POV-Ray : Newsgroups : povray.binaries.images : It seemed like a good idea at the time Server Time
11 Jul 2026 12:56:22 EDT (-0400)
  It seemed like a good idea at the time (Message 1 to 6 of 6)
Subject: It seemed like a good idea at the time
Date: 23 Jun 2003 06:17:15
Message: <3ef6d3ab@news.povray.org>
Scene contains 38 frame level objects; 0 infinite.
Statistics for ruinedtemple.pov, Resolution 2048 x 1536
Pixels:         3148380   Samples:        27807664   Smpls/Pxl: 8.83
Rays:          46647978   Saved:                 0   Max Level: 10/10
Ray->Shape Intersection          Tests       Succeeded  Percentage
Cone/Cylinder                 30938283        15241970     49.27
Mesh                         114974611        49356427     42.93
Sphere                        69744866        65794933     94.34
Bounding Box                4909291911      1716750230     34.97
Light Buffer                  93342906        37822465     40.52
Vista Buffer                 524596390       349059878     66.54
Calls to Noise:           60091854   Calls to DNoise:      245361694
Media Intervals:           7887081   Media Samples:         44192469 (5.60)
Shadow Ray Tests:         25599216   Succeeded:             14999770
Transmitted Rays:         12102639
Radiosity samples calculated:      74890 (0.22 percent)
Radiosity samples reused:       34407161
Smallest Alloc:                 25 bytes   Largest:         15870024
Peak memory used:        497470420 bytes
Time For Parse:    0 hours  1 minutes  57.0 seconds (117 seconds)
Time For Trace:    4 hours 22 minutes  23.0 seconds (15474 seconds)
     Total Time:    4 hours 19 minutes  51.0 seconds (15591 seconds)
CPU time used: kernel 44.89 seconds, user 11742.30 seconds, total
11787.19 seconds
Render averaged 266.88 PPS over 3145728 pixels
That's right, a 2048x1536 raytraced image in 4 hours 20 mins.  With
media radiosity and one point light.  Image to follow.
Tim Cook
Version: 3.12
Subject: It seemed like a good idea at the time (image)
Date: 23 Jun 2003 06:19:45
Message: <3ef6d441@news.povray.org>
...resized to 800x600.
Tim Cook
Version: 3.12
Download 'temple ruins small.jpg' (134 KB)
Preview of image 'temple ruins small.jpg'
Subject: Re: It seemed like a good idea at the time
Date: 23 Jun 2003 14:32:35
Message: <3EF747BD.539C1617@hotmail.com>
I've found that using two shadowless lights, far off, both at right
angles to each other & the direction of the main light, does the work of
radiosity at a small fraction of the computational cost.
John
Date: 23 Jun 2003 15:00:01
Message: <web.3ef74d568d60c382a0c272b50@news.povray.org>
>Tim Cook
>http://home.bellsouth.net/p/PWP-empyrean
Nice!  Very moody.
RG
Date: 23 Jun 2003 15:10:01
Message: <web.3ef74f738d60c382a0c272b50@news.povray.org>
Thanks, I'll try that.   I started a radiosity render for the IRTC before I
left on a dive trip... came back, and after 71 hrs it was only 48%
finished, and unfortunately, I do need to use my computer for other things
occasionally.
Probably had something to do with the 655,000+ frame level objects... no
radiosity renders in about 2 hrs.
RG - it looks ok without radiosity, but the shadows are too dark, and too
much contrast overall
Date: 23 Jun 2003 15:41:17
Message: <3ef757dd@news.povray.org>
Well the one point light that I do have isn't contributing much of
anything radiosity-wise to the scene; I have radiosity on for the
glowing media...that fire there has no actual light sources, just
media with emission of, oh, 1000...?
Tim Cook
Version: 3.12
