POV-Ray : Newsgroups : povray.binaries.images : My LOTW project (145K) Server Time
24 Mar 2026 10:48:56 EDT (-0400)
  My LOTW project (145K) (Message 31 to 40 of 49)
<<< Previous 10 Messages Goto Latest 10 Messages Next 9 Messages >>>
Subject: Re: My LOTW project (145K)
Date: 29 Apr 2004 20:35:32
Message: <40919f54@news.povray.org>
Those fields *rule*, man. Very nice.
-Xplo
Date: 29 Apr 2004 20:48:59
Message: <4091a27b$1@news.povray.org>
Jaime Vives Piqueres wrote:
> Hi all:
> I've started my own "Landscape of the week" project, following the idea
>   and general concepts of the LOTW project by Christoph Hormann. I'm
> really amazed of what he achieved with isosurfaces, so I tried too...
<snip />
Although Christoph's stuff is certainly good, you have raised the bar
with yours: stunning work! Your attention to detail is amazing!!!
Respectfully,
Dan P
http://<broken link>
Date: 29 Apr 2004 20:50:59
Message: <4091a2f3$1@news.povray.org>
Jaime, you are the king.
Respectfully,
Dan P
Date: 29 Apr 2004 20:52:48
Message: <4091a360$1@news.povray.org>
> Mick Hazelgrove wrote:
>> How did you get the foam along the waters edge?
>   Casually, I'm just tweaking this texture. Now I simlified it a bit,
> removing the intersection. The same terrain itself translated a bit is
> enough. There is the relevant part:
<snip />
I
AM
NOT
WORTHY!!!!
Respectfully,
Dan P
Date: 29 Apr 2004 21:03:49
Message: <4091a5f5@news.povray.org>
Were I doing this one, I'd make a really loooooong scene, render it from
successive points, and put it together in a panning movie that goes
around and around. :-)
Very very cool.
Date: 29 Apr 2004 21:29:16
Message: <4091abec@news.povray.org>
I was wowed by this image this morning, but wanted to wait until I got home
(full color monitor) before posting. This is incredible. The little plateau
with the houses definitely raises the bar.
 -Shay
Date: 30 Apr 2004 02:12:52
Message: <4091ee64@news.povray.org>
> stephen parkinson wrote:
>> first thought, where is it? second - photo, third - has the Loch Ness
>> monster moved residence :-)
>   You mean the foam in the middle of the lake? This is a side effect of
> the foam technique... nothing misterious, I hope: I've enough with the
> artifacts! :)
>> some silly questions
>> what is the range of x,y,z in the pic for the iso-surfaces?
>   The container is box{<-200,0,-200>,<200,8,200>}, although the peaks
> rarely reach the "ceil". I tried to keep the scene scale somewhat like
> 1=1km.
>> do you do the iso as <-1,-1,-1> to <1,1,1> and scale ?
>   No, I never scale isosurfaces! I've the superstitious believe that
> scaling them increases render times...
>> how do you do the houses, csg - yes- but what size typically as a
>> standalone object for devel, and then scale by some factor, to fit in,
>> process of emphirical adjustment until it looks right?
>   They are just a bunch of boxes. I scale them randomly to have sizes
> between 5 and 15 metters of side (in the scene scale).
>> please post source or some tantalising snippets to aid understanding ?
>   Wait, I'm still cleaning and commenting it. And the web page for the
> LOTW project must be done too...
> Jaime
interesting
one minor critism, the houses all have shiny white walls facing the
camera, darken it to a sort of mushroom off-white might fit in the scene??
also no windows, just some darker squares would suffice at longer range ?
stephen
Date: 30 Apr 2004 04:36:50
Message: <40921022@news.povray.org>
Christoph Hormann wrote:
> Neat, but must take quite long to parse...
  Not that long really, only 3 minutes. Appart from near the crackle
borders, I also permit the trees to fill sometimes an entire cell, so
this accelerates the rendering and causes the effect of little forests
here and there. I'm just thinking that the same technique can be used
with the houses to create little towns... hmmm... interesting.
> Of course no serious farmer would create such perfect crackle fields.  I
> assume developing an algorithm to automatically generate realistic
> divisions would be quite tricky though.
   :) You know, I expent many time looking at aerial photos of fields to
try to capture the order/chaos there, but the only idea that poped up
was the use of crackle.
   Indeed, I forgot to tell you something I discovered about Skylight
when making this scene (as you are one of the few known users of this
include):
   I finally found why SunColor seemed always too blue, and it was that
ovbious that I feel a bit idiot: Skylight isn't a sunlight model, but a
*sky light* model. Looking for first time at the original abstract
papers that Philippe Debar implemented, I notice that he only
implemented the one for the sky light simulation, so the SunColor
returned it's not the color of the sun, but the color of the sky at the
sun position. I'm using now instead the Blackbody() macro from CIE.inc
for the sunlight color, with variable temperature depending on the
altitude: Blackbody(2000+4500*Al). Of course, I still use the sky dome,
  and the SunColor for the fill lights.
Jaime
Date: 30 Apr 2004 04:55:02
Message: <c6t48q$2b9$1@chho.imagico.de>
That strongly depends on the region and the relief form.  Here in
northern Germany for example you will find a lot of (nearly) rectangular
fields.  In more hilly/mountain regions with more extensive farming a
more crackle-like division might be more common.
You could try http://www.cse.ogi.edu/~jsnow/graphics/pov.html although
this seems to generate a lot of very small areas as well which is not
realistic.
> include):
> *sky light* model. [...]
Well, now that you say it... ;-)
In fact i stopped using the 'correct' color for the light source soon
after i started using the skylight system.  I just need the additional
degree of freedom to design scenes.
Last updated 21 Mar. 2004 _____./\/^>_*_<^\/\.______
Date: 30 Apr 2004 05:12:51
Message: <40921893@news.povray.org>
de news: 409177ef@news.povray.org...
> artifacts! :)
It must be an effect of a shallow, a rise of the terrain underneath.
You could try less turbulence warp in the vertical direction maybe
Marc
