POV-Ray : Newsgroups : povray.binaries.images : fur take 2 Server Time
15 May 2026 19:56:34 EDT (-0400)
  fur take 2 (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: fur take 2
Date: 8 Jan 2002 23:12:38
Message: <3c3bc336$1@news.povray.org>
> I'll clean the code of the shader, and then I'll post it to povray.text.scene-files
(or
> should I post it somewhere else?)
povray.binaries.scene-files that is...
cu!
Date: 9 Jan 2002 02:07:18
Message: <3C3BED7C.CD65F9BC@applesnake.net>
wow!  That is very good!
um...
with that better trace time...
um....
how does it animate? :o)
-peter
Current obsession: "Ballet pour ma fille."
http://www.applesnake.net
Date: 9 Jan 2002 07:26:10
Message: <3c3c36e2@news.povray.org>
Much better than the last one. I like.
Date: 9 Jan 2002 07:58:00
Message: <3c3c3e58@news.povray.org>
tnx :)
well, the orientation of the hairs won't change, so it might look a bit static...
cu!
Date: 9 Jan 2002 07:58:12
Message: <3c3c3e64@news.povray.org>
tnx
cu!
Date: 9 Jan 2002 13:05:54
Message: <3c3c8682@news.povray.org>
Sweet.
#local j=text{ttf"arial""JRG".2,0}#local J=0;#while(J<10)#local R=0;#while
(R<2)#local G=0;#while(G<1)#if(inside(j<R,G.1>))object{j scale.025translate
<R-1G-J/20J/-40+2>pigment{rgb<9J>}}#debug"O"#else#debug" "#end#local G=G+
.025;#end#local R=R+.05;#debug"\n"#end#local J=J+1;#end// JRG
Home: http://digilander.iol.it/jrgpov  //New: Kitchen scene WIP
Date: 9 Jan 2002 15:44:29
Message: <3c3cabad@news.povray.org>
Very nice!
I can see that you too have figured out that one important trick to simulate
fur is using "dark highlights". :)
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 2)
Date: 9 Jan 2002 19:14:16
Message: <3c3cdcd8@news.povray.org>
> Very nice!
tnx :)
thanks to your fur-texture :)
Another important thing is a bit of fuzziness at the edges.  That's the only reason
I'm
using shaders instead of just textures...
Problem now is that it's not suitable for animations, because the structure of the fur
doesn't move along with the object.  I can change that by not using the actual point
as a
parameter for the noise used, but the uv-coordinates.  However, if I did that, the
shader
couldn't be used for objects that have no uv-coordinates (like isosurfaces)...
Anyway, for stills and distant objects, I think this is a good enough fur-shader :)
cu!
Date: 11 Jan 2002 12:56:44
Message: <3C3F27B9.2080500@comtrade.ee>
Zeger Knaepen wrote:
[Snip]
Nice to see, that someone is playing with shaders and creating such
beautiful pictures!
I took a look to your shader and I must admit, that I don't understand
its semantics at all (as I've never learned Flemish? ;o) But I looked at
it from syntax viewpoint and may I propose couple of improvement
suggestions?
I noted, that you created help function intercol() to mix 2 colors, but
shading language has built-in function mix() with same functionality.
Using it instead of user-function will save couple of commands.
You calculate value of opac from dot production of normalized normal and
  incident vectors, later you calculate normalized normal vector again
and  store it in variable Norm. By moving this before opac calculation,
you can save one vector normalization.
I'm not sure, what is meaning of variable teken? Will it hold sign of
cosinus? In this case it would be much more effective to use built-in
sign function (note, that sign returns 0, if argument is 0, but in
current case it does not matter, as value of ruis4 should remain same).
There is couple of variables, which values are calculated, but never
used. Better would be to comment them out, if you don't want to delete
them. Unfortunately SL compiler is not so smart, that it could throw
such unnecessary statements away...
Sorry to be so critic, but as my measurments have shown, shader
execution takes great deal of rendering time and every optimization
there is welcome.
However, this shader is quite nice and I'd like to add it to shader
examples section in my homepage (with your permission, of course). And
I'd like to put your contact information (name and e-mail address) there
  as well. This would be of course only in case, if you don't have
nothing against it (some people don't want to put e-mail addresses in
web pages to avoid spam). So please reply here or send me mail, if you
agree with it.
Date: 11 Jan 2002 21:29:35
Message: <3c3f9f8f$1@news.povray.org>
> beautiful pictures!
tnx
> suggestions?
well, I'm sure it could be improved a lot :)
hmmm, not really a surprise :)  I assumed there was such a function, but
finding the name would have taken me more time than just make it myself :)
you see, I don't know the names of the build-in function, so instead of
searching for them, I just made my own functions out of my limited knowledge
of the shader-language :)
I'll delete them.
> there is welcome.
uhm, why sorry?  They're helpfull comments! tnx! :)
uhm, not yet please.  There is a bug in: the 'transparantie'-variable
doesn't work as it should.  I'll add the improvements you suggested and fix
that problem.  Once that's done (might be later this night) I'd be happy to
let you put it on your site.
> agree with it.
Spamming might be a problem indeed.  If you do this, maybe you should use my
other email-adres: zeg### [at] yahoocom
So, I'll work on it now :)
cu!
ZK AKA SaD
http://www.povplace.be.tf
"Luckyly they included a button, right here, that'll blow the entire thing
up!"
