POV-Ray : Newsgroups : povray.binaries.images : scanned blobs Server Time
12 May 2026 05:26:29 EDT (-0400)
  scanned blobs (Message 1 to 6 of 6)
Subject: scanned blobs
Date: 12 Apr 2004 10:53:00
Message: <407aad4c@news.povray.org>
3-light system used, probably incorrectly tho.
Download 'scan_3_lights.png' (153 KB)
Preview of image 'scan_3_lights.png'
Subject: Re: scanned blobs
Date: 12 Apr 2004 12:46:44
Message: <407ac7f4$1@news.povray.org>
Not so bad. :-)
For some reason, the position for the back light that is given in
tutorials does not quite work in my scenes, it seems I'm not the only
lit areas that will let you see the shape of your spheres better.
Try to render your image with only one of the three lights (trying with
key, fill and back) and you'll see better what happens and which brings
what.
How many spheres do you have in this render ?
JC
http://exether.free.fr/irtc (more IRTC stats !)
Date: 12 Apr 2004 16:14:34
Message: <407af8aa$1@news.povray.org>
"JC (Exether)" <no### [at] spamfr> wrote in message
news:407ac7f4$1@news.povray.org...
> Not so bad. :-)
If I understand correctly, the angular relationship between the key and
backlight is already at 135 degrees (viewed down the y-axis), since the key
light is 45 degrees off  to the left and the backlight is behind the
subject. It might help if I position the lights by putting them at a
standard position and rotating them around the subject instead of my rather
rough positioning by offsets.
> what.
The key light is certainly key. I've set it up so I have a test render of
the target object available, and the other 2 lights provide little light,
but more than the recommended light mind - I thought that they needed more
of a presence.
Durn, you've made me re-parse this monster to find out: There are ... mmm,
POV-Ray does not say how many blob components there are!
> JC
Date: 12 Apr 2004 16:28:42
Message: <407afbfa@news.povray.org>
>>Not so bad. :-)
with the >camera<, you should turn it around so that it lights the right
part of the object. It would be easier working with angles, but you can
set it up with offsets too. I posted the source of the menger sponge in
p.t.scene-files on 18/08/2003 if you want to have a look at the 3 lights
code.
>>what.
> of a presence.
Back light should provide as much light as the key light, because it's
in the back it won't provide too much light.
Sorry, I was just beeing curious as your algorithm provides a lot of
spheres for the outside, but fewer for the inside, so I thought the
result might be interesting. You can use #debug traces to know.
JC
Date: 12 Apr 2004 17:40:31
Message: <407b0ccf$1@news.povray.org>
news:407afbfa@news.povray.org...
> >>Not so bad. :-)
key
rather
> code.
http://www.mavart.com/art-film-three-point.html
is just one of a number of sites that give yet another slight variation in
the rules.
This one agrees with my original interpretation that the back light is 180
degrees to the camera, behind the subject.
> >>what.
of
light,
more
> > of a presence.
The site above indicates a smaller light (than the key light) is to be used.
Blimey. Well I suppose it's not a bad thing not to lay down hard and fast
rules for first-time lighting technicians etc.
mmm,
I think that's probably for the future. I'm gurding up my parts to work on
something that can produce DXF output.
> JC
Date: 13 Apr 2004 01:09:13
Message: <407b75f9$1@news.povray.org>
>>>>Not so bad. :-)
> key
> rather
>>code.
> the rules.
>>>>what.
> of
> light,
> more
>>>of a presence.
I didn't get my best results by sticking to the rules and you're right
that my setting are not quite academic. But well, that's what worked on
my scene. :-)
JC
