POV-Ray : Newsgroups : povray.binaries.images : Cavorite Sphere (off the shelf) [~105K JPG] Server Time
18 Oct 2024 10:21:44 EDT (-0400)
  Cavorite Sphere (off the shelf) [~105K JPG] (Message 1 to 10 of 60)
Subject: Cavorite Sphere (off the shelf) [~105K JPG]
Date: 15 Apr 2004 01:57:28
Message: <407e2448@news.povray.org>
Subject line says "off the shelf" because it was first made almost two years
ago and then left to sit idle. Now trying it in the 3.6 beta and making some
texture and environment changes. It will definitely need a realistic Earth
mapped onto that sphere at the horizon.
Getting black areas and specks on it from something, can't figure out why.
The max_trace_level is at a low 9 but there's not much reason for it to be
higher. Wouldn't expect so. In fact, I was finding a really odd black
splotch on the ground plane (other grass earth one) when using radiosity,
however this one doesn't use that. But it does have a isosurface instead of
plane for the ground. This model caused trouble last time I was working with
it too, with the inside apparently leaking through to the outside. Whether
my fault or POVs...? I sure hope to figure that out someday.
Oh yeah, someone might ask what function the Moon surface is made from. It's
a f_ridge() from functions.inc. If anyone wants to ask or say anything, I'll
reply back eventually.
Bob H.
Download 'Cavorite Sphere outside window.jpg' (11 KB) Download 'Cavorite Sphere on Moon.jpg' (67 KB)
Preview of image 'Cavorite Sphere outside window.jpg'
Preview of image 'Cavorite Sphere on Moon.jpg'
Subject: Re: Cavorite Sphere (off the shelf) [~105K JPG]
Date: 15 Apr 2004 19:42:29
Message: <407f1de5@news.povray.org>
Oh YEAH -- fantastic!
It reminds me of Wallace and Grommit.
"Cheese, Grommit! We need cheese! Cheese!!!!"
Another parallel light at low intensity pointing down from behind the
object will bring out the details of the shadow and add depth.
Date: 16 Apr 2004 16:10:28
Message: <40803db4$1@news.povray.org>
"Dan P" <dan### [at] yahoocom> wrote in message
news:407f1de5@news.povray.org...
years
Ha ha! Thanks Daniel, that's a compliment. Someone said that last time I
posted it, IIRC.
Ahh, an oversight. I haven't added a light shining back from the Earth yet!
That might do it. Although, probably not high up enough to illuminate the
upper parts of the CS. There already is a shadowless light directly above
but it's extremely dim. Originally I was never intending to have any other
illumination besides the sunlight, and moon surface diffusing onto it by
using radiosity.
The Earth doesn't really add anything by radiosity alone so I'll add a light
source to it.
Bob H.
Date: 16 Apr 2004 22:34:51
Message: <408097cb$1@news.povray.org>
Hughes, B. nous apporta ses lumieres ainsi en ce 2004/04/16 16:10... :
>years
>posted it, IIRC.
>using radiosity.
>source to it.
>Bob H.
You're on the moon, that mean NO air -> shadows are SUPOSED to be pitch
black. I remember the Apolo lunar expeditions, unless there is something
nearby to reflect light into a shadowed area, there was absolutely
nothing to be seen but black.
The shadowless light must be extremely dim, it represent star's light,
globaly, that's less than about 0.001% that of the sun.
Date: 17 Apr 2004 12:51:56
Message: <cjameshuff-839E8F.12525717042004@news.povray.org>
In article <408097cb$1@news.povray.org>, Alain <aze### [at] qwertygov>
Your argument has actually been used to claim the moon photos were
fake...but it's wrong. There *was* something to reflect the light...the
ground, which happens to be covered in dust which is unusually good at
reflecting light back in the general direction it came from. In most of
the images I've seen, this was quite clear...the surrounding brightly
lit surface would diffuse light onto the shadowing object, which would
diffuse light onto the shadowed part of the surface. The shadowed side
of the object would be fairly well lit, and the ground shadow dimly lit.
Only areas shadowed both from the sun and from the ground were really
dark.
http://www.iangoddard.net/moon01.htm
Starlight would be negligible, even without the atmosphere to block it.
Earthlight could be quite bright at night, however. Think of how bright
nights with full moons can be, and consider that Earth is about 3.67
times as big as the moon. (though the lower albedo will compensate
somewhat)
http://tag.povray.org/
Date: 17 Apr 2004 20:42:20
Message: <4081ceec$1@news.povray.org>
<snip/>
> posted it, IIRC.
Heh! Cool!
> using radiosity.
Sweet.
> source to it.
Right; it's too far away.
Very cool scene!
> Bob H.
Date: 17 Apr 2004 20:43:54
Message: <4081cf4a$1@news.povray.org>
<snip/>
> Alain
Ack, forget accuracy. Did Lucas let the tiny detail that ships can't
bank in space because there's no air stop him? No, man, he said, like,
"It's my freekin' universe and I'll phyisicalize it as I want!" :-)
Dan P
http://<broken link>
Date: 19 Apr 2004 11:25:48
Message: <cjameshuff-D177D8.11265419042004@news.povray.org>
In article <4081ceec$1@news.povray.org>,
> > source to it.
Distance has little to do with it, it is the area of sky covered and
brightness per unit area that counts. The diameter is about 3.6 times
that of the moon, the sky area covered is almost 13.5 times greater. The
moon's albedo is less than Earth's, between 7% and 12% compared to 30%.
(The lunar surface reflects light preferentially in the direction it
came from, so it appears brighter when nearly full.)
This all means that Earthlight is much brighter than moonlight. It's
still very little in comparison to direct sunlight, but it can
contribute to shadowed areas if the viewer's not looking at a bright
object, and will be very significant at night on the near side. And it's
practically all due to radiosity, diffusely scattered sunlight, though
an area light might be more accurate than any but very high radiosity
settings.
Date: 19 Apr 2004 16:15:10
Message: <4084334d@news.povray.org>
>> > light source to it.
Is this true? I mean, in POV world, doesn't distance really matter when
computing radiosity?
> settings.
Yes. When the moon is very thin, you can clearly see the dark side lit by
"earthlight". Even in a Moon eclipse, when all the moon is in shadow, and
the earth face it sees is at night, the Moon is notably lit with a red
glow, which comes from scattering in the Earth's atmosphere (all the dawns
and twilights).
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 19 Apr 2004 17:59:56
Message: <cjameshuff-7DE24C.18010219042004@news.povray.org>
In article <4084334d@news.povray.org>, Jellby <jel### [at] M-yahoocom>
As far as I know, it does so only when it comes to selecting previously
taken samples to interpolate...you want to use samples taken from
nearby, and probably reduce the importance of samples from more distant
points. I don't know in detail how POV-Ray's radiosity algorithm works,
though.
