shit happening is all in your mind.
Date: 12 Dec 2005 15:55:00
Message: <web.439de2897988abeed61e8c370@news.povray.org>
Hi Simon,
You ARE seing photons, lots of them. If you delete the photons setting in
the global_settings block (in your file "lent_test3_a.inc") you'll get an
image like this (no_photons.png).
And, perhaps if you use this include file perhaps set:
count 1000000
instead of
space 0.03
That'll reduce the number of photons to 1 Mio and renders much faster. Do
this at least when you're testing.
Your last posting:
I don't know what this test sphere is all about.
To your idea with the normals:
See next post.
Yours,
Bu.
Download 'no_photons.png' (32 KB)
Preview of image 'no_photons.png'
Message: <web.439de2e77988abeed61e8c370@news.povray.org>
Hi again,
To the idea of doing refraction with normals:
I made a test render with a flat box containing a bump_map of an image white
in the middle and black at the edges.
Doing a photon render with this is not really convincing.
See zip file.
Yours,
Bu.
Download 'pho_norm_on.zip' (96 KB)
Date: 12 Dec 2005 22:20:00
Message: <web.439e3cc57988abee43a5e2560@news.povray.org>
Aha!  I think i found something.  I had suspected that dispersion had
something to do with it, and your dispersion 1.0 trial confirms it.
From lent_test3.pov:
> interior {ior 1.10 dispersion 1.2 dispersion_samples 3}
I've noticed that photons don't quite honor the dispersion count; it is as
if the photons undercount the dispersion_samples by 2.  With your
dispersion_samples set at 3, you'll only have one color to work with--the
middle color of the spectrum, *green*.
(I haven't attempted to report this as a bug because it's less painful to
increase dispersion_samples by 2 than to bother the POV Team.)
Also, be careful with your dispersion compared to your ior.  At ior 1.1
dispersion 1.2, if i understand this right (not guaranteed!), the red will
not refract at all.
Date: 13 Dec 2005 20:17:07
Message: <439f7293@news.povray.org>
Cousin Ricky nous apporta ses lumieres en ce 2005-12-12 22:15:
> not refract at all.
You prompted me to do a small test:
	interior{ior 1.2 dispersion 1.5 dispersion_samples 44}
Using a simple prism with rgbt 3 to boost the spectra brightness.
The red does refract a little. If I raise the dispersion to 1.6, the red refract UP
'the' is a registered trademark of Microsoft Corporation
Download 't8.jpg' (2 KB)
Preview of image 't8.jpg'
