Anyone got any ideas what might be causing the unpleasant
black speckling on the stonework?
It seems to be keyed to the texture but only occurs with
radiosity turned on and conventional lighting off.
radiosity {
Rad_Settings(Radiosity_OutdoorLQ, true, false)
recursion_limit 2
rendered without aa.
Bill Hails
Download 'artefacts.jpg' (8 KB)
Preview of image 'artefacts.jpg'
Doesn't look like a radiosity error. Looks more like the kind of error you get
with ray-intersection problems, e.g. coincedent surfaces or innaccuracies in
isosurfaces/blobs, etc. Can you render a higher resolution close-up?
Tek
www.evilsuperbrain.com
"Bill Hails" <bil### [at] europeyahoo-inccom> wrote in message
news:4078fc07@news.povray.org...
> radiosity {
> recursion_limit 2
> Bill Hails
Bill, what is that shape made from? Is it a height_field? CSG?
If it's a height_field, I've had the same kind of artifacts even without
radiosity. Try removing the 'smooth' keyword. I don't know if that will
help or not, but it's worth a try.
If it's CSG, it might be a problem with coincident surfaces. Try
translating one object just slightly. I can't see it being that, though.
Hope that helps~
-Samuel Benge
> get with ray-intersection problems, e.g. coincedent surfaces or
> innaccuracies in isosurfaces/blobs, etc. Can you render a higher
Yeah, you were right, it was just a coincident surface. Sorry to post
such a dumb question without investigating further myself :-(
I now think there may be a few more of them to eliminate.
Bill Hails
Thanks, It's CSG, and the problem was just a coincident surface.
Sorry for wasting peoples time :-(
> Hope that helps~
> -Samuel Benge
Bill Hails
