Hi folks,
I wanted to improve my McIntosh image, mostly the table material and the
tubes filaments light emission.
I had to fiddle with radiosity settings. filaments are just high ambient
textured stacked tori, (20 ,2 per valve, arealights should take forever to
trace and point lights should be unrealistic)
I used save & load radiosity data (as found on Jaime's page
http://www.ignorancia.org/t_tips.php ) with higher ambient for the filaments
during the pretrace
I am still not quite satisfied: lighting by filaments is uneven.
Modeled with Moray with some Luis' DirectCode plugin additions and directly
exported and rendered in Megapov 1.1
A larger version can be found here:
http://marc.jacquier.free.fr/Pics/Stock/Autres/mcintoshhdri4.png
Comments & advices are welcome as usual :-)
Marc
here are my radiosity settings
#declare use_rad=2;
global_settings{
#if (use_rad)
radiosity{
// save settings: modified Outdoor settings from rad_def.inc
#if (use_rad=1)
brightness 1
count 1300
error_bound 1
gray_threshold 0.0
low_error_factor 0.6
minimum_reuse .015
nearest_count 5
recursion_limit 1
adc_bailout 0.05
max_sample -1.0
media off
normal on
always_sample 1
pretrace_start 0.08
pretrace_end 0.02
save_file "rad-save-load.rad"
#else
// load settings
pretrace_start 1 pretrace_end 1
load_file "rad-save-load.rad"
error_bound 1 // it's important to specify the same value used to save
data
recursion_limit 1 // also the same if specified
always_sample off // no more samples: specially useful with focal blur
Download 'mcintoshhdri4_800_600.jpg' (90 KB)
Preview of image 'mcintoshhdri4_800_600.jpg'
Marc Jacquier wrote:
> Hi folks,
> during the pretrace
> Marc
Nice version too. It seem that you remove the bump and changed the
texture of the table...
> Hi folks,
I must say i like the old version better. The wood pattern looks
somewhat strange in this one.
Your comment says it is important to use the same error_bound when
taking and reusing radiosity data - this is not necessarily the case
(and to avoid taking too many additional samples in the final trace it
makes sense to use a higher value there.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Dude, that is too cool...
Subject: Re: McIntosh in the Kitchen new version
Date: 30 Sep 2004 14:58:16
Message: <415c5748@news.povray.org>
I think the same about the wooden tecxture. It will be better to say
"mackintosh in the barn"
The rest is very great as usually with your posts Marc.
news:415bbd67@news.povray.org...
> Hi folks,
to
filaments
> during the pretrace
directly
> Marc
> #declare use_rad=2;
> global_settings{
> #if (use_rad)
> radiosity{
> #if (use_rad=1)
> brightness 1
> count 1300
> error_bound 1
> gray_threshold 0.0
> minimum_reuse .015
> nearest_count 5
> recursion_limit 1
> adc_bailout 0.05
> max_sample -1.0
> media off
> normal on
> always_sample 1
> pretrace_start 0.08
> pretrace_end 0.02
> #else
> // load settings
save
> data
blur
> #end
> #end
Date: 30 Sep 2004 16:07:59
Message: <415c679f@news.povray.org>
Yeah, that's very good. Congratulations!!!!!
Best regards,
Oleguer
news:415c5748@news.povray.org...
de
> > Hi folks,
> to
> filaments
> > during the pretrace
> directly
> > Marc
> > #declare use_rad=2;
> > global_settings{
> > #if (use_rad)
> > radiosity{
> > #if (use_rad=1)
> > brightness 1
> > count 1300
> > error_bound 1
> > gray_threshold 0.0
> > minimum_reuse .015
> > nearest_count 5
> > recursion_limit 1
> > adc_bailout 0.05
> > max_sample -1.0
> > media off
> > normal on
> > always_sample 1
> > pretrace_start 0.08
> > pretrace_end 0.02
> > #else
> > // load settings
> save
> > data
> blur
> > #end
> > #end
Date: 2 Oct 2004 06:40:32
Message: <415e85a0@news.povray.org>
cjgv55$apn$1@chho.imagico.de...
Well I am trying to improve that
Thanks, I still feel dumb in front of radiosity parameters, btw it is not my
comment but Jaime's comment, as I copy/pasted his code and fiddled with
values.
Marc
415c4bc4$1@news.povray.org...
Thank you
Marc
Thank You Remy, I'll change this fuc4!ng table, LOL
Marc
Date: 2 Oct 2004 16:26:42
Message: <415f0f02@news.povray.org>
415bf059$1@news.povray.org...
> Nice version too.
Oh thanks, I missed your post
Yes indeed :)
Marc
