Halfway between pictures and announcement, since we'll have both.
Here is a picture made using a grass dropping software I wrote this
summer. The rest of the picture is the result of Marc Jacquier's skills.
This software was written in Java for portability, takes a greyscale
height_field image as input, and outputs a POV-Ray 3.5 include file. It
features the following:
- important memory savings compared with usual loop algorithms, using an
extension to Gilles Tran's mgrass macros "patch" principle and a
"dictionary"-style packing algorithm
- easy slope filtering to remove grass in steepest areas
- optional mask to allow or prevent grass growth on special locations
like roads or ponds
- choice between simple but ugly, and nice, curved blades
- optional gathering of blades into tufts
- mesh2 export
- individual uv-mapping of blades
This free software (GPL) and its documentation are here:
http://www.wozzeck.net/images/hfcomp/gazon-en.html
Enjoy!
__ __ __ __ _
| | / \ / / |_ / |/
\/\/ \__/ /_ /_ |__ \_ |\
Download 'demo.jpg' (351 KB)
Preview of image 'demo.jpg'
noticias 3f6250af@news.povray.org...
> like roads or ponds
> - mesh2 export
> Enjoy!
Sure I'll do.
Impressive image, and impressive features.
I've just downloaded it.
Thank you very much for sharing your work.
Bye.
Txemi Jendrix
http://www.txemijendrix.com
n
> like roads or ponds
> - mesh2 export
Looks nice but using an external program excluses placing the grass on
isosurfaces :-(. I understand though that your sophisticated memory
saving placement would probably be very slow in SDL.
Last updated 17 Jun. 2003 _____./\/^>_*_<^\/\.______
I sincerely would like the water code! I simply adore the look of it.
I realize it's a good combination of sky and under-water grass and cliffs.
But the pattern and material looks great. Can it be animated?
Hugo
Surely you can just render the isosurface from above with a depth render?
Though you wouldn't get grass on surfaces that couldn't be represented with a
height field, like caves or similar concave shapes.
Tek
http://www.evilsuperbrain.com
Excellent work.
Hands up for the water code as well :)
What do you mean by "depth render"?
I think what you're saying is that you could create a height_field from the
isosurface, and then use that hightfield for reference in the grass-tool.
Is this correct?
The only way I would know of to do something like that is to create an
orthogonal camera view, and then use a gradient texture on the isosurface.
But without trying that, I'm not sure if it would work. I'm assuming that
there must be an easier way.
Jeremy
"Jeremy M. Praay" <jer### [at] questsoftware com> wrote in message
news:3f65f794@news.povray.org...
> Is this correct?
Yeah exactly, I thought povray had a render option to do that. Or maybe
megapov...
But otherwise you could do an orthographic camera and gradient, like you said.
It would work perfectly (I've done similar things a few times), you'd just need
a simple bit of maths to line up the heightfield with the original objects.
Tek
3f6352c7$1@news.povray.org...
Thank you :-)
Sea surface shape is a piece of code frome Gilles Tran's makeclouds demo
http://www.oyonale.com/ressources/downloads/makecloud2_demo_sea.pov
Material is from my own :p
I post the scene ( without grass) on p.b.s-f
>Can it be animated?
I don't see how it could be but maybe somebody has an idea.
Marc
"Orthographic" not "orthogonal"... Oops... I knew that didn't sound right
when I typed it, but alas, I was at work...
I should give that a try (in conjunction with this grass tool). I was
hoping to enter the current IRTC round, but "work" and "life" seem to be
taking precedence, so that should give me time to play around.
"Tek" <tek### [at] evilsuperbrain com> wrote in message
news:3f6635ab@news.povray.org...
the
grass-tool.
> > Is this correct?
> megapov...
said.
need
objects.
> Tek
