POV-Ray : Newsgroups : povray.binaries.images : some asteroids (from Paul Bourke) [122kb JPG] Server Time
4 Aug 2026 00:32:21 EDT (-0400)
  some asteroids (from Paul Bourke) [122kb JPG] (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: some asteroids (from Paul Bourke) [122kb JPG]
Date: 16 Jul 2005 21:13:02
Message: <42d9b09e$1@news.povray.org>
"Steven Pigeon" <ste### [at] videotronca> wrote in message
news:42d974e4$1@news.povray.org...
> I'm sure the shape-data is accurate as can be, but the texture
> looks weird. I would not expect to vary between reddish/bluish
> gray. Maybe more like 6489 Golevka (even though I'm sure it's
> also the same texture), at least, as a global feeling.
Thanks for the comments Steven.
Yes, intermediate-sized ones look better to me too. Eros and Kleopatra have
one more layer of crackle pigment and normal added to them to use two
different sizes of craters. Or at least what is supposed to be craters. I
muted the colors a lot since the first renderings I did. I was trying for
something like the Galileo spacecraft photos of Gaspra and Ida, as seen in
the color pictures at:
http://nssdc.gsfc.nasa.gov/photo_gallery/photogallery-asteroids.html
I think most people think of asteroids as being only grey or a grey-brown,
grey-blue. I'm not sure how realistic any of the photos are of those I've
seen but I still can't get it to look right. I believe all are over-exposed.
Bob Hughes
Date: 17 Jul 2005 03:45:29
Message: <42da0c99@news.povray.org>
Bob Hughes wrote:
Nice texturing.
 > Yeah, I know, they only look vaguely like space rocks. Thought I'd
show how strange they can be if you aren't familiar with them already.
Maybe I'll be able to make better cratered surfaces without resorting to
image/bump maps someday but this isn't the day.
An idea for some Q&D craters
#local S = seed(1234);
#local DensityCurve =
spline {
    0/2 <0,0,0>
    1/2 <.5,.15,0>
    2/2 <1,1,0>
#local PN =
    average
    pigment_map {
       #local I=0;#while(I<256)
           #local ScaleFactor = DensityCurve(rand(S)).y;
           [1
               cylindrical
               scale  .15*ScaleFactor
               #local ScaleFactor =  .5*ScaleFactor;
               poly_wave .8
               pigment_map {
                       [0 rgb   .1]
                       [.1 rgb  10*(1-ScaleFactor)]
                       [.2 rgb -20*(1-ScaleFactor)]
                       [1 rgb  -30*(1-ScaleFactor)]
               rotate <rand(S)*180,rand(S)*180,rand(S)*180>
       #local I=I+1;#end
sphere {
    0, 2
    pigment { rgb .6 }
    normal {
       pigment_pattern {
          average
          pigment_map {
             #local Scl  = 1;
             #local I=0;#while(I<12)
                     [1
                         PN
                         scale Scl
                     #local Scl=Scl*.8;
             #local I=I+1;#end
       bump_size 15
Download 'img.00062.jpg' (38 KB)
Preview of image 'img.00062.jpg'
Date: 17 Jul 2005 05:18:28
Message: <42da2264$1@news.povray.org>
news:42da0c99@news.povray.org...
> Bob Hughes wrote:
> Nice texturing.
Thanks Jim, only a simple layered texture though. It's crackle form
<1.25,0,0.25>, which was just trial and error to get. Here it is, with
different finish statements and lowest layer (minus uppermost layer, too).
  location  <0, 0, -3>
  look_at   <0, 0, 0>
light_source {
 <100,100,-100>, 1
sphere {
  0, 1
    color rgb 0.5
   crackle form <1.25,0,0.25> scallop_wave turbulence 0.1 scale 0.1
   color_map {
    [0 color rgbf <0.7,0.65,0.625,1>]
    [0.3 color rgbf <0.55,0.525,0.5,1>]
    [0.7 color rgbf <0.45,0.5,0.5,1>]
    [1 color rgbf <0.425,0.425,0.45,1>]
  normal {
   crackle -0.7 form <1.25,0,0.25> scallop_wave turbulence 0.1 scale 0.1
  finish {
   specular 0.1 roughness 0.01
   crackle form <1.25,0,0.25> scallop_wave turbulence 0.125 scale 0.033
   color_map {
    [0 color rgbt <0.7,0.65,0.625,0.9>]
    [0.3 color rgbt <0.55,0.525,0.5,0.9>]
    [0.7 color rgbt <0.45,0.5,0.5,0.9>]
    [1 color rgbt <0.425,0.425,0.45,0.9>]
  normal {
   crackle -0.85 form <1.25,0,0.25> scallop_wave turbulence 0.125 scale
0.033
  finish {
I'm looking yours over now, trying to understand it.
Clever thing... although, I am finding it to be very slow to render. Since
you used 'average' I'm trying that with the layered crackle patterns now and
it looks better that way.
Should be able to create an isosurface with real surface variations instead
of faking it with a normal; unfortunately, the asteroid mesh models made
that impossible.
You might want to rethink the "Q&D" and say S&C (slow and clean). Only
joking.
> spline {
>    0/2 <0,0,0>
>    1/2 <.5,.15,0>
>    2/2 <1,1,0>
> #local PN =
> pigment {
>    average
>    pigment_map {
>           [1
>               cylindrical
>               poly_wave .8
>               pigment_map {
>                       [0 rgb   .1]
>       #local I=I+1;#end
> sphere {
>    0, 2
>    pigment { rgb .6 }
>    normal {
>       pigment_pattern {
>          average
>          pigment_map {
>             #local Scl  = 1;
>                     [1
>                         PN
>                         scale Scl
>                     #local Scl=Scl*.8;
>             #local I=I+1;#end
>       bump_size 15
Date: 17 Jul 2005 11:14:36
Message: <42da75dc$1@news.povray.org>
> joking.
LOL!
Yes it is very slow. Agreed.
In the code the, ScalingFactor is just an attempt to produce more little
ones than big ones, and at the same time make the little ones inverse
proportionately deeper.
Defining the pigment beforehand is just an attempt to get around the
limit of 256 terms to be averaged.
Also I think it looks better, or at least closer to your example, with
poly_wave set between 1 and 4.
The crater profile is mostly about the pigment_map of course
Otherwise just a bunch of averaged cylindricals rotated and scaled randomly.
Yes Slow. My example rendered -aa in about 5 minutes.
That you would use the idea or something similar to augment your texture
was what I was thinking.  With a little less random, but rather more
judicious application, you might get faster times and better effects.
Subject: Re: some cratering using your idea [18kb JPG]
Date: 17 Jul 2005 15:05:08
Message: <42daabe4@news.povray.org>
news:42da75dc$1@news.povray.org...
I've tried it with poly_wave 1.8 and I see what you are saying about that.
It isn't slow enough to matter, I guess, if doing mainly a cratered
planetoid anyway. In fact, I've tried it with 50 iterations for the first
loop and 25 for the second and using default AA it was 3 minutes 50 seconds
(on a 2GHz CPU here) to do the attached image.
I changed the average value to be rand(S), too, so it could have old and
young craters mixed together. I'm thinking that to use this appropriately on
irregular shapes, like those asteroids, it might be a good idea to try and
match the surface normal using trace in some way. Something to think about
anyhow, not sure I'll ever get around to it though.
Thanks a bunch for sharing this other way Jim.
Bob Hughes
Download 'jccratersrandomaverage.jpg' (14 KB)
Preview of image 'jccratersrandomaverage.jpg'
Date: 17 Jul 2005 16:10:42
Message: <42dabb42@news.povray.org>
I've always preferred using an inverted granite pattern for a more
natural looking heavily cratered surface, though it doesn't give any
distinct individual craters, so maybe you could combine the two
techniques. Anyway here's a quick example (this is the entire source file!):
//moon
light_source { <-1,1,-1>*1000, rgb 1 }
sphere {
	z*3, 1
	pigment { rgb 1 }
	finish { diffuse 1 ambient 0 }
	normal {
		pigment_pattern { granite } -.2
		accuracy 1/5000
Tek
Bob Hughes wrote:
> "Jim Charter" <jrc### [at] msncom> wrote in message
> Bob Hughes
Download 'moon.jpg' (39 KB)
Preview of image 'moon.jpg'
Date: 17 Jul 2005 23:39:46
Message: <42db2482$1@news.povray.org>
You also have normal data from the original mesh too? Either natively or
as cross products of the verts? Though a shotgun trace would probably be
easier.  Then again maybe use a few normals from the mesh as seeds then
cluster some traces around them?  It also occurred to me that using
local clusters  you could avoid the Venn Diagram looking situations by
somehow creating nested patterns instead of averaged...maybe by writing
to an include file?
Subject: Re: changed cratering [~168kb JPG]
Date: 18 Jul 2005 04:29:27
Message: <42db6867@news.povray.org>
news:42dabb42@news.povray.org...
> I've always preferred using an inverted granite pattern---8<---
> //moon
> sphere {
> z*3, 1
> pigment { rgb 1 }
> normal {
> accuracy 1/5000
Hadn't seen it done that way before.
I did use a small scale negative granite normal on the topmost layer, it
just isn't very obvious. I realize now I overlooked adding a no_bump_scale
keyword to prevent the depth from scaling after applying it to the
asteroids, which were then scaled. Of course that meant readjusting the
normals.
Attaching the changed (rescaled textures) image here.
Download '8asteroids.jpg' (124 KB)
Preview of image '8asteroids.jpg'
Date: 18 Jul 2005 04:32:44
Message: <42db692c@news.povray.org>
news:42db2482$1@news.povray.org...
>> about
> cluster some traces around them?  It also occurred to me that using local
> clusters  you could avoid the Venn Diagram looking situations by somehow
> creating nested patterns instead of averaged...maybe by writing to an
> include file?
You lost me, Jim, you'd know more about meshes than I would. Triangle meshes
aren't something I ever got into, beyond rendering some anyway. I just
thought trace would see the normals on them like it does with other objects.
Date: 18 Jul 2005 10:09:33
Message: <42dbb81d$1@news.povray.org>
>>>about
>>include file?
> Bob
All I meant was that his files contain the vertices for each triangle
which would be enough to approximate the triangle's normal with.  Just
checking now, I see that the files do also contain the normals for each
vertex too.  So the files could be parsed, probably externally, to
either retrieve or calculate some normals info.  As you say though, for
your purposes shooting a trace would be easier and sufficient.
