POV-Ray : Newsgroups : povray.binaries.images : Media method 3 + shadow rays Server Time
17 Oct 2024 14:24:25 EDT (-0400)
  Media method 3 + shadow rays (Message 1 to 3 of 3)
Subject: Media method 3 + shadow rays
Date: 1 Sep 2004 11:40:39
Message: <4135ed77$1@news.povray.org>
As I was helping out Josh in povray.general with his "Object Pattern in
Media" question, I noticed a strange behavior with media method 3 and shadow
rays.
This media has the following sample parameters:
   method 3
   intervals 1
   samples 3
   aa_level 20
The intended behavior is that 3 samples should be taken, and then more
samples between them if they differ. This produces a very smooth result as
you can see in the image, with only a few artifacts near the edges of the
density shape.
The strange thing is that the shadow is not smooth. Neither the shadow on
the ground nor the self-shadowing of the media is smooth. It appears that
the recursive sampling is not happening for shadow rays! You can see that
there are only 4 levels of brightness on the ground, probably corresponding
to the amount of the 3 samples which are taken that have density.
Is this intended behavior? Although it may be convenient sometimes for
shadow rays to have less accuracy, there should be a way to specify how
accurate they should be, shouldn't there?
This is the scene code for anyone who wants to try this out themself:
 location  <0, 5, -40>*.8
 look_at   <0, 0,  0>
light_source {<-200, 1000, -400> White}
plane {
 y, -20
 pigment { color rgb <.8,.5,.5> }
#declare myObject = union {
 cylinder {
  <8,0,0>,
  <-8,0,0>,
  3
 sphere {
  <0,0,0>
  ,5
sphere {
 <0,0,0>,
 10
 texture { pigment { Clear } }
 interior {
  media   {
   scattering {1, 0.1}
   method 3
   intervals 1
   samples 3
   aa_level 20
   density {
    pigment_pattern {object {myObject 0, 1}}
    color_map {[0 rgb 0][1 rgb 1]}
 hollow
 - Slime
 [ http://www.slimeland.com/ ]
Download 'temp.jpg' (21 KB)
Preview of image 'temp.jpg'
Subject: Re: Media method 3 + shadow rays
Date: 1 Sep 2004 12:20:02
Message: <4135f6b2$1@news.povray.org>
Slime, I've knocked up a sketch animation, and like a [DELETED] I've gone a
posted it in p.a.,  instead of p.b.a.
Date: 1 Sep 2004 12:56:31
Message: <4135ff3f$1@news.povray.org>
a
Looks cool. You can cancel the message (in outlook express select the
message, go to message -> cancel message) and repost it in p.b.a. Anyone who
comes along after you cancel it won't see it there.
 - Slime
