POV-Ray : Newsgroups : povray.binaries.images : Full CRASH!!! BUG!!! Server Time
20 Jun 2026 07:53:16 EDT (-0400)
  Full CRASH!!! BUG!!! (Message 1 to 4 of 4)
Subject: Full CRASH!!! BUG!!!
Date: 6 Jun 2004 07:49:00
Message: <40c304ac@news.povray.org>
A code:
plane {
  y, 0
    pigment { color rgbf <0.2, 0.2, 0.2,0.9> }
     finish { reflection 0.3 diffuse 0.2 specular 0.2}
        normal { cells scale 0.5 }
    normal { hexagon
      normal { agate 3 scale 0.7 }
      normal { cells 3 scale 0.2 }
Subject: Re: Full CRASH!!! BUG!!!
Date: 6 Jun 2004 08:04:20
Message: <40c30844@news.povray.org>
In article <40c304ac@news.povray.org> , "IkA" <ixis.yandex.ru> wrote:
> A code:
What is this about???
    Thorsten
e-mail: tho### [at] trfde
Date: 6 Jun 2004 15:32:50
Message: <40c37162$1@news.povray.org>
IkA nous apporta ses lumieres ainsi en ce 06/06/2004 07:48... :
>A code:
>plane {
>  y, 0
>  texture {
>    normal { hexagon
The problem seems to be the nested normals. Your hexagon normal pattern
contain 2 other normal patterns.
Date: 8 Jun 2004 15:01:37
Message: <40c60d10@news.povray.org>
>> A code:
It took me one second to see that this is a bug report. So people like
Thorsten should figure out in approximately 0.1 seconds :)
The crash is in
  void Post_Tnormal (TNORMAL *Tnormal)  (normal.cpp):
          case NORMAL_TYPE:
-->         Map->Blend_Map_Entries[i].Vals.Tnormal->Flags |=
              (Tnormal->Flags & DONT_SCALE_BUMPS_FLAG);
  with i=2, Map->Number_Of_Entries=3 and ...Tnormal=NULL.
The problem probably begins in express.cpp, Parse_Blend_List(), near
the end (line 2680):
        case NORMAL_TYPE:
          Temp_Ent[i].Vals.Tnormal=Copy_Tnormal(Default_Texture->Tnormal);
          break;
Copy_Tnormal will return NULL because Default_Texture->Tnormal is NULL.
Then, in Post_Tnormal it's a classical NULL pointer deref.
Using if(Map->Blend_Map_Entries[i].Vals.Tnormal!=NULL) in the
case NORMAL_TYPE in Post_Tnormal() will make the test scene trace
successfully but I doubt that this is a good solution.
Instead, using
        case NORMAL_TYPE:
-->       if(!Temp_Ent[i].Vals.Tnormal)  Count=i;
          break;
in Parse_Blend_List(), will also make the crash go away. This, however,
means that Parse_Blend_List() no longer guarantees that the number
of entries is equal to the Count argument.
Just my 10 minute bug analysis (so no warranty for anything)...
Somebody with a bit more clue about that portion of the code should have
a look at this.
Cheers,
Wolfgang
