POV-Ray : Newsgroups : povray.binaries.images : Reaching (1 image ~23kb) Server Time
10 Sep 2025 19:25:07 EDT (-0400)
  Reaching (1 image ~23kb) (Message 1 to 8 of 8)
Subject: Reaching (1 image ~23kb)
Date: 10 Jan 2002 00:22:20
Message: <3c3d250c@news.povray.org>
Hey there!
I saw an image posted a while back with 2 hands reaching up out of the sand.
I took some inspiration from that.  Here, a hand is reaching up out of the
ground towards the rising sun.  What do you think?  Questions? Comments?
-Dayv
Download 'reach.jpg' (23 KB)
Preview of image 'reach.jpg'
Subject: Re: Reaching (1 image ~23kb)
Date: 10 Jan 2002 02:22:27
Message: <3C3D4148.C6D4B5AC@unforgettable.com>
Dayv wrote:
> Hey there!
For some reason it makes me think of the dead coming to life and
crawling out of the ground.. except that hand looks pretty healthy, and
I'd expect that to happen at night.
-Xplo
Date: 10 Jan 2002 15:33:50
Message: <3c3dfaae@news.povray.org>
For some reason, this image reminded me of a Salvador Dali painting
Leitha
Date: 10 Jan 2002 21:46:54
Message: <3c3e521e$1@news.povray.org>
It looks too healthy to me.  Wanted it to look more stony.  Can you not
apply a normal pattern to a mesh?  I've tried all kinds of granite and
crackle... and even dents and ripples just for the hell of it... of all
different scales and nothing changes its appearance at all.
Any thoughts??
Thanks
Dayv
Date: 11 Jan 2002 15:16:22
Message: <3c3f4816$1@news.povray.org>
> Any thoughts??
This happens if it is a mesh2 object with indexed textures. Further texture
declarations get ignored. You can use the older mesh format or edit the textures
referenced in the object's include file.
BTW, I like this image. :)
light_source{0,1}#macro c(J,a)sphere{0,1pigment{rgb z}scale a translate J+O}
#end#macro B(R,V,O)c(0,4)intersection{c(V,R)difference{c(-z*4x+10)c(-z*4.1x+
10)c(0<7.5,45,5>)}}#end B(12,0z*25)B(8y*4<0,12,50>)          // Batronyx ^"^
Subject: Got it to work! (attached image ~23kb)
Date: 11 Jan 2002 18:15:45
Message: <3c3f7221@news.povray.org>
texture
textures
It's not a mesh 2.  Just a regular mesh.  I figured out what the problem
was.  The .inc file generated by PoseRay included uv_mapping that I thought
I had commented out. I didn't want to use the texure supplied by Poser
anyway.  The texturing was done in an "object" statement in the .pov file.
I renedered the scene in both 3.5 and megapov 0.7 and got the same results.
It wasn't until I tried rendering with 3.1 that I found I had missed a bunch
of uv_mapping tags.  When I removed those everything worked fine!  I guess
normals and uv_mapping don't get along well?  I've never used uv_mapping at
all so I have no idea.
Thanks.  Now that I've got the normal to work, I'm going to fine tune it
'till I like the way it looks!
Download 'reach2.jpg' (23 KB)
Preview of image 'reach2.jpg'
Subject: Re: Got it to work! (attached image ~23kb)
Date: 12 Jan 2002 19:41:56
Message: <3c40d7d4$1@news.povray.org>
I forgot about the new uv_mapping abilities of the regular mesh. I guess it
happens there too.
>  I guess
I'm no expert myself, but I would expect that the image the uv coords map into
is declared as a texture statement somewhere. I would also therefore expect one
could add a normal statement there to get bumps. I would also expect that for
good results, it should probably be based on another image(grayscale) but
anything there should produce something bumpy.
I'll have to give it try later. I'm going to need to know all of this soon
anyway.
Keep pluggin! :)
Date: 12 Jan 2002 20:00:14
Message: <3c40dc1e@news.povray.org>
hmm...
maybe I'll try editing the tiff file (and converting it to another format so
POV-Ray can read it.) to a stony texture and try it that way.
Back to the pov'ing board. . .
Sigh.  I may never have a social life again. . .
-Dayv
"Batronyx" <bat### [at] alliancecablenet> wrote in message
news:3c40d7d4$1@news.povray.org...
thought
file.
results.
bunch
it
> happens there too.
> >  I guess
at
into
expect one
for
> anyway.
> Keep pluggin! :)
J+O}
> #end#macro
