POV-Ray : Newsgroups : povray.binaries.images : fur take 2 Server Time
15 May 2026 21:00:32 EDT (-0400)
  fur take 2 (Message 1 to 10 of 13)
Subject: fur take 2
Date: 8 Jan 2002 21:24:57
Message: <3c3ba9f9@news.povray.org>
only 1 blob this time...
Parse Time: 0 seconds
Trace Time: 0 hour 32 minutes 44 seconds
Peak Memory Used: 168032 bytes (164.1 KB)
Pentium 3 450Mhz, 192MB RAM, under Windows XP, GUI priority: highest, Render priority:
lowest.
Rendered in POVMan 0.71.4 (at a resolution of 1024*768, resampled using PSP)
Actually this is a complete rewrite of the shader.  No more need for a shell-object
(at
least not in this test-image...)
Ryan: I tried adding anisotropic highlights, but it didn't really give as good as I
expected, so I left it out.
cu!
Download 'fur2.jpg' (71 KB)
Preview of image 'fur2.jpg'
Subject: Re: fur take 2
Date: 8 Jan 2002 22:46:12
Message: <3c3bbd04$1@news.povray.org>
as I
Umm. . . that wasn't Ryan. It was me. :)
This looks much much better even without the anisotropic shading. I'm not sure
if that was the right thing to suggest anyway. In R.Suzuki's post of November
14th "ISO quilt and carpet: three torii:
http://news.povray.org/3bf235e6@news.povray.org
you can see, in the first two torii, what I was trying to suggest.
You probably already knew that though. :)
light_source{0,1}#macro c(J,a)sphere{0,1pigment{rgb z}scale a translate J+O}
#end#macro B(R,V,O)c(0,4)intersection{c(V,R)difference{c(-z*4x+10)c(-z*4.1x+
10)c(0<7.5,45,5>)}}#end B(12,0z*25)B(8y*4<0,12,50>)          // Batronyx ^"^
Date: 8 Jan 2002 22:59:36
Message: <3c3bc028@news.povray.org>
you're right.  I'm sorry :)
tnx.  I think, if I had a way to know the orientation of the hairs, adding correct
anisotropic shading (and highlighting) would have very good results...  But I'm really
just starting with shaders, I don't know how to orient the fur.  In this image it
looks
already much better than in the previous one, where the noise representing the hairs
was a
uniform noise, but it's still not the way I want it...
Maybe someone can help me with this?
I'll clean the code of the shader, and then I'll post it to povray.text.scene-files
(or
should I post it somewhere else?)
cu!
Date: 8 Jan 2002 23:12:38
Message: <3c3bc336$1@news.povray.org>
(or
povray.binaries.scene-files that is...
cu!
Date: 9 Jan 2002 02:07:18
Message: <3C3BED7C.CD65F9BC@applesnake.net>
wow!  That is very good!
um...
with that better trace time...
um....
how does it animate? :o)
-peter
Current obsession: "Ballet pour ma fille."
http://www.applesnake.net
Date: 9 Jan 2002 07:26:10
Message: <3c3c36e2@news.povray.org>
Much better than the last one. I like.
Date: 9 Jan 2002 07:58:00
Message: <3c3c3e58@news.povray.org>
tnx :)
well, the orientation of the hairs won't change, so it might look a bit static...
cu!
Date: 9 Jan 2002 07:58:12
Message: <3c3c3e64@news.povray.org>
tnx
cu!
Date: 9 Jan 2002 13:05:54
Message: <3c3c8682@news.povray.org>
Sweet.
#local j=text{ttf"arial""JRG".2,0}#local J=0;#while(J<10)#local R=0;#while
(R<2)#local G=0;#while(G<1)#if(inside(j<R,G.1>))object{j scale.025translate
<R-1G-J/20J/-40+2>pigment{rgb<9J>}}#debug"O"#else#debug" "#end#local G=G+
.025;#end#local R=R+.05;#debug"\n"#end#local J=J+1;#end// JRG
Home: http://digilander.iol.it/jrgpov  //New: Kitchen scene WIP
Date: 9 Jan 2002 15:44:29
Message: <3c3cabad@news.povray.org>
Very nice!
I can see that you too have figured out that one important trick to simulate
fur is using "dark highlights". :)
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 2)
