POV-Ray : Newsgroups : povray.binaries.images : Sparky (for Dave VanHorn) Server Time
15 Jul 2026 04:18:34 EDT (-0400)
  Sparky (for Dave VanHorn) (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Sparky (for Dave VanHorn)
Date: 20 May 2004 10:42:18
Message: <40acc3ca$1@news.povray.org>
Eh?  Why not use radiosity and v. high ambient?
Tim Cook
Version: 3.12
Date: 20 May 2004 10:55:21
Message: <40acc6d9@news.povray.org>
Mainly because I do a lot of animations and radiosity doesn't work well in
animations. Secondly because I think using lights it's more controllable
Ger
Date: 20 May 2004 10:59:52
Message: <40acc7e7@news.povray.org>
Dave VanHorn wrote:
> Very nice!  I had to scale it to inches, and I think then the translate
> needs to be "Count * Inch" but it looks good. I've put it in a test scene
> with the large discharge spark as you saw, plus 20 switching sparks, which
> I limited to 5 lights since they are small, and not so detailed anyway.
> It's going to be a while, I'll post the image when it's done baking.
Glad you like it. :)
Btw, there is an error in the Spark_Light macro
#local Distance = (End - Start) / NumberOfLights+1;
should be
#local Distance = (End - Start) / (NumberOfLights+1);
I forgot the second set of brackets
Sorry :(
Ger
Date: 20 May 2004 17:02:41
Message: <40AD1CA9.4020108@earthlink.net>
Ger,
I really liked your scene so I rendered it myself but the results were
not as nice as yours. What were your render settings if you don't mind
sharing?
Thanks!
Apollo16
Date: 20 May 2004 17:19:50
Message: <40ad20f6$1@news.povray.org>
> should be
No problem, I see what you mean.
I've made two macros, one for the big spark, and another for the smaller
ones, since I want them to look different, just like real life.
I need to tweak my settings though, it's taking a LONG time to trace.
Date: 20 May 2004 17:26:21
Message: <40ad2269@news.povray.org>
Apollo16 wrote:
> Ger,
> sharing?
> Thanks!
Hi, I don't really know what I changed in that image because I tend to play
around a lot with different options, but the commandline options were:
+W800 +H600 +A0.2
The scene by itself should be the one that is described.
Or can you tell me what is different?
As a teaser here is one with 100 lights to create a very high powered
spark :)
Ger
Download 'sparky-005 (100 lights).jpg' (60 KB)
Preview of image 'sparky-005 (100 lights).jpg'
Date: 20 May 2004 22:59:56
Message: <40ad70ac$1@news.povray.org>
Ger wrote:
> A quick and dirty try to get the spark to emit light.
> I tightened the spark and added a bunch of lights to it.
> The cylinders in the background are just to give an idea about the shadowing
> on the back wall.
> You may have to play with the "Spark_Light" settings to get the effects you
> want.
Nice job!!!
Respectfully,          "Leave it to the coward to make a religion
Dan P            of his cowardice by preaching humility."
                                    - George Bernard Shaw
http://<broken link>
Date: 21 May 2004 00:28:54
Message: <40ad8586@news.povray.org>
It's definitely getting there.
I have to get the lighting amounts roughly right, they are a BIT overdone in
this image.
It does take a LONG time to trace now, even through I cut the main spark
down to 50 lights, and the minor ones to 3 lights.  (BTW: What happens if I
set it to 1 or 2 lights?)
I used to have an area light at 2 illuminating the scene, now it's cranked
down to 0.75 in this scene, and I'm working on minimizing that.
I need to work on the main spark, it's not as complicated as I'd like but I
still want the softer look that I have here. You get a sort of "burning"
look with the longer discharges, as the heated nitrogen rises and cools.
I got tired of the checkered floor.  Interestingly, I was going for a
fractally checkered floor, but this dosen't work:
#declare Floor = object { plane { y, // <X Y Z> unit surface normal, vector
points "away from surface"
                                  0 // distance from the origin in the
direction of the surface normal
                                  photons { target reflection on refraction
off }
                          texture { hexagon
                                    texture {White_Plastic}
                                    texture {Black_Plastic}
                                    texture {hexagon
                                             texture {Red_Plastic}
                                             texture {Green_Plastic}
                                             texture {Blue_Plastic}
                          scale <12 * Inch, 12 * Inch, 12 * Inch>
Download 'marxlight1.JPG' (50 KB)
Preview of image 'marxlight1.JPG'
Date: 21 May 2004 04:30:44
Message: <40adbe30$2@news.povray.org>
> in this image.
> I set it to 1 or 2 lights?)
The very long render time comes from using photons.
If you use just 1 light it will get centered in the spark. Downside to it is
that you get a very sharp shadow. Because the spark is very long it should
give a washed out shadow.
> I still want the softer look that I have here. You get a sort of "burning"
Ger
Date: 21 May 2004 04:31:50
Message: <40adbe76@news.povray.org>
Dan P wrote:
> Nice job!!!
Ger
