POV-Ray : Newsgroups : povray.binaries.images : Help: Brushed metal: POV Ray 3.1 > 3.5 Server Time
15 Apr 2026 18:42:43 EDT (-0400)
  Help: Brushed metal: POV Ray 3.1 > 3.5 (Message 1 to 10 of 13)
Subject: Help: Brushed metal: POV Ray 3.1 > 3.5
Date: 26 Apr 2004 20:10:44
Message: <408da502@news.povray.org>
Thanks to Dan P's post I was able to create in POV Ray 3.1
a brushed metal that looked very similar to the "before" picture, which I
was entirely happy with. But I have since upgraded to POV Ray 3.5 and the
EXACT same settings produce the horrible mess in the "after" picture. My
normal settings are:
normal {
   granite
   0.1
   scale <0.1, 20, 1>
I've tried changing changing the depth, scale, rotation, bump depth,
accuracy, noise generator, and turbulence but I can't achieve the same
effect in 3.5, what am I doing wrong?
Download '?.jpg' (60 KB)
Preview of image '?.jpg'
Subject: Re: Brushed metal: POV Ray 3.1 > 3.5
Date: 26 Apr 2004 20:25:21
Message: <408da871$1@news.povray.org>
First of all, it doesn't look like the two scenes are the same, lighting,
angle, everythings seems slightly different. Have you tried "no_bump_scale"
yet?
Tim
"Tim Nikias v2.0"
Subject: Re: Help: Brushed metal: POV Ray 3.1 > 3.5
Date: 26 Apr 2004 21:55:19
Message: <408dbd87$1@news.povray.org>
Program ended abnormally on 26/04/2004 18:05, Due to a catastrophic Dustin error:
> normal {
>    granite
>    0.1
>    scale <0.1, 20, 1>
There were changes in the noise generating routines in POV 3.5, try adding:
global_settings{
   noise_generator 1
To your scene to see if it helps.
Date: 26 Apr 2004 21:58:22
Message: <408dbe3e$1@news.povray.org>
> normal {
>    granite
>    0.1
>    scale <0.1, 20, 1>
Looks like the light source is /in/ the object somehow...?
Respectfully,
Dan P
http://<broken link>
Date: 26 Apr 2004 22:08:51
Message: <408dc0aa@news.povray.org>
> "no_bump_scale" yet?
> Regards,
> Tim
They aren't the same, I didn't render the "before" scene, that is from
Dan P's post. I'll post is actual sample from 3.1 and 3.5 (same
settings).
I tried "no_bump_scale" it does not seem to make any difference :(
Download 'difference.jpg' (146 KB)
Preview of image 'difference.jpg'
Date: 26 Apr 2004 22:24:08
Message: <408dc448@news.povray.org>
> adding:
> global_settings{
>    noise_generator 1
Thanks, I tried that, it didn't make a difference.
Date: 26 Apr 2004 22:39:10
Message: <408dc7ce$1@news.povray.org>
>>Regards,
>>Tim
> settings).
DAMN, that is a cool lookin' leg!
Respectfully,
Dan P
Date: 26 Apr 2004 23:26:18
Message: <408dd2da@news.povray.org>
Thanks, I *WAS* happy with how things were turning out until I decided to
upgrade in the middle of the model. Could you post the code to your
'brushed metal scene' example? Maybe I can compare and find out where I am
going wrong...
Date: 27 Apr 2004 01:18:56
Message: <408ded40$1@news.povray.org>
Interesting problem. I've just tried it out comparing 3.5 to Megapov 0.7 (based
on pov 3.1) and I think I have the solution, try this:
 normal {
  pigment_pattern {
   granite
   scale <0.1, 20, 1>
  } 0.1
I've noticed that pov seems to generate bumps by comparing samples of the bump
pattern to estimate a gradient (by sampling a fixed distance away). It would
appear 3.1 evaluates this sample distance after the pattern has been scaled,
whereas 3.5 does it before the scaling. This means if you scale a pattern in 3.5
the bumps will appear to scale, whereas in 3.1 they will alter as they scale
(becoming smoother as you scale down).
In any case using pigment_pattern allows you to manipulate the pattern before
pov samples a normal from it. One trick I use is: normal { pigment_pattern {
granite scale f } 1 scale 1/f }, so that by varying the value of f you control
the severity of the bumps.
Hope that helps
Tek
www.evilsuperbrain.com
"Dustin" <xkx### [at] excitecom> wrote in message news:408da502@news.povray.org...
> normal {
>    granite
>    0.1
>    scale <0.1, 20, 1>
Date: 28 Apr 2004 15:00:53
Message: <408fff65@news.povray.org>
> (based on pov 3.1) and I think I have the solution, try this:
>  normal {
>   pigment_pattern {
>    granite
>    scale <0.1, 20, 1>
>   } 0.1
> bump pattern to estimate a gradient (by sampling a fixed distance away).
> It would appear 3.1 evaluates this sample distance after the pattern has
> been scaled, whereas 3.5 does it before the scaling. This means if you
> scale a pattern in 3.5 the bumps will appear to scale, whereas in 3.1 they
> will alter as they scale (becoming smoother as you scale down).
> before pov samples a normal from it. One trick I use is: normal {
> pigment_pattern { granite scale f } 1 scale 1/f }, so that by varying the
> value of f you control the severity of the bumps.
> Hope that helps
Thanks alot, I think this may work, I am trying to set it up now...
