POV-Ray : Newsgroups : povray.binaries.images : Some radiosity issues Server Time
21 Oct 2024 07:27:46 EDT (-0400)
  Some radiosity issues (Message 1 to 8 of 8)
Subject: Some radiosity issues
Date: 31 Jan 2003 12:14:47
Message: <3e3aaf07@news.povray.org>
Hi all!
I'm having some problems with getting radiosity to look good in my current
IRTC project.
I've attatched three pictures
bathroom07_small_original.jpg is how it came out from POV-Ray
bahtroom07_gamma.jpg is gamma correceted to se the detais
bahtroom07_target.jpg is an gamma / brightness / contrast altered image, and
is somewhat what I aim for.
I tried using two lights, and it looked better, but you couldn't even spot
the light beam from the door, and that is an important part of the scene.
I'll model seperate tiles for the walls and sink, any tips for a good, clean
ceramic texture?
I use the following rad settings: (uses Jaimes save/load trick)
global_settings{
 assumed_gamma 1.0
 ambient_light 0.0
 #if (R)
iosity{
// indoor quick settings from rad_def.inc
    #if(R_Save)
          pretrace_start 0.08
          pretrace_end   0.01
          count 50+100
          nearest_count 5+15
          error_bound 0.5-0.25
          recursion_limit 2
          low_error_factor 0.8
          gray_threshold 0
          minimum_reuse 0.015
          brightness 1.0+1.5
          adc_bailout 0.01/2
          save_file "bathroom.main.radiosity"
    #else
        // load settings
        pretrace_start 1 pretrace_end 1
        load_file "bathroom.main.radiosity"
        error_bound 0.5    // it's important to specify the same value used to save
data
        recursion_limit 2  // also the same if specified
        always_sample off  // no more samples: specially useful with focal blur
The rad is collected in 320x240 res with dummy objects and no finishes (~45min). And
then rendered in 1280x1024 (~1hour)
Any help appreciated!
Kind regards
Peter
Download 'bathroom07_small_original.jpg' (7 KB) Download 'bathroom07_gamma.jpg' (27 KB) Download 'bathroom07_target.jpg' (18 KB)
Preview of image 'bathroom07_small_original.jpg'
Preview of image 'bathroom07_gamma.jpg'
Preview of image 'bathroom07_target.jpg'
Subject: Re: Some radiosity issues
Date: 31 Jan 2003 16:07:26
Message: <3E3AE58C.C6C9054@gmx.de>
Peter Hertel wrote:
> Hi all!
> IRTC project.
Your image is simply way too dark.  Making the light source much brighter
will certainly improve it (alternatively you can also try the film
exposure function in megapov).
Also note that modifying contrast/brightness/gamma in the (8 bit) image
afterwards will strongly reduce the quality - most artefacts in your third
image do not seem to be caused by radiosity but by the limited color
resolution.
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 1 Feb 2003 09:14:28
Message: <3e3bd644@news.povray.org>
I've found that in architectural-type images it works better to increase the
minimum_reuse and the count, and decrease the error_bound.  Also, increasing
the recursion_limit will increase the brightness a little bit.
I found this to work okay for my last scene:
     pretrace_start 1
     pretrace_end   0.01
     count 600
     nearest_count 5
     error_bound 0.25
     recursion_limit 5
     low_error_factor .5
     gray_threshold 0.0
     minimum_reuse 0.05
     brightness 1
     adc_bailout 0.01/1
"Peter Hertel" <peter@hertel**NOSPAM**.no> wrote in message
news:3e3aaf07@news.povray.org...
> Hi all!
> IRTC project.
and
clean
> ceramic texture?
> global_settings{
>  assumed_gamma 1.0
>  ambient_light 0.0
>  #if (R)
> iosity{
>     #if(R_Save)
>           pretrace_start 0.08
>           pretrace_end   0.01
>           count 50+100
>           nearest_count 5+15
>           recursion_limit 2
>           gray_threshold 0
>           minimum_reuse 0.015
>           brightness 1.0+1.5
>           adc_bailout 0.01/2
>     #else
>         // load settings
used to save data
blur
>     #end
>  #end
(~45min). And then rendered in 1280x1024 (~1hour)
> Kind regards
> Peter
Date: 3 Feb 2003 14:16:13
Message: <3e3ebffd@news.povray.org>
Doh.. something didn't connect properly in my brain..
I added a 150 light multiplyer to the light, and it worked great. I lost
most of the warm colors in the light though.. I'll have to play around some
more.
> resolution.
Yeah.. I know.. It was mostly to get some hints of where I was planning to
go. And since brightness/constrast editing isn't permitted in IRTC, it's not
an option, really.
Thank you for your reply!
-Peter
Date: 3 Feb 2003 14:16:15
Message: <3e3ebfff@news.povray.org>
the
increasing
>      pretrace_start 1
>      pretrace_end   0.01
>      count 600
>      nearest_count 5
>      error_bound 0.25
>      recursion_limit 5
>      low_error_factor .5
>      gray_threshold 0.0
>      minimum_reuse 0.05
>      brightness 1
>      adc_bailout 0.01/1
That did the trick, thank you!
This is the first scene I'm making which depends so much on radiosity,
there's a lot to learn.
-Peter
Date: 6 Feb 2003 19:18:13
Message: <3e42a121.6444273@localhost>
from the title of your post I thought you were talking
about a new periodical.  I think you meant the title
to be "Some Radiousity Problems".
Date: 6 Feb 2003 22:37:29
Message: <3e4329f9$1@news.povray.org>
"nospam" <Pet### [at] nymaliasnetalmost> wrote in message
news:3e42a121.6444273@localhost...
I worked at a company some years ago where we weren't allowed to use the word
'problem' because it evoked negativity. 'Issues' however presented 'challenges
to be overcome.' He may be suffering residual effects from similar authoritarian
silliness.
Date: 7 Feb 2003 11:37:43
Message: <3e43e0d7@news.povray.org>
> He may be suffering residual effects from similar authoritarian silliness.
Something like that :)
-Peter
