POV-Ray : Newsgroups : povray.binaries.images : Intruder Server Time
23 Jun 2026 06:16:29 EDT (-0400)
  Intruder (Message 1 to 7 of 7)
Subject: Intruder
Date: 3 Feb 2003 05:13:35
Message: <3e3e40cf@news.povray.org>
Here's an updated image.
Download 'Intruder_1024x768AA0.3_20020131.jpg' (55 KB)
Preview of image 'Intruder_1024x768AA0.3_20020131.jpg'
Subject: Re: Intruder
Date: 3 Feb 2003 14:09:02
Message: <3e3ebe4e$1@news.povray.org>
"Darren Hewson" <dar### [at] hotmailcom> wrote in message
news:3e3e40cf@news.povray.org...
Is it me or or we seeing double reflections here?
Certainly the planet seems to be reflected twice; first, just behind the
jetty (half-hidden by leaves) and then midway between that reflection and
the planet itself. The craft also seems to be reflected twice; first, where
I'd expect it and then just in front of the craft itself but scaled down.
On the positive side, I like the atmosphere.
John
BTW Move the jetty or the background trees; it looks as if the tree
reflection is growing out of the jetty upright.
Run Fast
Run Free
Run Linux
Date: 4 Feb 2003 04:20:08
Message: <web.3e3f84eb3c720672641f1e9f0@news.povray.org>
>Cheers
This is getting pretty cool :)
Best regards.
Date: 4 Feb 2003 04:45:15
Message: <3e3f8bab@news.povray.org>
The normal-pattern on the lake is too large. What you
see are multiple reflections due to several "waves".
Perhaps that should be changed, I guess "waves" or "ripples"
are being used. A nice bozo-turbulenced normal
might be better.
Tim
Tim Nikias
Email: Tim### [at] gmxde
Date: 4 Feb 2003 05:13:38
Message: <3e3f9252@news.povray.org>
Aside from the odd reflections - looking much better
PGP Public Key
Date: 4 Feb 2003 10:59:59
Message: <3e3fe37f@news.povray.org>
Yes, the wet stuff is much better now. I agree with Tim's suggestion
that the double reflections could be due to a large normal.
Perhaps if the phase of the "ringed-one" were increased you could use
its light to explain the apparant (sp?) brightness of the water's
surface? On second thoughts - scrubb that idea, it would spoil the
scene.
Alf
Date: 4 Feb 2003 14:20:03
Message: <web.3e4011f93c720672b026437f0@news.povray.org>
>Cheers
Hey, thanks for the tips here, currently experimenting with bozo for the
water, previously I'd carelessly copied some other water texture that used
a bumps normal pattern, so it shouldn't be too tricky to fix the double
reflections.
I'll also move the jetty slightly to avoid the reflections 'growing' out of
it, good spot!
I also should mention that I used the newly released POVTree to create the
meshes for the background trees in this version (previously I used the PD
Tree macro), so thanks to Gena Obukhov for the timely release, I think it
much improved the image. Coincidentally I'd already used TOMTREE to create
the foreground trees.
