POV-Ray : Newsgroups : povray.binaries.images : swimming with the fishies Server Time
23 Feb 2026 04:50:11 EST (-0500)
  swimming with the fishies (Message 1 to 10 of 18)
Subject: swimming with the fishies
Date: 7 Oct 2005 13:47:54
Message: <4346b4ca@news.povray.org>
twenty-something hours render
Download 'sav.20019.jpg' (76 KB)
Preview of image 'sav.20019.jpg'
Subject: Re: swimming with the fishies
Date: 7 Oct 2005 15:01:49
Message: <4346c61d$1@news.povray.org>
news:4346b4ca@news.povray.org...
Sorry can't swim with you, I am salt-forbidden ;-)
Wait! did you model all those fishes? even the big one? didn't it swallow
your mouse?
Great!!!
Marc
Date: 7 Oct 2005 15:20:00
Message: <web.4346c99cdfbececfa0c272b50@news.povray.org>
Wow! It's starting to look very good!  The flash falloff is much better and
the remora is an excellent touch for realism.
Only things that look funny to me now are the normal on the shark's skin is
too pronounced and the water in the background should also have a light
falloff with depth; the bottom of the picture should be a lot darker than
the top, probably a dark blue-green almost black.
Is the water color media? If so, maybe a gradient background behind it or
maybe even negative lights below and behind.
RG
Date: 7 Oct 2005 15:56:16
Message: <4346d2e0@news.povray.org>
Salt-forbidden???
> your mouse?
> Great!!!
> Marc
Thanks Marc.
The shark is modeled entirely in Wings.  So are the remora. The obvious
way to do the fish would have been to model them also in Wings and use
the magnets feature to create and save off a dozen or so swimming
postures then apply them randomly in the fish school.  But alas I took
on the challenge of generating the fishies within SDL.  They are created
in mesh based on splines all derived from a sort of axial backbone
spline which is bent randomly.  A dozen random instances of the fish are
created and stored then instanced randomly.  I also calculated the UV's
and generated a crude template for painting the image and bump maps.
There is also a image pattern map used to get the transparency of the
fins. However the model is still to crude to sustain much of a closeup.
Date: 8 Oct 2005 01:15:52
Message: <43475608$1@news.povray.org>
> They are created
Jim I am doing something amazingly similar with fish and splines right
now (although the project is on hold until school breaks).  You seem to
have been able to write it much faster than I have though.
The render look fantastic!  Your shark could use a bit of wear though.
Most good sized sharks have a few nicks in them.  Stunning nonetheless
though.
Skip
Date: 8 Oct 2005 07:05:01
Message: <web.4347a7a7dfbececf6121e2ac0@news.povray.org>
The shark flesh seems always a bit rigid, probably something to tweak
here...
but it's well done Jim.
> Salt-forbidden???
salt free diet ? (Marc, are you an hypertensive ??)
Date: 8 Oct 2005 09:18:13
Message: <4347c715@news.povray.org>
"Jim Charter" <jrc### [at] msncom> schreef in bericht
Can I go to another swimming pool, please?
Excellent work Jim!
Date: 8 Oct 2005 10:15:36
Message: <4347d488@news.povray.org>
news:web.4347a7a7dfbececf6121e2ac0@news.povray.org...
Yes, doomed to flavourless food :-/
Marc
Date: 8 Oct 2005 10:45:58
Message: <4347dba6$1@news.povray.org>
Thanks Ron.
> too pronounced
I agreed it isn't quite right though I am not quite sure which way to go
with it.  Right now it looks like wet seak skin to me.  It is a bump map
so I can of course reduce the bumo_size.  The texture is created in
Photoshop with custom brushes that I dirived from images of silhouetted
tree branches I believe.  Right now the texture in that strange area of
being closer-than-I've-ever-gotten, but still not "right"  So I cling to
it.  IT's a matter of vision as well as technical I think.
Yes I was playing with some of those effects back when I was
concentrating on the lighting.  It is sort of a matter of balance.
Pictures where you see the media effect have more of an overhead light.
  Pictures with the strob light and severe falloff seem to have a
clearer look with less media and debris coloring the water.  Those
images have more tactility and visual punch it seems to me but loose the
sense of immersion.  I guess I was trying to trade these effects off.
Have it both ways.  Another envisioning issue.  I will have to revisit it.
I was using the gradient at one point but did want to "model" the
lighting in a cleaner way comceptually if I could.  Didn't think of the
negative lights idea
The media is basically this:
sphere {
   hollow
   pigment  {
         rgbt <0,0,0,1>
   finish {
         ambient 0
         diffuse 0
   interior {
      media {
          absorption ...
      media {  //bg color
         scattering { .... extinction ... }
         density {
		granite
		scale .1
		turbulence 1
		color_map { a blend }
      media {  //bg color
         density {
		granite
		scale .5
		turbulence 1.5
      media {   //large debris
         density {
		granite
		scale 5.5
		turbulence .1
		color_map {
			stepped with transparent color
			to get particles
      media {   //pea soup
         density {
		granite
		scale .03125
		turbulence .1
		color_map {
			to get particles
Date: 8 Oct 2005 10:48:16
Message: <4347dc30$1@news.povray.org>
Great Lighting
Very realistic....jaws
