POV-Ray : Newsgroups : povray.binaries.images : Media problem... Server Time
20 Apr 2026 05:02:03 EDT (-0400)
  Media problem... (Message 1 to 7 of 7)
Subject: Media problem...
Date: 28 Oct 2001 09:57:28
Message: <3bdc1cd8@news.povray.org>
     Using Steve's and others suggestion of a clear cone and media, I'm
somewhat closer to what I want to achieve, but if you look at the image
where the light crosses the illuminated window, you can see clearly a kind
of dark/black hue or line. It doesn't show so much in the darker areas, so
how do I remove it?  Also, I'm getting it wrong where it's supposed to start
fading, can anyone help me with this? I've tried fade_distance in the light
source but can't see any difference between a low setting and a high
setting, ie, I've tried .8 and 3.8.
     Thanks for any help.
      ~Steve~
     Here's the code...
   light_source { <-10.125, 5.83, 13> colour Yellow * 1.5
  area_light <4, 0, 0>, <0, 0, 4>, 4, 4
  adaptive 1.5
  jitter
   fade_distance 3.8
#declare Media =
media {
emission .028
      intervals 5
      samples 1, 10
      confidence .9999
            variance 1/1000
      density{
              gradient y
              ramp_wave
              turbulence 18 //0.3
              colour_map{
                        [0.0 colour <.6, .6, 0.3>]
              scale <1,1,1>
              translate <-10.6, 5.2, 14>
cone{<0,-7.5,0>20,
     <0,1.3,0>.05
     pigment{rgb Clear}
     interior{media{Media}}
     hollow
Download 'bb35.jpg' (38 KB)
Preview of image 'bb35.jpg'
Subject: Re: Media problem...
Date: 28 Oct 2001 10:10:36
Message: <3bdc1fec@news.povray.org>
try adding
fade_power 2 to the light source as well, this will really increase the
falloff rate
change Clear to rgbt 1  (Clear = rgbf 1 which comes out different fo some
reason)
Also, why are you using emitting media rather than scattering?
-tgq
"25ct" <25c### [at] lineonenet> wrote in message news:3bdc1cd8@news.povray.org...
> Hi,
start
light
>       ~Steve~
>      Here's the code...
>   adaptive 1.5
>   jitter
>    fade_distance 3.8
> #declare Media =
> media {
> emission .028
>       intervals 5
>       samples 1, 10
>       confidence .9999
>             variance 1/1000
>       density{
>               gradient y
>               ramp_wave
>               turbulence 18 //0.3
>               colour_map{
>               scale <1,1,1>
> cone{<0,-7.5,0>20,
>      <0,1.3,0>.05
>      pigment{rgb Clear}
>      hollow
Date: 28 Oct 2001 11:04:37
Message: <3bdc2c95@news.povray.org>
"Trevor Quayle" <Tin### [at] hotmailcom> wrote in message
news:3bdc1fec@news.povray.org...
> try adding
> falloff rate
> reason)
      Aha! Good question Trevor! :) I used Steves code from his site as he
suggested and didn't change it. Thanks for your reply. I'll give it a go
right now.
   ~Steve~
> -tgq
Date: 28 Oct 2001 14:15:41
Message: <3bdc595d@news.povray.org>
Makes more sense to me to use emitting in this particular case. If he were
using scattering, then he shouldn't confine the media to the cone shape. It
may make sense to add fog to the scene to simulate the absorption part of
the media.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
> try adding
> falloff rate
> reason)
> -tgq
> > Hi,
kind
so
> start
> light
> >       ~Steve~
> >      Here's the code...
> >   adaptive 1.5
> >   jitter
> >    fade_distance 3.8
> > #declare Media =
> > media {
> > emission .028
> >       intervals 5
> >       samples 1, 10
> >       confidence .9999
> >             variance 1/1000
> >       density{
> >               gradient y
> >               ramp_wave
> >               turbulence 18 //0.3
> >               colour_map{
> >               scale <1,1,1>
> > cone{<0,-7.5,0>20,
> >      <0,1.3,0>.05
> >      pigment{rgb Clear}
> >      hollow
Date: 28 Oct 2001 15:00:44
Message: <3bdc63ec@news.povray.org>
"Slime" <noo### [at] hotmailcom> wrote in message
news:3bdc595d@news.povray.org...
It
> the media.
    Also, when I was using emitting media, the whole scene was taking just 6
minutes to render, but now that I've changed it to scattering, it just
overheated my CPU at 90 deg c, (the alarm went off), on line 39 of
480........ wait for it....... 1 hour 27 minutes later!  :o(
  I'll try your suggestion Slime. Thanks.
     ~Steve~
> - Slime
Date: 28 Oct 2001 16:49:49
Message: <3BDC7D89.282E1C53@ignorancia.org>
  Uh! If I were you, I will install as fast as posible a proper heatsink
and fan to the CPU... 90C is way too high temp for any processor, and
doing intesive CPU activity can give you a burned processor. Believe me,
I know what I'm talking about... I burned my first AMD because the
provider installed an undersized CPU fan. Now, the replacement one, with
a proper fan, never reaches 50 deg C.
  Take care!
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 28 Oct 2001 17:17:10
Message: <3bdc83e6@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> wrote in message
news:3BDC7D89.282E1C53@ignorancia.org...
>   Take care!
       Thanks for your concern Jaime, I will. The fan is the proper one,
it's the heatsink that's the problem. The guy that put this motherboard in 6
months ago *did* mutter something about  "...the heatsink should be
alright". Huh! Guess who I'm seeing tomorrow....     >:o(
   ~Steve~
> La Persistencia de la Ignorancia
