POV-Ray : Newsgroups : povray.binaries.images : fish glass [WIP 2] (JPG 53KB) Server Time
16 Nov 2024 06:14:48 EST (-0500)
  fish glass [WIP 2] (JPG 53KB) (Message 1 to 7 of 7)
Subject: fish glass [WIP 2] (JPG 53KB)
Date: 15 Feb 2003 10:46:41
Message: <3e4e60e1@news.povray.org>
Hi!
I added some gravels now.. The gravels at the very bottom look like one.
Don't know why..
The gravels were added via simpov/mechsim in MegaPOV 1 and are blobs.
Any more tips, suggestions, ...?
Dirk "DIRKO" Legler
Download 'fisch4.jpg' (54 KB)
Preview of image 'fisch4.jpg'
Subject: Re: fish glass [WIP 2] (JPG 53KB)
Date: 15 Feb 2003 12:46:32
Message: <3E4E7DB5.61F82FE8@Rapidnet.com>
Looking really good, however, the bowl looks like it was molded around the
base.  Unless this is the way you wanted it, you can find the radius of the
sphere at a given point with the following equation:
sqrt(pow(gr,2) - pow(dr,2))    <<-- in graphic form below.
where <b>gr</b> is the given radius of the sphere you started with, and
<b>dr</b> is the desired radius.  This will render the distance of that
radius from the center of the sphere. I use a graphing calculator for this,
but a really good scientific one will do.
A.D.B
Dirk \"DIRKO\" Legler wrote:
> Hi!
> Don't know why..
> Dirk "DIRKO" Legler
Date: 15 Feb 2003 14:06:23
Message: <3e4e8faf@news.povray.org>
"Anthony D. Baye" <ban### [at] Rapidnetcom> schrieb im Newsbeitrag
news:3E4E7DB5.61F82FE8@Rapidnet.com...
the
Sorry, but wat is "molded"? Couldn't find a translation in my dictionary..
this,
I wish I could afford babylon.com translator ;) Isn't it the desired radius
that is to calculate with that equation? Or what is it for?
*confused* DIRKO
Date: 15 Feb 2003 14:48:37
Message: <3e4e9995@news.povray.org>
Those gravels looking like one comes from the
insufficient lighting. All gravels below a certain
level are being shaded by those above them, and
then they all receive only the basic ambient-lighting,
thus no surfaces are shaded properly. If you set
global_settings{ambient_light 0}, then you'd see the
effect which is taking place with ambient-light:
objects that would otherwise be totally black, receive
something similiar to a gamma-correction, appearing
brighter and thus visible, but by no means properly
shaded.
Otherwise a nice beginning. You might want to make the
bowl totally transparent, but use specular and reflections
(look at finish in the docs) and ior (interior in docs) to make
the glass-object visible, but by other means that making it
milky...
Just a suggestion though.
Tim Nikias
Email: Tim### [at] gmxde
> Hi!
> Don't know why..
> Dirk "DIRKO" Legler
Date: 15 Feb 2003 14:55:11
Message: <3E4E9BDB.59625B59@Rapidnet.com>
> the
The bowl looks as if it were formed around the central ring of the base.  The
torus and spheres pass through the glass.
> this,
I inverted the parameters for desired radius and distance, so that the product
is the desired radius rather than the distance from center.
> *confused* DIRKO
Download 'equation.gif' (4 KB)
Preview of image 'equation.gif'
Date: 15 Feb 2003 14:56:56
Message: <3E4E9C47.4AB8CE11@Rapidnet.com>
I used this equation to create the rim of the foreward dish on my sattelite
picture above.
> > the
> > this,
> > *confused* DIRKO
Subject: fish glass [WIP 3] (JPG 40KB)
Date: 16 Feb 2003 14:19:35
Message: <3e4fe447@news.povray.org>
800*600, photons=on, new fish (blobs), brighter light, 30 minutes render
time on Intel P4 1600MHz
water now overlaps with glass (suggested by Tim Nikias)
DIRKO
Download 'fisch6.jpg' (40 KB)
Preview of image 'fisch6.jpg'
