POV-Ray : Newsgroups : povray.binaries.images : rad prob Server Time
14 Jan 2026 03:14:20 EST (-0500)
  rad prob (Message 1 to 10 of 12)
Subject: rad prob
Date: 15 Nov 2001 15:45:16
Message: <3bf4295c@news.povray.org>
From: "Mick Hazelgrove" <mic### [at] mhazelgrovefsnetcouk>
Subject:
Date: 15 November 2001 20:13
Hi
Notice the black marks aon the window arches. Any ideas what is causing them
or how I can get rid of them?
I suspect they are due to radiosity settings. The arches are basic triangle
meshes created in hamapatch and converted to pov by 3dwin.
Radiosity settings I'm using
    radiosity{
       pretrace_start 1//0.08
       pretrace_end   1//0.04  //.004
       count 400  // 2-400 in final
       nearest_count 8
       error_bound 0.15
       recursion_limit 2
       low_error_factor 0.5
       gray_threshold 0
       minimum_reuse 0.015
       brightness 1.0
       adc_bailout 0.01/2
   normal on
   media on
Any help gratefully received
Mick
Download 'Yuma Head.jpg' (41 KB)
Preview of image 'Yuma Head.jpg'
Subject: Re: rad prob
Date: 15 Nov 2001 15:54:52
Message: <3bf42b9c$1@news.povray.org>
He he... it looks like posting messages with already-used titles is becoming
a very common mistake (in your case the message was attached to another
<no-title> message posted many months ago by... YOU (again) :-D
The black dots you're talking about are barely visible. Have you tried to
render it without radiosity? Are those dots still there? Otherwise they
might be due to bad convertion process (maybe inverted normals or something
like that).
Very nice scene.
Jonathan.
"Mick Hazelgrove" <mic### [at] mhazelgrovefsnetcouk> ha scritto nel messaggio
news:3bf4295c@news.povray.org...
> Subject:
> Hi
them
triangle
>     radiosity{
>        nearest_count 8
>        error_bound 0.15
>        recursion_limit 2
>        gray_threshold 0
>        minimum_reuse 0.015
>        brightness 1.0
>        adc_bailout 0.01/2
>    normal on
>    media on
> Mick
Date: 15 Nov 2001 16:00:54
Message: <3bf42d06$1@news.povray.org>
I've just noticed one thing: the helix column on the right looks like it's
directly lit by the sky. Probably a radiosity accuracy problem.
Jonathan.
> Subject:
> Hi
them
triangle
>     radiosity{
>        nearest_count 8
>        error_bound 0.15
>        recursion_limit 2
>        gray_threshold 0
>        minimum_reuse 0.015
>        brightness 1.0
>        adc_bailout 0.01/2
>    normal on
>    media on
> Mick
Date: 15 Nov 2001 16:09:45
Message: <3bf42f19@news.povray.org>
Yes I noticed that - it might be lit from behind as there is a gap in the
wall I'll have to move it to find out.
Mick
Date: 15 Nov 2001 19:15:23
Message: <3BF45B69.F94F5405@faricy.net>
The mistake is not that the person put in a preexisting subject line,
it's that the newsreader can't thread properly...
Date: 16 Nov 2001 03:21:22
Message: <3bf4cc82@news.povray.org>
I have a suggestion not related to the radiosity problem:
The arches look a bit odd. They would break down in the real world, because
they don't lie on the wall and the forces from above can't go to the bottom.
Make the windows a bit smaller or the arch wider.
I hope my english was clear enough to give you an understanding of what I'm
trying to say. It's difficult for me to explain something in a foreign
language when the discussion is about architecture or other special
fields...
So long,
Bonsai
Date: 16 Nov 2001 03:28:18
Message: <3bf4ce22@news.povray.org>
Nice pic :)
Are the pillars supposed to be rounded like that at the bottom? It wouldn't
really do the job of a pillar that way. Unless of course it's reinforced with
steel...
- Nekar
http://nekar_xenos.tripod.com/metanoia/
Version: 6.0.286 / Virus Database: 152 - Release Date: 2001/10/09
Date: 16 Nov 2001 10:26:47
Message: <3bf53037@news.povray.org>
news: 3bf42f19@news.povray.org...
Perhaps related : I recently came upon a similar problem where rad light
managed to pass between two coincident boxes (a wall on a floor). The
problem disappeared when the wall was slightly lowered into the floor. I now
make sure that objects do not totally coincide.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 16 Nov 2001 12:26:56
Message: <3bf54c60@news.povray.org>
"Bonsai" <bon### [at] b0n541net> wrote in message
news:3bf4cc82@news.povray.org...
because
bottom.
Don't worry ther's another bit to go in when I've finished modelling it that
will support the arch!
Mick
Date: 16 Nov 2001 12:28:34
Message: <3bf54cc2@news.povray.org>
"Nekar Xenos" <j-p### [at] citywalkcoza> wrote in message
news:3bf4ce22@news.povray.org...
wouldn't
with
> steel...
Nope this is a WIP with a long, long way to go... I was hoping someone could
help with the black marks on the mesh.
Mick
