POV-Ray : Newsgroups : povray.binaries.images : Baking UV textures with POV-Ray Server Time
10 Sep 2025 15:12:49 EDT (-0400)
  Baking UV textures with POV-Ray (Message 1 to 9 of 9)
Subject: Baking UV textures with POV-Ray
Date: 20 Aug 2004 22:14:56
Message: <4126b020@news.povray.org>
See the thread in povray.general ("Can I bake UV textures with Povray?") for
discussion.
There are very slight differences between the two images which aren't very
noticeable. One difference (and the most significant one) is that along the
corners, the UV mapped version has some slight artifacts because it's
sampling from the background area of the UV texture. This would be more
noticable if I had used a lower resolution UV map (the version shown is half
the size of the original 512x512). The other difference is that there is a
very tiny discrepancy in some triangles between where colors in the
procedural texture appear and where colors in the UV texture appear;
probably due to innacuracies in the sampling.
This would be better implemented as a patch, especially because of how
incredibly slow it is (there may be room for some optimization). But in a
pinch it can do the trick.
 - Slime
 [ http://www.slimeland.com/ ]
Download 'uvbaking.png' (152 KB)
Preview of image 'uvbaking.png'
Subject: Re: Baking UV textures with POV-Ray
Date: 20 Aug 2004 23:32:19
Message: <4126c243$1@news.povray.org>
> discussion.
>  - Slime
Well I for one am damned impressed!  You said the UV projection had to
be established first.  How did you do that?  The reason I ask is that I
think the polys would have to have be contiguous in some way if the next
stage in the workflow was to take the template and add more stuff, say
hand-drawn wrinkles, for instance.  That, anyway, is how I imagine this
technique would play a role in a workflow.  I assume by your description
that that could be done.  How you get the original UV's is arbitrary right?
Date: 20 Aug 2004 23:57:00
Message: <4126c80c@news.povray.org>
Thank you! =)
The mesh and UV coordinates were both made with Wings 3D.
right?
Yup. You can generate the UV coordinates any way you want, just as long as
you can get them into your POV-Ray code.
 - Slime
Date: 21 Aug 2004 00:06:26
Message: <4126ca42$1@news.povray.org>
> Thank you! =)
> right?
>  - Slime
This is really significantly useful.  People use it to interactively
locate prcedurally generated bits of texture.  But beyond that it seems
to me that it practically guarantees that the texture would lay flat and
be appropiately scaled since you are working *back* to the pre-existing
uv projection.  This would give us a piece of fuctionality that
characterizes the highend integrated apps.  It also seems to me that if
written as a patch, it would be efficious stand alone.  Once the uvmap
is gained, processing could be shifted to a different patch for any
other functionality needed.
Date: 21 Aug 2004 03:27:09
Message: <4126f94d$1@news.povray.org>
Yes, nice work Slime!  This is not going to slip away as a neat knick knack
macro, but should become a permanent addition to POV-Ray.
Skip
Date: 21 Aug 2004 03:32:53
Message: <4126faa5@news.povray.org>
"Skip Talbot" <Ski### [at] aolcom> schreef in bericht
news:4126f94d$1@news.povray.org...
knack
I fully support that!!
Date: 21 Aug 2004 05:34:07
Message: <4127170f$1@news.povray.org>
news:4126b020@news.povray.org...
The concept looks great! Note that it requires not only pre-existing UVs but
also a completely unwrapped UV-map. It sure would be nice if someone would
turn it into a patch, both for speed and to avoid the creation of
potentially huge arrays in SDL.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 21 Aug 2004 07:05:10
Message: <Xns954C851E8AC94seed7@news.povray.org>
Nice!
Imagine it in combination with the tesselation patch (or the tri-scan
macro).
Ingo
Date: 21 Aug 2004 08:05:06
Message: <41273a72$1@news.povray.org>
for
> discussion.
Sorry, I haven't got time to read that thread now, but the useful thing here
would be to bake the result of raytracing / radiosity. This would save an
enourmous amount of rendering time during animation. (in areas where the
light doesn't change).
Hugo
