POV-Ray : Newsgroups : povray.binaries.images : Strange Attractors by Manuel Kasten Server Time
23 Mar 2026 07:32:27 EDT (-0400)
  Strange Attractors by Manuel Kasten (Message 1 to 10 of 39)
Subject: Strange Attractors by Manuel Kasten
Date: 14 Mar 2004 19:15:08
Message: <4054f58c@news.povray.org>
The code for this image is by Manuel Kasten, who posted it in
povray.general. The scene contains 2.000.000 little white spheres. He
couldn't render it himself though, because of heavy swapping.
Now, I don't have enough memory either, but what I did was to reduce the
memory usage by rendering the image over 20 passes each with 100.000
spheres, each time using the previous frame as a background image_map
for the current frame. The result looks nice. It's attached. Well, I
blurred it in Paint Shop Pro before posting in order to reduce
graininess and jpeg-artifacts. The original really isn't blurred at all
despite the multiple times applied antialiasing that is a side effect
from the multiple pass technique I used.
Rune
rune|vision:  http://runevision.com **updated Mar 9**
POV-Ray Ring: http://webring.povray.co.uk
Download 'attractors.jpg' (55 KB)
Preview of image 'attractors.jpg'
Subject: Re: Strange Attractors by Manuel Kasten
Date: 14 Mar 2004 19:22:06
Message: <4054f72e$1@news.povray.org>
"Rune" <run### [at] runevisioncom> wrote in message
news:4054f58c@news.povray.org...
AWESOME technique!!!
- Respectfully,
Dan
http://<broken link>
Date: 14 Mar 2004 19:30:29
Message: <4054f925$1@news.povray.org>
If you used no interpolation (the default) and aligned the background image
properly, then the AA'ing shouldn't have caused any blurring.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 14 Mar 2004 19:48:15
Message: <4054fd4f@news.povray.org>
> the background image properly, then the AA'ing shouldn't
Now that I think a bit more about it, I think you're right. And it does
indeed seem like there was no blurring at all. (And yes, I did use no
interpolation and aligned the background image properly.)
Rune
Date: 15 Mar 2004 01:03:17
Message: <40554725@news.povray.org>
Shouldn't that be 'AWESUM ROLEX'?  ;)
Tim Cook
Version: 3.12
Date: 15 Mar 2004 01:42:29
Message: <40555055@news.povray.org>
The code is based on Paul Bourkes scc3 entry.
Thank you! That's a great idea. Because I couldn't get around that problem
for myself, but wanted to play with attractors more, I wrote a Java program
(so the following picture is _NOT POVRAY CREATED_). It consits of merely
50 mio. points and was created in less than 2 minutes with a memory usage of
approx. 4 MB.
again: this is not povray generated, but related to the topic...
Download 'attractor.jpg' (88 KB)
Preview of image 'attractor.jpg'
Date: 15 Mar 2004 01:58:11
Message: <40555403@news.povray.org>
> approx. 4 MB.
Cool! Looks much smoother than the POV one. No create some colorful
gradients within the attractor, add a "create random attractor"-button
and there goes the new wallpaper-machine :)
Do I understand it correctly that the attractor is a surface (or could
be represented as one)? It looks like it, so you could try to build a
(smooth) mesh from it. Then you could also do fancy stuff like nice
finishes etc. Of course you'd need POV again to do so.
Florian
Date: 15 Mar 2004 07:20:43
Message: <40559f9b@news.povray.org>
Hmm, I don't have any idea how to colour them.
Plus I think they look much more artistic in 2 colors.
(I have some black attractors on light blue background as wallpaper)
No, it's not a surface. It's a bunch of points on a 2D-coordinate system.
They look 3D, but they aren't.
Manuel Kasten
Date: 15 Mar 2004 08:13:05
Message: <4055abe1@news.povray.org>
Which is not to say that you can't have 3D attractors. I wrote a quick
and dirty hack to search for sets of coefficients for a 3D quadratic
that produce nice attractors a while ago, I've been meaning to work on
it, perhaps I'll clean it up and post it here if anyone's interested.
The trouble with rendering it as a solid object is that you have no more
information than the location of each point - other than simple
proximity there is no way of knowing whether two points should be
connected forming part of a surface, or whether there is a gap between
them that should not be filled. In the end you either just plot so many
points that it looks like a single surface, or use a guessing algorithm
designed to form a surface from a collection of points.
The sample attaced is rendered by plotting each of the 65536 points as a
sphere. It looks a little flat, but you can see where a bit of it sticks
in front of the rest at around 8 o'clock, and a bit of twisting from
around 11 o'clock to 2 o'clock.
Download 'attractor3d.jpg' (25 KB)
Preview of image 'attractor3d.jpg'
Date: 15 Mar 2004 10:17:02
Message: <4055c8ee@news.povray.org>
"Timothy Cook" <z99### [at] bellsouthnet> schreef in bericht
news:40554725@news.povray.org...
IIRC it was "AWSOME ROLEX" :)
btw, Rune, nice image as always, but I believe in this case raytracing isn't
the way to go.  Using scanline, you don't have to store all the points in
memory, only the one you're currently drawing, so it wouldn't be any problem
to draw millions or billions of points :)
(Unless there's something about this strange attractors that I don't know...
maybe you need every previous point to compute the next? :-/ :-))
cu!
ZK AKA Gaeriel
http://www.povplace.be.tf
"If we ain't outta here in ten minutes, we won't need no rocket to fly
through space."
