![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In the margins of the LOTW projects running here, I try in my own way to
generate interesting landscapes.
I have a question about this isosurface one with a slope/altitude texture.
The bedding plane is vertical. However, I would like to rotate it so that it
shows inclined or even (sub)horizontal bedding. Using rotate doesn't work
(except around the vertical axis). Is that possible?
The relevant code is:
#declare Wrinkling = 1.0; // higher values give sharper features
#declare Wturb = <0.1, 0.5, 0.3>; // turbulence in wrinkles warp
#declare Wscale = <0.1, 0.1, 0.5>; // wrinkling scale
#declare Wrotate = <0, 0, 0>; // wrinkling rotation
#declare P1=function {pattern {wrinkles warp {turbulence Wturb octaves 3
omega 0.5 lambda 1} scale Wscale rotate Wrotate}}
#declare P4=function {f_hetero_mf(x,y,z, 0.8, 2, 5, 0, 0.9, 2) }
#declare P=function { P4(x, 0, z) - P1(x, y, z)*Wrinkling }
isosurface {
function {y - P(x, 1, 1-z)}
//open
max_gradient 10
contained_by {box {<0.5-Xscale*0.5, -2, 0.5-Zscale*0.5>, <0.5+Xscale*0.5,
1, 0.5+Zscale*0.5>}}
translate <-0.5, 0, -0.5>
scale <Loc, 1, Loc>
pigment {Landtex}
//translate -Loc/2*x
Any help is much appreciated!!!
Download 'Geolandscape_02.jpg' (112 KB)
Preview of image 'Geolandscape_02.jpg'
![Geolandscape_02.jpg](/povray.binaries.images/attachment/%3C40f4ee64%40news.povray.org%3E/Geolandscape_02.jpg?ttop=415949&toff=5450&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thomas de Groot wrote:
> [...]Using rotate doesn't work
> isosurface {
What did you expect? The result of P does not depend on the vertical
coordinate.
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Christoph Hormann" <chr### [at] gmx de> schreef in bericht
news:cd2s1c$3fe$1@chho.imagico.de...
> > isosurface {
> coordinate.
Hmm... Consider me as a moron where maths is concerned (very far in the
past, and not a dayly meal). So, please take me by the hand and explain what
I should do. After all I used here the function once provided by Mike
Williams, and I do not pretend to understand exactly what it does...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>>isosurface {
>>coordinate.
Well, of course you can do this but when you rotate the function around
the x or z axis and then evaluate the function in the x-z-plane you will
just rotate the evaluation plane. But P is still constant in vertical
direction. To get a visible effect from a rotation you will need to
evaluate the function in 3D: function {y - P(x,y,z)} (but you probably
will need to adapt the function itself to make it look right).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hey, neat image tho...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:cd3bdj$66i$1@chho.imagico.de...
That makes sense, indeed! <sigh> I think I should dig up those old musty
books, burrowed somewhere in the basement ;-)
Thanks a lot Christoph! You have put me (again) on the right track!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Andrew C on Mozilla" <voi### [at] dev null> schreef in bericht
news:40f587ae$1@news.povray.org...
Thanks Andrew! I liked it a lot too. I probably shall use it somewhere...
Isosurfaces are really addictive!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
