POV-Ray : Newsgroups : povray.binaries.images : Need help with Colefax' Splines (Coil spline) 1 attachement 12kb Server Time
30 Mar 2026 13:29:18 EDT (-0400)
  Need help with Colefax' Splines (Coil spline) 1 attachement 12kb (Message 1 to 9 of 9)
Subject: Need help with Colefax' Splines (Coil spline) 1 attachement 12kb
Date: 8 Feb 2003 16:49:11
Message: <3e457b57@news.povray.org>
Hello,
please help me!
What is this, and how can I avoid it?
Thanks
MfG
Manuel Kasten
Download 'problem.jpg' (13 KB)
Preview of image 'problem.jpg'
Subject: Re: Need help with Colefax' Splines (Coil spline) 1 attachement 12kb
Date: 8 Feb 2003 17:39:18
Message: <3e458716$1@news.povray.org>
"Manuel Kasten" <kas### [at] gmxde> wrote in message
news:3e457b57@news.povray.org...
> Hello,
> please help me!
    I used to get those all the time in my phone cords, then I went to Radio
Shack and bought some of those little twisty ends for the cords and I never
had that problem again.
Version: 6.0.449 / Virus Database: 251 - Release Date: 1/27/03
Date: 9 Feb 2003 02:49:30
Message: <3e46080a@news.povray.org>
That's a kink in your phone cord...to remove it, take the handset and
loop it around once...;)
--Tim Cook
Version: 3.12
Date: 9 Feb 2003 12:05:01
Message: <3e468a3d@news.povray.org>
Never seen that happen before so I couldn't tell you anything. It doesn't
looks like a part of the spline, e.g. a misplaced endpoint/control point.
Looks a lot like a separate piece.
Is this using the spline macro? I suppose there's a chance it could be where
two splines meet...  No way of knowing without checking the pov script.
Subject: Re: Need help with Colefax' Splines (Coil spline) 1 attachement 23kb
Date: 9 Feb 2003 17:20:41
Message: <3e46d439@news.povray.org>
It is only one spline.
I was able to reproduce it, but that didn't help me to avoid it in my scene.
Here's the reproduce:
----------code----------
#include "spline.mcr"
#declare coil = create_spline (
   array[3] {<-75,0,0><0,0,3><75,0,0>},
   create_default_spline +
   spline_sampling (on) )
#declare coil2 = create_spline (
   array[3] {<0,0,-75><-3,0,0><0,0,75>},
union {coil_spline (coil, spline_steps (40)
   + spline_radius (4)
   + coil_radius (1.5))
   pigment {rgb <1, 0, 0>}
   finish {phong 0.6}
   translate 20*z}
union {coil_spline (coil2, spline_steps (40)
   + spline_radius (4)
   finish {phong 0.6}
   rotate 90*y
   translate -20*z}
camera {location  <0,500,-150> look_at <0,0,0> angle 20}
background{rgb 1}
light_source { <500,500,500> rgb 1 }
----------end_code----------
Download 'problem2.jpg' (24 KB)
Preview of image 'problem2.jpg'
Date: 10 Feb 2003 00:04:16
Message: <3e4732d0@news.povray.org>
I'm not too familiar with the spline macro so I was hoping someone else,
even Chris Colefax himself, might know of a remedy for this. What it seems
to be is that the coil object (torus spiral) is meeting in a mirrored
fashion instead of compensating for the bend. I looked over the macro quite
a while but I can't see a simple solution. Unless maybe it would be to use a
different object.
news:3e46d439@news.povray.org...
>    + spline_radius (4)
>    finish {phong 0.6}
>    translate 20*z}
>    + spline_radius (4)
>    finish {phong 0.6}
>    rotate 90*y
>    translate -20*z}
> background{rgb 1}
Date: 10 Feb 2003 21:14:10
Message: <1icbprof7cggi$.dz0h7qo4y0j4$.dlg@40tude.net>
>    + spline_radius (4)
>    finish {phong 0.6}
>    translate 20*z}
>    + spline_radius (4)
>    finish {phong 0.6}
>    rotate 90*y
>    translate -20*z}
> background{rgb 1}
I've never used this macro so I'm not sure but it looks like the cable is
half-turned in one of them creating a quite realistic "kink". I'd guess
turning one end around would actually help, no joke!
I might be completely wrong...
Date: 10 Feb 2003 21:46:13
Message: <3e4863f5@news.povray.org>
Manuel Kasten <kas### [at] gmxde> wrote:
> please help me!
The problem you are seeing is caused by the method used to calculate the
normal vector of the spline (required to orient the torus segments used to
create the coil).  The current macro file is hardwired to use a 'sky' vector
of z to calculate the spline normal, and when the spline runs directly along
this axis a shift in orientation occurs.
To fix the problem, you can ensure the spline doesn't run along the z-axis,
or download an updated version of the macro file (from
www.geocities.com/ccolefax/spline), which will allow you to adjust the sky
vector used with the spline_normal_sky option.
Date: 10 Feb 2003 22:38:31
Message: <3e487037@news.povray.org>
"Chris Colefax" <chr### [at] tagpovrayorg> wrote in message
news:3e4863f5@news.povray.org...
vector
along
z-axis,
A big thank you, Chris. As simple an explanation as you make your files seem
(until looking at them!). I was so close to the answer, I tried the
spline_normal_sky once because that was one of the things I thought might
have to do with this (axis shifting) but I obviously used it wrong and saw
no change. Then again, I've now tried the suggested fix and it still isn't
going right. I just redownloaded the spline macro to be sure I have the
right file and retried and it's okay. However, in both files there is a
_SP_normsky which apparently uses y, not z. I won't try to figure it out
since it boggles my mind anyhow.
