POV-Ray : Newsgroups : povray.binaries.images : Borg cube - 1 attachment Server Time
14 Nov 2024 12:25:22 EST (-0500)
  Borg cube - 1 attachment (Message 1 to 6 of 6)
Subject: Borg cube - 1 attachment
Date: 28 Feb 2004 03:51:50
Message: <Xns949D642CCECECraf256com@203.29.75.35>
Borg cube droped out from warp 9 - ahad of us!
Comander Riker, evasive maneuvers!
( this image should be viewed in .png, since .jpg compressed version looks
totaly different - background is messed up :/ )
.png version is[1] on my www - http://www.raf256.com/3d/image/a00121/
and also .jpg - i.e. if some poor outloo er... I ment, news readers, can
not display attachments with several dots in name.
I also will put on www another version of this image (in few minutes) -
Borg Cube Decloaking, with is better? I personaly think - the one with
background.
Any comments welcommed :)
[1] or will be there in ~15 min from now
Computer Graphics
Download 'borg.vb3.jpg95.jpg' (237 KB)
Preview of image 'borg.vb3.jpg95.jpg'
Subject: Re: Borg cube - 1 attachment
Date: 28 Feb 2004 12:13:18
Message: <4040CC2A.FB77A151@hotmail.com>
Well, it exposes the limitations of relying on texturing for details
that should be modeled.  If you hadn't said it was the Borg cube, I
would have taken it for an abstract work.
John
Date: 28 Feb 2004 16:50:27
Message: <Xns949DE8B0E7BF4spamraf256com@203.29.75.35>
John VanSickle <evi### [at] hotmailcom> wrote in
news:4040CC2A.FB77A151@hotmail.com
It was for the SCC-3 (limit 256 bytes of source code ;)
I'm planning to d oa real Borg Cube later
Date: 29 Feb 2004 07:24:46
Message: <4041da0e$1@news.povray.org>
Does 256 bytes not allow for a loop of boxes, even with cylinders, spheres
and torus's?  If you can make a plant ...  :o)
Hugo
Date: 29 Feb 2004 07:46:42
Message: <Xns949E8C8524685spamraf256com@203.29.75.35>
"Hugo Asm" <hua### [at] post3teledk> wrote in
news:4041da0e$1@news.povray.org
> spheres and torus's?  If you can make a plant ...  :o)
I played with fractals long time ago, and this was my first "borg cube",
but  I could try to make some L system that will produce maze-like-grid,
L systems have suprisingly short code.
In fact this image also uses some style of fractal recursion, but the
effect is not so nice.
  X is an cells pattern
  C is an checker of B
  B is either C or X depending or randomness and recursion level
  box and tunel are covered in X
I also tried to build side of cube as a grid of N..400 cylinders, N-th
cylinder was translated by <N mod 20, int(N/20)> and rotate by 0 or 90*y
randomly. Then put a cube of 6 object like above. Then make smaller one,
with pigment y and ambient 1 to work as light source. And this code AFAIR
was >256 already. To have nice effect it will also require radiosity to
better show green light from inside of cube, and an normal light source,
so I will do it as normal scene (not for SCC3).
It is nice how SCC3 can inspire :)
Date: 29 Feb 2004 07:51:11
Message: <Xns949E8D47CEE95spamraf256com@203.29.75.35>
Raf256 <spa### [at] raf256com> wrote in
news:Xns949E8C8524685spamraf256com@203.29.75.35
errat,
..in C
> N-th cylinder was translated by <N mod 20, int(N/20)> and rotate by
> 0 or 90*y
0 or 90*z
