POV-Ray : Newsgroups : povray.binaries.images : A lamp Server Time
14 Sep 2025 15:02:10 EDT (-0400)
  A lamp (Message 1 to 10 of 18)
Subject: A lamp
Date: 10 Oct 2004 10:49:39
Message: <41694c03@news.povray.org>
Hallo,
I'm trying to model my room in POV-Ray (again ?). I'm still at the beginning, but the
lamp turned out so nice, I thought, I'd share
it.
Manuel
Download 'Lamp.jpg' (91 KB)
Preview of image 'Lamp.jpg'
Subject: Re: A lamp
Date: 10 Oct 2004 13:20:23
Message: <Xns957EC4A63C378raf256com@203.29.75.35>
kas### [at] gmxde news:41694c03@news.povray.org
> beginning, but the lamp turned out so nice, I thought, I'd share it.
Very nice lamp :)
Btw, such scenes always can benefit from lightsources with fade_distance 2
and perhaps exposure (MegaPov)
http://www.raf256.com/3d/
Computer Graphics
Subject: Re: A lamp
Date: 10 Oct 2004 15:56:28
Message: <416993ec@news.povray.org>
> Very nice lamp :)
Thanks.
As far as I understood, fade_power controlls the falloff charactristic (it's set to 2
already) and fade_distance only controls the
brightness? But I could have mixed it up.
Manuel
Subject: Re: A lamp
Date: 11 Oct 2004 04:30:55
Message: <416a44bf@news.povray.org>
416993ec@news.povray.org...
(it's set to 2 already) and fade_distance only controls the
Yes  fade_distance tells to POV at which distance the light has the
intensity given by the color specification of the light
see doc 3.3.7.9  Light Fading
Marc
Subject: Re: A lamp
Date: 11 Oct 2004 09:52:44
Message: <416a902c$1@news.povray.org>
Manuel Kasten wrote:
> Hallo,
> it.
> Manuel
Gosh, that almost looks like mine. Care to share the source for that part?
Subject: Re: A lamp
Date: 11 Oct 2004 13:15:00
Message: <web.416abe782e59f77667c1c3ff0@news.povray.org>
The model is good, but I'm especially impressed by the overall shading.  I'd
really like to take a look at your radiosity/finish/light_source settings
for the concerned elements ;-)  My current #1 project (like, for the next
three years ...) is also a room.
jussi.kantola
Subject: Re: A lamp
Date: 12 Oct 2004 03:02:21
Message: <416b817d$1@news.povray.org>
It's in p.t.s-f .  Have fun!
Subject: Re: A lamp
Date: 12 Oct 2004 03:07:02
Message: <416b8296@news.povray.org>
No problem. But it's nothing special....
You can see the settings for the lamp and light_sources in p.t.s-f .
The ceiling:
    pigment { rgb 1 }
    normal { crackle .2 scale .5}
Radiosity:
    #include "rad_def.inc"
    global_settings {
        radiosity { Rad_Settings(Radiosity_Normal, off, off) recursion_limit 2
brightness 3.0}
        //radiosity { Rad_Settings(Radiosity_Fast, off, off) recursion_limit 2
brightness 3.0}
        //radiosity { Rad_Settings(Radiosity_Debug, off, off) recursion_limit 2
brightness 3.0}
The couloring comes from the environment, its mostly wood. I guess it will change a
lot, once I put my sofa in (it's blue).
Manuel
Subject: Re: A lamp
Date: 12 Oct 2004 05:42:22
Message: <Xns95807715E8EFFraf256com@203.29.75.35>
kas### [at] gmxde news:416b8296@news.povray.org
> recursion_limit 2 brightness 3.0}
Uhm, I'm afraid ushc settings are totaly psychical incorrect - surfaces
diffuse up to x3 times more light then their get.
If You would set higher quality (i.e. recursion_limit 5) probably entire
scene will be totaly white / overlighted, since walls will recive about
3*3*3*3*3 * 1 RGB light
Computer Graphics
Subject: Re: A lamp
Date: 12 Oct 2004 06:31:15
Message: <416bb273$1@news.povray.org>
Remember that Pov-RAY tries not to simulate reality but to produce
(photo)realistic images. There are many limitations that might cause one
to use higher brightness than 1. For example, sometimes it is not
feasible to set the lightsource ambient value more than 1 as it might
get clipped. Then the only way to get enough illumination is to increase
brightness value. Megapov's exposure setting might help with this -
haven't tried it though.
This is all about getting the desired result, not about actual values
being used. You are seriously limiting yourself by allways using just
brightness 1 (and fade_power 2 etc.).
It all depends. Usually increasing the recursion limit beyond a certain
value doesn't affect the result almost at all. When diffuse
inter-reflections are calculated, the intensity gets smaller and smaller
at every iteration (depending on the surface color, diffuse, ambient
etc. values) and finally has no influence on total radiosity value. I
think there aren't many "normal" scenes that look practically any
different with recursion_limit 10 or 20.
Severi
