POV-Ray : Newsgroups : povray.binaries.images : Barth Decic Server Time
12 Sep 2025 12:10:30 EDT (-0400)
  Barth Decic (Message 1 to 10 of 12)
Subject: Barth Decic
Date: 29 Sep 2005 08:51:56
Message: <433be36c@news.povray.org>
Thought I'd share this with you all.
IMNSHO it's the best rendering of (part of) the Barth Decic that I've seen
for a while.
For the record:
#declare a=1.0
#declare GM=(sqr(5)+1)/2
#declare GM4=pow(GM, 4)
function(x,y,z,a) {
 8*(pow(x, 2)-GM4*pow(y, 2))*(pow(y, 2)-GM4*pow(z, 2))*(pow(z, 2)-
 GM4*pow(x, 2))*(pow(x, 4)+pow(y, 4)+pow(z, 4)-2*pow(x, 2)*
 pow(y, 2)-2*pow(x, 2)*pow(z, 2)-2*pow(y, 2)*pow(z, 2))+(3+5*GM)
 *pow((pow(x, 2)+pow(y, 2)+pow(z, 2)-pow(a, 2)),2)*pow((pow(x, 2)
 +pow(y, 2)+pow(z, 2)-(2-GM)*pow(a, 2)),2)*pow(a, 2)
max_gradient 25060
contained_by{sphere {0, 1.9}}
...and the texture:
  aoi <3, 1, 3>
  color_map {
   [0 color rgb <1.0,0.4,0.25>]
   [0.8 color rgb <0.15,0.25,0.9>]
 finish {
  ambient 0
  diffuse 0.7
  specular 0.16
Must be rendered using Megapov >=1.1
John
Run Fast
Run Free
Run Linux
Download 'Decic.jpg' (82 KB)
Preview of image 'Decic.jpg'
Subject: Re: Barth Decic
Date: 29 Sep 2005 09:05:44
Message: <433be6a8$1@news.povray.org>
> for a while.
> For the record:
> #declare a=1.0
> function(x,y,z,a) {
> max_gradient 25060
> ...and the texture:
> texture {
>  pigment {
>   aoi <3, 1, 3>
>   color_map {
>  finish {
>   ambient 0
>   diffuse 0.7
>   specular 0.16
> John
Spiny...
On another note... Anybody: Is there a way to duplicate the aoi pattern
w/ the official POV-Ray?
~Mike
Things! Billions of them!
Date: 29 Sep 2005 09:16:30
Message: <433be92e$1@news.povray.org>
"Mike Raiford" <mra### [at] hotmailcom> wrote in message
news:433be6a8$1@news.povray.org...
> Spiny...
> On another note... Anybody: Is there a way to duplicate the aoi pattern w/
Tough, Mike, you gotta get Megapov. It's not difficult to install.
hop over to http://megapov.inetart.net/ and away you go...
btw - make sure you get the latest version (1.2.1 at time of writing)
John
Run Fast
Run Free
Run Linux
Date: 29 Sep 2005 09:18:24
Message: <433be9a0$1@news.povray.org>
>> Spiny...
> John
I have MegaPOV, I'm just looking for an alternative.
~Mike
Date: 29 Sep 2005 20:27:54
Message: <433c868a$1@news.povray.org>
You can fake it with the slope pattern if you're only going to see the
object from one direction (no reflections).
 - Slime
 [ http://www.slimeland.com/ ]
Date: 2 Oct 2005 11:32:47
Message: <433ffd9f$1@news.povray.org>
>> pattern w/ the official POV-Ray?
This works best with small camera angles though. Technically it only works
perfectly with an orthographic camera.
Rune
rune|vision:  http://runevision.com
POV-Ray Ring: http://webring.povray.co.uk
Subject: Re: Barth Decic - Barth SEXTIC
Date: 5 Oct 2005 03:17:26
Message: <43437e06@news.povray.org>
> for a while.
> For the record:
> #declare a=1.0
> function(x,y,z,a) {
> max_gradient 25060
> ...and the texture:
> texture {
>  pigment {
>   aoi <3, 1, 3>
>   color_map {
>  finish {
>   ambient 0
>   diffuse 0.7
>   specular 0.16
> John
Barth's SEXTIC is a surface with 65 double points. It's interesting to
know that 20 of these double points are the vertices of a regular
dodecahedron and 30 other double points are the midpoints of the edges
of another regular dodecahedron. Both dodecahedra have the same center
and the edges are parallel. I have illustrated this property in a small
animated gif.
I used the "poly" representation of the surface and not "function".
More images can be seen here:
http://cage.ugent.be/~hs
Download 'animbarth04d.gif' (443 KB)
Preview of image 'animbarth04d.gif'
Date: 18 Oct 2005 18:37:19
Message: <4355791f$1@news.povray.org>
And the other five?
Anton Sherwood, http://www.ogre.nu/
"How'd ya like to climb this high *without* no mountain?" --Porky Pine
Date: 19 Oct 2005 04:21:03
Message: <435601ef@news.povray.org>
> And the other five?
That's an interesting question, but I can't give the answer. Perhaps
somebody else can help.
As mentioned in a link on my page concerning this surface, Barth's
sextic is a 6th degree surface that has the maximum number of double
points (65) a 6th degree surface can have.
Date: 19 Oct 2005 07:28:32
Message: <vlF4GAA8uiVDFw5x@econym.demon.co.uk>
>> And the other five?
I spent a while trying to imagine how such a symmetric object could have
an extra 5 points that formed any sort of symmetrical pattern, and
became pretty well convinced that it can't happen.
Then I noticed that 65 - 30 - 20 = 15.
However, I still can't find them, and can't think of any symmetrical
patterns of 15 points that don't have a point at the centre.
Mike Williams
Gentleman of Leisure
