POV-Ray : Newsgroups : povray.binaries.images : Re: Caustics on a surface under an object - Tim Niklas Server Time
17 Jun 2026 08:47:27 EDT (-0400)
  Re: Caustics on a surface under an object - Tim Niklas (Message 1 to 5 of 5)
Subject: Re: Caustics on a surface under an object - Tim Niklas
Date: 23 May 2004 14:47:06
Message: <40b0f1a8@news.povray.org>
Tim Nikias v2.0 wrote:
>> If I want caustics on a surface BELOW a photon target, must the surface
> that
>> the photon target is on also be a photon target?
>> I have tried many combinations but simply cannot get caustics on a
>> surface "behind" a photon target, even with very small spacings and lots
>> of
> photons
>> - all my photon caustics stay confined to the glass object. I simply
> cannot
>> get caustics onto the table "behind" the glass standing on it.
> Can you provide small, minimal sample scene (post it on
> povray.binaries.scene-files), so that I could have a look at it? You could
> also try to put both objects in a union and shoot photons at the union,
> but that's just a random guess, nothing based on experience or such.
Hi Tim!
Thanks for replying to my post - I think I have at least demystified it for
myself a bit. I made the following test scene:
global_settings
        adc_bailout 0.05
        max_trace_level 10
        photons
                spacing 0.01
                jitter 0.15
                max_trace_level 10
                adc_bailout 0.05
                autostop 0
                radius ,1.75
                //save_file "phottest.pht"
camera
        location <0,0,5>
        look_at <0,2,0>
light_source
        <4,4,5>
        color rgb <1,1,1>*2
        photons
                refraction on
                reflection on
box
        <-1,-1,-1>
        <1,1,1>
        material
                texture
                        pigment
                                color rgb <1,0,0>
        scale <2,2,1>
cylinder
        <-1,-1,-1>,
        <-1,1,2>
        0.25
        material
                texture
                        pigment
                                color rgbft <0,0,1,0.3,0.65>
                        finish
                                diffuse 0.55
                                ambient 0.45
                                specular 0.9
                                roughness 0.2
                                metallic 0.25
                                reflection 0.25
                interior
                        ior 1.3
                        dispersion 1.4
                        dispersion_samples 10
                        caustics 2
        translate <1,0,0>
        photons
                target 0.75
                reflection on
                refraction on
This works ok. However in my scene I am working on (a bit too big to post),
specifying the object like this (I copied exactly the same ior, texture,
and shape) makes it turn absolutely 255,255,255 white - I have one very
distant (1000 units away) light. Specifying "collect off" in the glass
object's statement makes its texture be okay, but I guess THIS is why it
does not leave caustics on the surface it is standing on.
Any idea how I can prevent the photon object being "white out"-ed when I
remove "collect off"? Obviously I am making some mistake and specifying
"collect off" makes the class NOT leave caustics like I want it to.
Thanks!
Stefan Viljoen
Software Support Technician
Polar Design Solutions
Date: 23 May 2004 18:22:02
Message: <40b1240a@news.povray.org>
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
  <meta content="text/html;charset=ISO-8859-1" http-equiv="Content-Type">
  <title></title>
</head>
<body vlink="#551a8b" alink="#ee0000" link="#0000ee" text="#330000"
 bgcolor="#ffffcc">
Stefan Viljoen <rylan@ nous apporta ses lumieres ainsi en ce
2004/05/23 14:45... : <br>
<blockquote cite="mid40b0f1a8@news.povray.org" type="cite">
  <pre wrap="">
global_settings
        adc_bailout 0.05
        //max_trace_level 10 commented out
        photons
                spacing 0.01
                jitter 0.15
                max_trace_level 10
                adc_bailout 0.05
                autostop 0
                radius ,1.75
camera
        location <0,0,5>
        look_at <0,2,0>// -> <0,0,0>
light_source
        <4,4,5>
        color rgb <1,1,1>*2
        photons
                refraction on
                reflection on
box
        <-1,-1,-1>
        <1,1,1>
        material
                texture
                        pigment
                                color rgb <1,0,0>// -> rgb 1
        scale <2,2,1>
cylinder
        <-1,-1,-1>,
        <-1,1,2>
        0.25
        material
                texture
                        pigment
                                color rgbft <0,0,1,0.3,0.65>// -> rgbft
<0.9,0.9,1,0.99,0.0>
                        finish
                                diffuse 0.55//-> 0.1
                                ambient 0.45// -> 0.0
                                specular 0.9
                                roughness 0.2
                                metallic 0.25
                                reflection 0.25
                interior
                        ior 1.3
                        dispersion 1.4
                        dispersion_samples 10// -> 20
                        //caustics 2// you don't need faked caustics
        translate <1,0,0>
        photons
                target 0.75
                reflection on
                refraction on collect off
Thanks!
  </pre>
</blockquote>
Changing the table to white and the "glass" to almost clear does show
both reflection and refraction caustics with strong dispersion.<br>
My changes to the glass are: remove caustics 2, add collect off in th
photons block, recolor to bluish white "rgbft
<0.9,0.9,1,0.99,0.0>" instead of blue, change the ambient to 0
and diffuse to 0.1, increased dispersion_samples to 20.<br>
I also made the "table" white.<br>
Reverted to default Max_trace_level hithout any obvious black spot.<br>
It renders somewhat faster to.<br>
<img height="768" width="1024" alt=""
 src="cid:par### [at] qwertygov"><br>
<br>
Alain<br>
</body>
</html>
Download 'test.png' (217 KB)
Preview of image 'test.png'
Date: 23 May 2004 18:37:55
Message: <40b127c3@news.povray.org>
<html>
<head>
  <title></title>
</head>
<body>
I missed that one: to bright light_source washing things out<br>
Removing the *2 give much beter results.<br>
<blockquote cite="mid40b1240a@news.povray.org" type="cite">
    <pre wrap="">
light_source
        <4,4,5>
     >>>>>>>> color rgb <1,1,1>*2
<<<<<<<<<< change to rgb 1
        photons
                refraction on
                reflection on
    </pre>
  </blockquote>
  <img height="384" width="512" alt=""
</blockquote>
Alain<br>
</body>
</html>
Download 'test.png' (56 KB)
Date: 24 May 2004 06:24:29
Message: <40b1cd5d$1@news.povray.org>
Alain wrote:
 > Content-Type: text/html; charset=us-ascii
Please do not post HTML-posts in these groups. Thanks :)
Florian
Date: 24 May 2004 19:00:22
Message: <40b27e86$1@news.povray.org>
Florian Brucker nous apporta ses lumieres ainsi en ce 2004/05/24 06:29... :
> Florian
I don't have the choice, if I include any image, it's going to be HTML.
I'm not the only one who use HTML posting, it's just that I don't use
"default" white background that make it show.
