High!
Currently, I'm modeling an ancient mathematical co-prozessor... and with
its pins, a problem occurred. As they are somehow soldered to the
ceramic die's lower side, there is a smooth transition between the pin
itself and its flat round base. Any attempts to model this with blobs
resulted in monstrously swollen base cylinders, so I decided to do it
with a lathe, using Moray.
But when viewed from along the z axis, the lathe turns out to be
asymmetric (see picture)! Did this result from the fact that I did not
specify a fourth point on the y axis?
Here is the code:
#declare Pin_Raw=
cylinder
0, <0, 0.0037, 0>, 0.0001
#declare Pin_Transition=
lathe { // RotSweep001
quadratic_spline
3 // control points
<28.704931, 14.913935>,
<5.999999, -0.033529>,
<0.639678, 11.939946>
scale 0.0001
translate 0.00003
#declare Pin_Socket=
cylinder
0, <0, 0.00003, 0>, 0.0006
#declare Pin=
union
object { Pin_Raw }
object { Pin_Transition }
object { Pin_Socket }
texture { T_Gold_2B }
Download 'cyrix0001.jpg' (6 KB)
Preview of image 'cyrix0001.jpg'
I would have done something like this:
#declare contact_pin =
intersection {
union {
difference {
torus { 0.015625, 0.0078125 translate 0.0234375*y }
cylinder { <0.0, 0.0234375, 0.0> <0.0, 0.046875, 0.0> 0.046875 }
cylinder { <0.0, 0.0234375, 0.0> <0.0, 0.078125, 0.0> 0.0078125 }
cylinder { <0.0, -0.015625, 0.0> <0.0, 0.09375, 0.0> 0.0234375 }
texture { T_Gold_5A }
Anthony D. Baye
> High!
> Here is the code:
> #declare Pin_Raw=
> cylinder
> quadratic_spline
> 3 // control points
> scale 0.0001
> translate 0.00003
> cylinder
> #declare Pin=
> union
> object { Pin_Raw }
> [Image]
>High!
>Here is the code:
>#declare Pin_Raw=
>cylinder
> quadratic_spline
> 3 // control points
> scale 0.0001
> translate 0.00003
The lathe itself is symmetrical, it's just that you've translated it by
<0.00003, 0.00003, 0.00003> relative to the Pin_Raw cylinder. Try
translate 0.00003*y
Mike Williams
Gentleman of Leisure
=?iso-8859-1?Q?J=F6rg?= 'Yadgar' Bleiman wrote:
>High!
>Here is the code:
> quadratic_spline
> 3 // control points
> scale 0.0001
> translate 0.00003
Are you aware that POV-Ray promotes
the 0.00003 scalar in your
"translate 0.00003" expression to a
vector, so that the expression
becomes this:
translate <0.00003, 0.00003, 0.00003>
Maybe you meant to write:
translate 0.00003*y
Hmmm...
I see now that you are using Moray.
Maybe I haven't found your problem.
Tor Olav
High!
> translate 0.00003*y
Ouuuh... how stupid!!!
You should perhaps explain what you're actually trying
to do with that code. Some newbies might not understand
that you're taking a cylinder, put a thick base, of which
you carve a quarter of a torus. And without an image
they might not get what the effect is...
Just a suggestion,
Tim
Tim Nikias
Email: Tim### [at] gmxde
> intersection {
> union {
> difference {
> Regards,
> Anthony D. Baye
> > High!
> > Here is the code:
> > #declare Pin_Raw=
> > cylinder
> > quadratic_spline
> > 3 // control points
> > scale 0.0001
> > translate 0.00003
> > cylinder
> > #declare Pin=
> > union
> > object { Pin_Raw }
> > [Image]
