POV-Ray : Newsgroups : povray.binaries.images : First Scene Post Server Time
14 Nov 2024 16:24:09 EST (-0500)
  First Scene Post (Message 1 to 5 of 5)
Subject: First Scene Post
Date: 22 Jan 2004 11:17:03
Message: <400ff77f@news.povray.org>
Following the traditions of the group, I'd like to introduce my
interpretation of the Sphere-on-Checkered-Plane.  Enjoy, and lighting
recommendations are *always* welcome (radiosity* as well).
-->Jeff
*--radiosity for second version is default (radiosity{})
No signature here, move along...
--- jgentry at ev1 dot net ---
Download 's-n-cp.jpg' (117 KB) Download 's-n-cp_rad.jpg' (129 KB)
Preview of image 's-n-cp.jpg'
Preview of image 's-n-cp_rad.jpg'
Subject: Re: First Scene Post
Date: 22 Jan 2004 21:48:36
Message: <40108b84@news.povray.org>
Neato!  Can't wait to see more of your stuff.
Date: 23 Jan 2004 07:24:50
Message: <40111292@news.povray.org>
Welcome! That looks nice, and if you want to improve the light, try adding:
   fade_distance 1
   fade_power 2
to your light source which gives it a realistic fall-off. You'll need to
increase the strength of light, until it has the desired lumiousity. To
emphasize the falloff effect you could also place it closer to the sphere (I
would still have it outside the camera view). Eventually you'll want to make
a color gradient in the sky_sphere, so it gets brighter at the position of
the light_source.
It's best to turn off 'ambient' completely in all light absorbing materials,
except the sky... You can do this by adding the following line at the top of
your code:
   #default { finish { ambient 0 } }
About gamma correction: I'm not sure if you already use it, but it's off by
default in POV-Ray. It's probably a good idea to activate it and get used to
it. Only thing is, imported image_maps will be gamma corrected as well, and
this was usually done already, outside of POV-Ray. So image_maps will need
some adjusting. If you are running a typical PC computer, gamma correction
should probably be 2.2 and you set this by adding the following line to your
code (I know it looks ironic but it's not):
These suggestions will change the appearance of your image quite a bit, but
it's more natural and realistic to use them ..so, good luck!
Hugo
Date: 23 Jan 2004 09:05:35
Message: <40112a2f@news.povray.org>
>    fade_distance 1
>    fade_power 2
> the light_source.
> your code:
> Regards,
> Hugo
Thanks for your comments and [very] helpful suggestions.  I need the
tips.  Lighting has been a huge problem.
-->Jeff
Date: 23 Jan 2004 09:06:57
Message: <40112a81$1@news.povray.org>
Thanks, Aaron.  Hopefully I'll be able to get a new scene underway soon.
-->Jeff
