POV-Ray : Newsgroups : povray.binaries.images : sphere sphere sphere Server Time
15 Apr 2026 22:01:54 EDT (-0400)
  sphere sphere sphere (Message 1 to 6 of 6)
Subject: sphere sphere sphere
Date: 9 Apr 2004 14:35:35
Message: <4076ecf7@news.povray.org>
A sphere octree-traversed into spheres that were octree-traversed into
spheres.
Download 'sphere_sphere_sphere.png' (114 KB)
Preview of image 'sphere_sphere_sphere.png'
Subject: Re: sphere sphere sphere
Date: 9 Apr 2004 15:56:07
Message: <4076ffd7@news.povray.org>
"IMBJR" <no### [at] spamhere> wrote in message
news:4076ecf7@news.povray.org...
into
> spheres.
     Whoah! Now yer talkin' kid! That's nice, I like that. Explain
'Octree-Traversed' please.
      ~Steve~
Date: 9 Apr 2004 16:44:51
Message: <40770b43$1@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:4076ffd7@news.povray.org...
> into
> > spheres.
Basically, in this piece a sphere's containing box has been split into 8
equal sub-boxes. Those boxes have in turn been split into 8 equal sub-boxes
... and so on. After a certain level is reached, inside/outside object
checks are made against the original sphere using the corners of the
attained sub-boxes as reference points. The results are passed upwards
through the recursive calls and analysed. The aim is to discover the largest
sub-box regions at a given level that are wholly contained within the
original sphere (boy, that sentence was not easy to write and I still don't
think it explains it properly).
In this case those largest sub-box regions are then used to create new
spheres which are then subjected to the same sub-division procedure,
resulting in yet more spheres which, this time, are used in the scene
proper.
I had a version of this going down to level 6, but after 4 hours of parsing
I gave up. The machine I'm currently using does not have much muscle.
>       ~Steve~
Date: 9 Apr 2004 17:20:07
Message: <40771387$1@news.povray.org>
Interesting idea and algorithm, might prove usefull for doing abstracts.
Interesting texture too.
JC
> spheres.
http://exether.free.fr/irtc (more IRTC stats !)
Date: 9 Apr 2004 17:58:11
Message: <40771c73$1@news.povray.org>
-[I had a version of this going down to level 6, but after 4 hours of
parsing I gave up]-
Have you considered writing a program in another language, and exporting
pov-ray code? This might improve things a bit on the speed front.
Which "level" is the image attached at? If I understand you correctly, its
level 2? If so, six levels of recursion would create a massive number of
spheres - about 30^6 = 730,000,000, if you keep the current "resolution" of
about 30 smaller spheres making up one big sphere. It should be OK with
level 3 (27,000 spheres) though.
-Chris
Date: 9 Apr 2004 18:23:09
Message: <4077224d@news.povray.org>
"Chris Johnson" <chris(at)chris-j(dot)co(dot)uk> wrote in message
news:40771c73$1@news.povray.org...
> parsing I gave up]-
It probably would, but I've not got the resources to do that.
of
Level 4, which creates 1034 spheres. Remember, each sphere is not
necessarily created at the lowest level. If a sphere can fit into the master
sphere at level 1 then it will be created within the scene; plus, after each
sphere is determined it too is then octree-traversed at level 4.
Here's the code. You will probably find that it's quite inefficient. I've
probably not got the knack for writing good POV code for this sort of thing:
-- code begins:
#version 3.5;
#include "transforms.inc"
global_settings {
  assumed_gamma 1.0
  max_trace_level 100
#include "rad_def.inc"
global_settings {
  radiosity {
    Rad_Settings(Radiosity_OutdoorLQ, off, on) // Radiosity_OutdoorLight
// Constants
// Split ratios
#declare xsr = 0.5;
#declare ysr = 0.5;
#declare zsr = 0.5;
// Level of detail of scan
#declare level_limit = 4; //4;
// Offset from edges of emitted area
#declare os = 0.5;
// Basic scene
  location  <0.0, 0.0, -550.0>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <0, 0, -300>
background {
 color rgb <0.7,0.7,1>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb 0.1]
      [0.7 rgb 0]
#declare target_object =
sphere {
 <0,0,0>, 100
#macro all_inside_check(p1, p2, p3, p4, p5, p6, p7, p8)
#if (
  (p1 = 1) &
  (p2 = 1) &
  (p3 = 1) &
  (p4 = 1) &
  (p5 = 1) &
  (p6 = 1) &
  (p7 = 1) &
  (p8 = 1)
 #declare all_inside = true;
#else
 #declare all_inside = false;
#macro emit(near_corner, far_corner)
#local fore_left_bottom_inside = inside(scan_object,
            near_corner);
#local fore_right_bottom_inside = inside(scan_object,
            <far_corner.x,
             near_corner.y,
             near_corner.z>);
#local fore_left_top_inside  = inside(scan_object,
            <near_corner.x,
             far_corner.y,
             near_corner.z>);
#local fore_right_top_inside = inside(scan_object,
            <far_corner.x,
             far_corner.y,
             near_corner.z>);
#local rear_left_bottom_inside = inside(scan_object,
            <near_corner.x,
             near_corner.y,
             far_corner.z>);
#local rear_right_bottom_inside = inside(scan_object,
            <far_corner.x,
             near_corner.y,
             far_corner.z>);
#local rear_left_top_inside  = inside(scan_object,
            <near_corner.x,
             far_corner.y,
             far_corner.z>);
#local rear_right_top_inside = inside(scan_object,
            far_corner);
all_inside_check(
     fore_left_bottom_inside,
     fore_right_bottom_inside,
     fore_left_top_inside,
     fore_right_top_inside,
     rear_left_bottom_inside,
     rear_right_bottom_inside,
     rear_left_top_inside,
     rear_right_top_inside,
#if (all_inside = true)
 #local bright =
     color rgb 1
    finish {
     diffuse 1
     ambient 0.75
 #local dark =
     color rgb 1
    finish {
     diffuse 0.5
     ambient 0.25
 #local emit_object =
  sphere {
   (near_corner+far_corner)/2, dx/3
    slope y
    texture_map {
     [0 bright]
     [1 dark]
  #if (final_emit = on)
   object{emit_object}
 #else
  scan_3d(
   emit_object,
   min_extent(emit_object)-2,
   max_extent(emit_object)+2,
   1,on)
#macro emit_control()
#local emitted = off;
// Disimilars get emitted if they have not already been so:
#if (fore_left_bottom_data[1] = 0)
 emit(near_corner,
   near_corner+cv)
 #local emitted = on;
#if (fore_right_bottom_data[1] = 0)
 emit(<near_corner.x+cx, near_corner.y, near_corner.z>,
   <far_corner.x, near_corner.y+cy, near_corner.z+cz>)
#if (fore_left_top_data[1] = 0)
 emit(<near_corner.x, near_corner.y+cy, near_corner.z>,
   <near_corner.x+cx, far_corner.y, near_corner.z+cz>)
#if (fore_right_top_data[1] = 0)
 emit(<near_corner.x+cx, near_corner.y+cy, near_corner.z>,
   <far_corner.x, far_corner.y, near_corner.z+cz>)
#if (rear_left_bottom_data[1] = 0)
 emit(<near_corner.x, near_corner.y, near_corner.z+cz>,
   <near_corner.x+cx, near_corner.y+cy, far_corner.z>)
#if (rear_right_bottom_data[1] = 0)
 emit(<near_corner.x+cx, near_corner.y, near_corner.z+cz>,
   <far_corner.x, near_corner.y+cy, far_corner.z>)
#if (rear_left_top_data[1] = 0)
 emit(<near_corner.x, near_corner.y+cy, near_corner.z+cz>,
   <near_corner.x+cx, far_corner.y, far_corner.z>)
#if (rear_right_top_data[1] = 0)
 emit(near_corner+cv,
   far_corner)
// Decide on return data
#if (emitted = on)
 #declare return_data = array [2] {fore_left_bottom_data[0],1};
#else
 #declare return_data = array [2] {fore_left_bottom_data[0],0};
#macro scan_3d(scan_object,near_corner,far_corner,level,final_emit)
// Get locations etc.
#local dx = abs(far_corner.x - near_corner.x);
#local dy = abs(far_corner.y - near_corner.y);
#local dz = abs(far_corner.z - near_corner.z);
#local cx = dx*xsr;
#local cy = dy*ysr;
#local cz = dz*zsr;
#local cv = <cx,cy,cz>;
#if (level < level_limit) // Further downwards scanning?
 // fore left bottom
   near_corner,
   near_corner+cv,
   level+1,final_emit)
 #local fore_left_bottom_data = return_data;
 // fore right bottom
   <far_corner.x, near_corner.y+cy, near_corner.z+cz>,
   level+1,final_emit)
 #local fore_right_bottom_data = return_data;
 // fore left top
   <near_corner.x+cx, far_corner.y, near_corner.z+cz>,
   level+1,final_emit)
 #local fore_left_top_data = return_data;
 // fore right top
   <far_corner.x, far_corner.y, near_corner.z+cz>,
   level+1,final_emit)
 #local fore_right_top_data = return_data;
 // rear left bottom
   <near_corner.x+cx, near_corner.y+cy, far_corner.z>,
   level+1,final_emit)
 #local rear_left_bottom_data = return_data;
 // rear right bottom
   <far_corner.x, near_corner.y+cy, far_corner.z>,
   level+1,final_emit)
 #local rear_right_bottom_data = return_data;
 // rear left top
   <near_corner.x+cx, far_corner.y, far_corner.z>,
   level+1,final_emit)
 #local rear_left_top_data = return_data;
 // rear right top
   near_corner+cv,
   far_corner,
   level+1,final_emit)
 #local rear_right_top_data = return_data;
 // Are all of the point sampled inside the target object?
 all_inside_check(fore_left_bottom_data[0],
      fore_right_bottom_data[0],
      fore_left_top_data[0],
      fore_right_top_data[0],
      rear_left_bottom_data[0],
      rear_right_bottom_data[0],
      rear_left_top_data[0],
      rear_right_top_data[0]
 // All inside?
  // No "children" emitted?
  #if (
    (fore_left_bottom_data[1] = 0) &
    (fore_right_bottom_data[1] = 0) &
    (fore_left_top_data[1]  = 0) &
    (fore_right_top_data[1]  = 0) &
    (rear_left_bottom_data[1] = 0) &
    (rear_right_bottom_data[1] = 0) &
    (rear_left_top_data[1]  = 0) &
   #declare return_data = array[2] {fore_left_bottom_data[1], 0}
  #else // Some emitted, check others
   emit_control()
  #end // Children emitted check
 #else // Not all inside
  emit_control()
 #end // all_inside check
#else // No, get raw data
            near_corner);
          0 // Not emitted
#end // End of level check
#end // End of macro
fog {
  fog_type   2
  distance   20 //10
  color      rgb 0.5
  fog_offset 0.1
  fog_alt    0.2
  turbulence 0.8
plane {
 y, 0
   color rgb 0.5
  finish {
   diffuse 1
   ambient 0
#declare final = union {
scan_3d(
 target_object,
 min_extent(target_object)-15,
 max_extent(target_object)+15,
 1,off)
#declare ye = max_extent(final).y-min_extent(final).y;
object{
 final
 transform{Center_Trans(final,x+y+z)}
 translate <0,ye/2,0>
 rotate <0,33,0>
  location  <0.0, ye*0.75, -350.0>
  direction 1.5*z
  look_at   <0.0, ye/2,  0.0>
light_source {
  <0, ye*0.75, -250>
  color rgb <1, 1, 1>
-- code ends
> -Chris
